_Geant4 Version:_11.1.1
_Operating System:_Macos 14 sonoma with
_Compiler/Version:_pple clang version 15.0.0 (clang-1500.0.40.1)
_CMake Version:_cmake 3.24.4
HI! I installed Geant4 11.1.1 in MacOS 13 with xcode14.x,my work worked successfully. after macOS is upgraded to macOS 14,Geant4 doesn’t work well, so I reinstall geant4,but the example B1 failed. here is the terminal in Attachment.
-- Check for working C compiler: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clan
g - broken
CMake Error at /opt/local/share/cmake-3.24/Modules/CMakeTestCCompiler.cmake:69 (message):
The C compiler
"/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang"
is not able to compile a simple test program.
It fails with the following output:
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -I/usr/local/opt/libomp/include -arch arm64 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX14.0.sdk -Wl,-search_paths_first -Wl,-headerpad_max_install_names -Wl,-rpath,/usr/local/opt/libomp/lib -L/usr/local/opt/libomp/lib -lomp CMakeFiles/cmTC_bc87c.dir/testCCompiler.c.o -o cmTC_bc87c
ld: warning: search path '/usr/local/opt/libomp/lib' not found
ld: library 'omp' not found
clang: error: linker command failed with exit code 1 (use -v to see invocation)
make[1]: *** [cmTC_bc87c] Error 1
make: *** [cmTC_bc87c/fast] Error 2
Geant4 doesn’t use OpenMP at all, so I’d suspect the upgrade wiped that and you’ll either need to reinstall that, or check your environment/system settings to remove this (it might be in CXXFLAGS or LDFLAGS).
