Reflectivity using glisur vs unified
I have a simulation of a liquid scintillator detector, consisting of a aluminum box filled with scintillating material. When I implement the glisur model for the surface on the inside of the detector between the aluminum and scintillator as below
  G4OpticalSurface* BaSO4_surfaceLT = new G4OpticalSurface("BaSO4_surfaceLT");
  BaSO4_surfaceLT->SetType(dielectric_metal);
  BaSO4_surfaceLT->SetFinish(ground);
  BaSO4_surfaceLT->SetModel(glisur);
  G4double photonEnergy9[2] = {1*eV, 5*eV};
  G4double other_coating[2] = {0, 0};
  G4double total_Al[2] = {0.5, 0.5};
  G4double specular_Al[2] = {0.5, 0.5};
  G4MaterialPropertiesTable* MTP_BaSOLT = new G4MaterialPropertiesTable();
  MTP_BaSOLT->AddProperty("SPECULARSPIKECONSTANT", photonEnergy9, other_coating, 2);
  MTP_BaSOLT->AddProperty("BACKSCATTERCONSTANT", photonEnergy9, other_coating, 2);
  MTP_BaSOLT->AddProperty("SPECULARLOBECONSTANT", photonEnergy9, specular_Al, 2);
  MTP_BaSOLT->AddProperty("REFLECTIVITY", photonEnergy9, total_Al, 2);
  BaSO4_surfaceLT->SetMaterialPropertiesTable(MTP_BaSOLT);
  G4LogicalSkinSurface* SurfaceLT = new G4LogicalSkinSurface("BaSO4_surfaceLT", ReflectBoxLT_log, BaSO4_surfaceLT);
the results come out the same regardless of the fraction of specular reflectivity. When I change the “REFLECTIVITY” parameter the results change but when the “SPECULARLOBECONSTANT” is modified using any number between 0-1 the results do not change. This is fixed by changing the model from glisur to unified without changing any other lines. Is there a problem with the way the glisur model is implemented here?
This is running on the most recent version of lxplus with the following
Geant4 Version: 11.2
Operating System: RHEL 9.4
Compiler/Version: gcc (GCC) 11.4.1 20231218 (Red Hat 11.4.1-3)
CMake Version: 3.18.3
Glisur dates from Geant3 days, and I haven’t seen any documentation for it.
Unified contains the parameters from Glisur, plus many others. Probably SPECULARLOBECONSTANT isn’t part of the Glisur model.
I recommend using the Unified model, for new applications at least.
Let me ask: why do you want to use Glisur, and why do you think there is a problem (that is, why do you think SPECULARLOBECONSTANT should be part of the model)?
Hi Daren,
Thanks very much for your reply. This is an old code passed down to me and originally based upon the OpNovice example, which uses the Glisur model. I could not find much documentation either, but since the Book for Application Developers states that it is very similar to the Unified I assumed that it could be implemented in the same way. Perhaps you are correct and the SPECULARLOBECONSTANT does not exist in this model. I will use Unified going forward.
