Geant4 Version: 10.07
Operating System: Ubuntu
Hi All,
I am trying to build a sim that alters the thickness of shielding with a macro command between runs. The macro is working, I can see the plate changing thickness in the viewer. When I try and reinitialize the geometry between runs the data isn’t written to file.
One possible cause is the runID doesn’t seem to be updating properly. My “beginrunaction” function is called with a runID of 0 and a threadID = -1. The function is then called for each of the 6 threads with a runID which increases, and threadID between 0 and 5 (i.e. it works). If I don’t reinitialize the geometry everything is recorded properly and the runID as expected.
Below is my run action
#include "RunAction.hh"
#include "PrimaryGeneratorAction.hh"
#include "G4RunManager.hh"
#include "G4Run.hh"
#include "G4AccumulableManager.hh"
#include "G4LogicalVolumeStore.hh"
#include "G4LogicalVolume.hh"
#include "G4UnitsTable.hh"
#include "G4SystemOfUnits.hh"
#include <iostream>
#include <ctime>
#include "DetectorMessenger.hh"
#include <string>
#include <cstring>
#include <dirent.h>
RunAction::RunAction()
: G4UserRunAction(),
fEdep(0.)
G4RunManager::GetRunManager()->GeometryHasBeenModified();
// Register accumulable to the accumulable manager
G4AccumulableManager* accumulableManager = G4AccumulableManager::Instance();
accumulableManager->RegisterAccumulable(fEdep);
man->SetNtupleMerging(true);
man->CreateNtuple("Hits", "Hits");
man->CreateNtupleIColumn("runID");
man->CreateNtupleIColumn("fEvent");
man->CreateNtupleDColumn("edep");
man->CreateNtupleDColumn("shielding");
man->CreateNtupleSColumn("shield_mat");
man->FinishNtuple(0);
RunAction::~RunAction()
void RunAction::BeginOfRunAction(const G4Run* run)
G4int runID = run->GetRunID();
G4int thr = G4Threading::G4GetThreadId();
std::cout << "\n\n\nBegin of Run Action Called\nRunID: " << runID << "\nThread ID: " << thr << "\n\n\n" << std::endl;
std::stringstream strRunID;
strRunID << runID;
man->OpenFile("output"+strRunID.str()+".root");
void RunAction::EndOfRunAction(const G4Run* run)
std::cout << "\n\n\nEnd of Run Action Called\nRunID: " << runID << "\nThread ID: " << thr << "\n\n\n" << std::endl;
man->Write();
man->CloseFile();
void RunAction::AddEdep(G4double edep)
fEdep += edep;
Here is the detector construction
#include "DetectorConstruction.hh"
#include "G4NistManager.hh"
#include "G4Box.hh"
#include "G4Tubs.hh"
#include "G4Cons.hh"
#include "G4Orb.hh"
#include "G4Sphere.hh"
#include "G4Trd.hh"
#include "G4PVPlacement.hh"
#include "Detector.hh"
DetectorConstruction::DetectorConstruction()
: G4VUserDetectorConstruction(),
fScoringVolume(0)
DefineMaterials();
fmessenger = new G4GenericMessenger(this, "/shielding/", "Shielding Thickness");
fmessenger->DeclareProperty("thickness", sZ, "Width of shielding material");
sZ = 0.3*cm;
DetectorConstruction::~DetectorConstruction()
void DetectorConstruction::DefineMaterials(){
// Get nist material manager
env_mat = nist->FindOrBuildMaterial("G4_AIR");
world_mat = nist->FindOrBuildMaterial("G4_AIR");
shielding_mat = nist->FindOrBuildMaterial("G4_Al");
det_mat = nist->FindOrBuildMaterial("G4_SODIUM_IODIDE");
std::cout << "\n\n\nConstruction Called\n" << sZ << "\n\n\n" << std::endl;
DetectorMessenger::GetInstance()->SetThickness(sZ);
// Envelope parameters
G4double env_sizeXY = 1*m, env_sizeZ = 1*m;
// Option to switch on/off checking of volumes overlaps
G4bool checkOverlaps = true;
// World
G4double world_sizeXY = 1.2*env_sizeXY;
G4double world_sizeZ = 1.2*env_sizeZ;
solidWorld =
new G4Box("World", //its name
0.5*world_sizeXY, 0.5*world_sizeXY, 0.5*world_sizeZ); //its size
logicWorld =
new G4LogicalVolume(solidWorld, //its solid
world_mat, //its material
"World"); //its name
physWorld =
new G4PVPlacement(0, //no rotation
G4ThreeVector(), //at (0,0,0)
logicWorld, //its logical volume
"World", //its name
0, //its mother volume
false, //no boolean operation
0, //copy number
checkOverlaps); //overlaps checking
// Envelope
solidEnv =
new G4Box("Envelope", //its name
0.5*env_sizeXY, 0.5*env_sizeXY, 0.5*env_sizeZ); //its size
logicEnv =
new G4LogicalVolume(solidEnv, //its solid
env_mat, //its material
"Envelope"); //its name
envPhys =
logicEnv, //its logical volume
logicWorld, //its mother volume
0, //copy number
// Shielding
G4ThreeVector shielding_pos = G4ThreeVector(0, 0, 0);
shielding_pos.setZ(-sZ*cm/2);
solidShield =
new G4Box("shielding", //its name
20*cm, 20*cm, sZ*cm/2); //its size
logicShield =
new G4LogicalVolume(solidShield, //its solid
shielding_mat, //its material
"shieldingLog"); //its name
shieldPhys =
shielding_pos, //at (0,0,0)
logicShield, //its logical volume
"shieldingPhys", //its name
logicEnv, //its mother volume
0, //copy number
// Detector
G4double innerRadius = 0.*cm;
G4double outerRadius = 10.*cm;
G4double hz = 10.*cm;
G4double startAngle = 0.*deg;
G4double spanningAngle = 360.*deg;
G4ThreeVector det_pos = G4ThreeVector(0, 0, 0);
det_pos.setZ(-((sZ*cm) + hz)); // For some reason Threevectors don't update properly unless you do this, they are const.
detector
= new G4Tubs("detector",
innerRadius,
outerRadius,
hz,
startAngle,
spanningAngle);
detectorLog
= new G4LogicalVolume(detector,
det_mat,
"detectorLog");
detectorPhys
= new G4PVPlacement(0, // no rotation
det_pos, // translation position
detectorLog, // its logical volume
"detectorPhys", // its name
logicEnv, // its mother (logical) volume
false, // no boolean operations
0); // its copy number
// Set Shape2 as scoring volume
fScoringVolume = detectorLog;
//always return the physical World
return physWorld;
void DetectorConstruction::ConstructSDandField()
SensitiveDetector *sensDet = new SensitiveDetector("SensitiveDetector");
detectorLog->SetSensitiveDetector(sensDet);
Action Initialization
#include "ActionInitialization.hh"
#include "EventAction.hh"
#include "SteppingAction.hh"
ActionInitialization::ActionInitialization()
: G4VUserActionInitialization()
ActionInitialization::~ActionInitialization()
void ActionInitialization::BuildForMaster() const
RunAction* runAction = new RunAction;
SetUserAction(runAction); // Tells GEANT4 to use user run action instead of default
void ActionInitialization::Build() const
SetUserAction(new PrimaryGeneratorAction);
EventAction* eventAction = new EventAction(runAction);
SetUserAction(eventAction);
SetUserAction(new SteppingAction(eventAction));
Attached is a copy of a macro file I am using with a low number of events.
isotope.txt (2.2 KB)
Finally, here is a link to the whole code on github
Any help you could provide would be greatly appreciated
