Hello Geant4 users,
I’ve been having some issues with reinitializing the geometry in my simulation.
Even when i don’t change any of the geometries via UI commands and generic messengers this error shows,
There’s no reason anything should be overlapping as i haven’t changed anything
Here is the code for my construction.cc file:
#include "construction.hh"
MyDetectorConstruction::MyDetectorConstruction()
nCols = 10;
nRows = 10;
xWorld = 0.05*m;
yWorld = 0.05*m;
zWorld = 0.05*m;
xRadiator1 = 0.02*m;
yRadiator1 = 0.02*m;
zRadiator1 = 0.0025*m;
dRadiator1 = 0.03*m;
xRadiator2 = 0.02*m;
yRadiator2 = 0.02*m;
zRadiator2 = 0.005*m;
dRadiator2 = 0.007*m;
xDet = 0.02*m;
yDet = 0.02*m;
mRadiator1 = 2; // 1 = water, 2 = aerogel
mRadiator2 = 3; // 3 = glass
mWorld = 4; // 4 = air
xPixel = xDet/nRows;
yPixel = yDet/nCols;
zPixel = 0.001*m;
dMessenger = new G4GenericMessenger(this, "/detector/", "Detector Construction");
wMessenger = new G4GenericMessenger(this, "/world/", "World Construction");
r1Messenger = new G4GenericMessenger(this, "/Radiator1/", "Radiator1 Construction");
r2Messenger = new G4GenericMessenger(this, "/Radiator2/", "Radiator2 Construction");
mMessenger = new G4GenericMessenger(this, "/materials/", "Materials");
dMessenger->DeclareProperty("nCols", nCols, "Number of columns");
dMessenger->DeclareProperty("nRows", nRows, "Number of rows");
dMessenger->DeclareProperty("xDet", xDet, "X length of detector");
dMessenger->DeclareProperty("yDet", yDet, "Y length of detector");
wMessenger->DeclareProperty("xWorld", xWorld, "X length of world");
wMessenger->DeclareProperty("yWorld", yWorld, "Y length of world");
wMessenger->DeclareProperty("zWorld", zWorld, "Z length of world");
r1Messenger->DeclareProperty("xRadiator1", xRadiator1, "X length of Radiator1");
r1Messenger->DeclareProperty("yRadiator1", yRadiator1, "Y length of Radiator1");
r1Messenger->DeclareProperty("zRadiator1", zRadiator1, "Z length of Radiator1");
r1Messenger->DeclareProperty("dRadiator1", dRadiator1, "Distance from Radiator1 to detectors");
r2Messenger->DeclareProperty("xRadiator2", xRadiator2, "X length of Radiator2");
r2Messenger->DeclareProperty("yRadiator2", yRadiator2, "Y length of Radiator2");
r2Messenger->DeclareProperty("zRadiator2", zRadiator2, "Z length of Radiator2");
r2Messenger->DeclareProperty("dRadiator2", dRadiator2, "Distance from Radiator2 to detectors");
mMessenger->DeclareProperty("mRadiator1", mRadiator1, "Radiator 1 material");
mMessenger->DeclareProperty("mRadiator2", mRadiator2, "Radiator 2 material");
mMessenger->DeclareProperty("mWorld", mWorld, "World material");
DefineMaterials();
MyDetectorConstruction::~MyDetectorConstruction()
void MyDetectorConstruction::DefineMaterials()
G4NistManager *nist = G4NistManager::Instance(); //the geant4 nist material database
SiO2 = new G4Material("SiO2", 2.201*g/cm3, 2); //defining the silicone dioxide material object
SiO2->AddElement(nist->FindOrBuildElement("Si"), 1); //adding the silicone element to the object
SiO2->AddElement(nist->FindOrBuildElement("O"), 2); //adding the oxygen element to the object
H2O = new G4Material("H2O", 1.000*g/cm3, 2); //defining h20 material object
H2O->AddElement(nist->FindOrBuildElement("H"), 2); //adding the hydrogen element to object
H2O->AddElement(nist->FindOrBuildElement("O"), 1); //adding the oxygen element to object
C = nist->FindOrBuildElement("C"); //creating the carbon material object
B2O3 = new G4Material("B2O3", 2.46*g/cm3, 2);
B2O3->AddElement(nist->FindOrBuildElement("B"), 2);
B2O3->AddElement(nist->FindOrBuildElement("O"), 3);
G4double energy[2] = {1.239841939*eV/0.9, 1.239841939*eV/0.2}; //momentum of photons usng conversion factor *eV / wavlength of red light and blue light
G4double rindexAerogel[2] = {1.1, 1.1}; //refractive index of aerogel
G4double rindexAir[2] = {1.0, 1.0}; //refractive index of the world volume (air)
G4double rindexWater[2] = {1.333, 1.333}; //refractive index of the world volume (water)
G4double rindexGlass[2] = {1.5, 1.5}; //refractive index of glass
if(mRadiator1 == 1)
radiatorMat1 = nist->FindOrBuildMaterial("G4_WATER"); //createing the radiator material (water)
mptRadiator1 = new G4MaterialPropertiesTable(); //creating properites object for water
mptRadiator1->AddProperty("RINDEX", energy, rindexWater, 2); //adding property to object
radiatorMat1->SetMaterialPropertiesTable(mptRadiator1); //assigning properties object to radiator material object
if(mRadiator1 == 2)
radiatorMat1 = new G4Material("Aerogel", 0.200*g/cm3, 3); //creating the aerogel material object
radiatorMat1->AddMaterial(SiO2, 62.5*perCent); //adding the silione dioxide material to aerogel object
radiatorMat1->AddMaterial(H2O, 37.4*perCent); //adding the h20 material to aergoel object
radiatorMat1->AddElement(C, 0.1*perCent); //adding the carbon material to aerogel object
mptRadiator1 = new G4MaterialPropertiesTable(); //creating aerogel material properties object
mptRadiator1->AddProperty("RINDEX", energy, rindexAerogel, 2); //adding property to this object
radiatorMat1->SetMaterialPropertiesTable(mptRadiator1); //assigning the Aergoel object the properties from the previous object created
if(mRadiator2 == 3)
radiatorMat2 = new G4Material("Glass", 2.23*g/cm3,2);//Creating glass
radiatorMat2->AddMaterial(SiO2, 70*perCent);
radiatorMat2->AddMaterial(B2O3, 30*perCent);
mptRadiator2 = new G4MaterialPropertiesTable(); //Creating glass material properties table
mptRadiator2->AddProperty("RINDEX", energy, rindexGlass, 2); //adding property to this object
radiatorMat2->SetMaterialPropertiesTable(mptRadiator2); //setting material properties
if(mWorld == 4)
worldMat = nist->FindOrBuildMaterial("G4_AIR"); //createing the world material (air)
mptWorld = new G4MaterialPropertiesTable(); //creating properites object for air
mptWorld->AddProperty("RINDEX", energy, rindexAir, 2); //adding property to object
worldMat->SetMaterialPropertiesTable(mptWorld); //assigning properties object to world material object
G4VPhysicalVolume *MyDetectorConstruction::Construct()
G4Box *solidWorld = new G4Box("solidWorld", xWorld, yWorld, zWorld); //setting up world volume as a box
G4LogicalVolume *logicWorld = new G4LogicalVolume(solidWorld, worldMat, "logicWorld"); //creating the world as dimensions from box and material
G4VPhysicalVolume *physWorld = new G4PVPlacement(0, G4ThreeVector(0., 0., 0.), logicWorld, "physWorld", 0, false, 0, true); //placing the world into geant 4 sim
G4Box *solidRadiator1 = new G4Box("solidRadiator1", xRadiator1, yRadiator1, zRadiator1); //setting the dimensions for the radiator
G4LogicalVolume *logicRadiator1 = new G4LogicalVolume(solidRadiator1, radiatorMat1, "logicRadiator1"); //creating the aergoel radiator from dimensions
G4VPhysicalVolume *physRadiator1 = new G4PVPlacement(0, G4ThreeVector(0., 0., zWorld-dRadiator1), logicRadiator1, "physRadiator1", logicWorld, false, 0, true); //placing radiator into world volume
G4Box *solidRadiator2 = new G4Box("solidRadiator2", xRadiator2, yRadiator2, zRadiator2); //setting dimensions of glass radiator
G4LogicalVolume *logicRadiator2 = new G4LogicalVolume(solidRadiator2, radiatorMat2, "logicRadiator2");
G4VPhysicalVolume *physRadiator2 = new G4PVPlacement(0, G4ThreeVector(0., 0., zWorld-dRadiator2), logicRadiator2, "physRadiator2", logicWorld, false, 0, true);
G4Box *solidDetector = new G4Box("solidDetector", xPixel, yPixel, zPixel); //setting the dimensions for the detectors
logicDetector = new G4LogicalVolume(solidDetector, worldMat, "logicDetector"); //creating the detectors, with same material as world
for(G4int i = 0; i < nRows; i++)
for(G4int j = 0; j <nCols; j++)
posX = -xDet+(i*2*xDet/nRows) + xDet/nRows;
posY = -yDet+(j*2*yDet/nCols) + yDet/nCols;
posZ = zWorld - zPixel;
physDetector= new G4PVPlacement(0, G4ThreeVector(posX, posY, posZ), logicDetector, "physDetector", logicWorld, false, j+i*nCols, true); //placing detectors into the world
G4cout << posX << posY << posZ << G4endl;
return physWorld; //returning the world, including everything inside
void MyDetectorConstruction::ConstructSDandField()
MySensitiveDetector *sensDet = new MySensitiveDetector("SensitiveDetector"); //creating a sensitive detector object
if(logicDetector != NULL)
logicDetector->SetSensitiveDetector(sensDet); //assigning the detectors as senstive detectors (it generates a hit when a track traverses its volume)
I do plan to use macro files to adjust the parameters of my geometry, however, when i reinitialize the geometry it throws errors due to overlapping. so i need to resolve this issue before I can proceed
EDIT:
Commenting out the messenger code has fixed the problem, but i need messengers…
Have i put them in wrong?
