rotateUz looks fishy
Geant4 implements a rotateUz function, which has been copy-pasted into ROOT (some reorganization of factors apart).
A ROOT user found out that the implementation of this function does not take into account the ‘quadrant’, ie the result might be mirrored if the x direction is negative and y direction is 0.
see: TVector3::RotateUz - General Chat - ROOT Forum
Could a developer look at it and confirm this extent?
Here is the relevant snippet:
Alternatively: could someone described what the equation was to reach this formula? What was the product of two individual rotation matrices assumed to reach that code implementation? Thanks in advance.
I think it is a theta rotation around y axis, followed by a phi rotation around z axis.
Theta is assumed to be in [0, pi] , phi in [0, twopi]
I used examples/extended/eventgenerator/particleGun, case 3, to check that rotateUz() works properly
Thanks a lot for checking. Let’s assume phi=0, ie uy=0..
The question: why is then theta restricted to 0 to pi? And not -pi to pi.
It’s not the same to describe a vector in polar coordinates than to perform a rotation of one full reference frame in 3D to another I guess?
In other words, i guess because in a local frame it does not matter how X and Y are oriented, I think that rotateUz does a two rotations plus one XY reflection (sometimes).
I found out the equation behind the scenes:
C = A x B
A =
u1/up  -u2/up 0
u2/up   u1/up 0
0       0     1
B =
u3  0 up
0   1 0
-up 0 u3
But up is always a positive number (theta is in 0, pi, as you said). So the sign of u1 and u2 is totally ignored for creating the B rotation (not for A).
In the case of u1=0, I do not see clearly if this rotation makes sense. (Why should it be rotated around y-axis?)
In the case of u2=0, and u1<0, A becomes a rotation by pi but B stays the same independently of u1<0 or u1>0, ie B is rotating in the ‘wrong sense’ of the y-axis right-hand rule.
Related: [math] Improve TVector3::RotateUz documentation · root-project/root@0ae85ac · GitHub
Related post about the discontinuity bug of this pseudo-rotation matrix:
@gcosmo @bmorgan @atolosad @mkelsey what’s your opinion?
Could this behavior be better documented?
This feels to me like it’s nothing more than gimbal lock, which is inescapable with polar coodinates. Phi is intrinsically undefined at theta=0, etc. etc. You’re right that the behaviour could be better documented, but it’s not obvious to me at least where that documention would/should live.
rotateUz is a method of Hep3Vector in CLHEP. Its documentation can be found in the CLHEP User Guide, so any update should eventually be applied there.
The rotation matrix used in this function is:
u1*u3/up    -u2/up    u1
u2*u3/up     u1/up    u2
-up          0        u3
Let me explain how it was calculated. The columns of a rotation matrix represent the coordinates of the new axes: the first column is the new X-axis, the second is the new Y-axis , the third is the new Z-axis.
In the case of rotateUz(), the new Z was specified, so the third column is (u1,u2,u3). To fill the elements of the second column we can take any unit vector orthogonal to the new Z-axis. After that, the first column can be calculated as a cross product of the second and the third columns.
New Y-axis is calculated as a cross product of the old and new Z axes:
(0,0,1)x(u1,u2,u3) = (-u2,u1,0)
after normalisation it becomes (-u2/up,u1/up,0)
Respectively the new X-axis:
(-u2/up,u1/up,0)x(u1,u2,u3) = (u1*u3/up,u2*u3/up,-up)
There is a special case when the new Z-axis is collinear to the old Z-axis. This case is considered separately.
Thanks a lot! That makes it much clearer than speaking about the composition of two rotations.
