Dear experts,
First, let me say that I’m a newbie, please sorry if not is a good question.
I’m trying to see the secondary radiation with a second volume when primaries, in this case protons, deposited dose in the first volume (see pic).
When I increase the energy of primary protons, that these pass throughout the first volume (box), these WARNINGS happen and the run crashed.
I searched for that but I can not find any solution. I’m running the code in sequential mode.
If anybody can help me I’ll appreciate it. Thank you in advance.
WARNING - Attempt to delete the physical volume store while geometry closed !
WARNING - Attempt to delete the logical volume store while geometry closed !
WARNING - Attempt to delete the solid store while geometry closed !
WARNING - Attempt to delete the region store while geometry closed !
There should have been some sort of FATAL error reported before those lines, or maybe you have an explicit “::exit()” somehwere in your application code. Those warning happen if the application attempts to quit out in the middle of a run (i.e., during a /run/beamOn event loop), and the static object cleanup deletes the geometry stores .
Thank you so much!! I’ll check
Yes, you are right, before given to me all those WARNINGS, give this:
*** Break *** segmentation violation
There was a crash.
This is the entire stack trace of all threads:
#0 0x00007f265a038dba in wait4 () from /usr/lib/x86_64-linux-gnu/libc.so.6
#1 0x00007f2659fa80e7 in ?? () from /usr/lib/x86_64-linux-gnu/libc.so.6
#2 0x00007f265be7636e in TUnixSystem::StackTrace() () from /home/dayron/Apps/root/root-build/lib/libCore.so
#3 0x00007f265be7308c in TUnixSystem::DispatchSignals(ESignals) () from /home/dayron/Apps/root/root-build/lib/libCore.so
#4
#5 0x000055722078bdfd in SteppingAction::UserSteppingAction(G4Step const*) ()
#6 0x00007f265ac2e7d5 in G4SteppingManager::Stepping() () from /home/dayron/Apps/Geant4/geant4-install/lib/libG4tracking.so
#7 0x00007f265ac398ec in G4TrackingManager::ProcessOneTrack(G4Track*) () from /home/dayron/Apps/Geant4/geant4-install/lib/libG4tracking.so
#8 0x00007f265ac74b2a in G4EventManager::DoProcessing(G4Event*) () from /home/dayron/Apps/Geant4/geant4-install/lib/libG4event.so
#9 0x00007f265ad146c7 in G4RunManager::DoEventLoop(int, char const*, int) () from /home/dayron/Apps/Geant4/geant4-install/lib/libG4run.so
#10 0x00007f265ad12312 in G4RunManager::BeamOn(int, char const*, int) () from /home/dayron/Apps/Geant4/geant4-install/lib/libG4run.so
#11 0x00007f265ad2c0b7 in G4RunMessenger::SetNewValue(G4UIcommand*, G4String) () from /home/dayron/Apps/Geant4/geant4-install/lib/libG4run.so
#12 0x00007f265a68db83 in G4UIcommand::DoIt(G4String) () from /home/dayron/Apps/Geant4/geant4-install/lib/libG4intercoms.so
#13 0x00007f265a6ac9ef in G4UImanager::ApplyCommand(char const*) () from /home/dayron/Apps/Geant4/geant4-install/lib/libG4intercoms.so
#14 0x00007f265a67c4b1 in G4UIbatch::ExecCommand(G4String const&) () from /home/dayron/Apps/Geant4/geant4-install/lib/libG4intercoms.so
#15 0x00007f265a67e466 in G4UIbatch::SessionStart() () from /home/dayron/Apps/Geant4/geant4-install/lib/libG4intercoms.so
#16 0x00007f265a6ae260 in G4UImanager::ExecuteMacroFile(char const*) () from /home/dayron/Apps/Geant4/geant4-install/lib/libG4intercoms.so
#17 0x00007f265a69a426 in G4UIcontrolMessenger::SetNewValue(G4UIcommand*, G4String) () from /home/dayron/Apps/Geant4/geant4-install/lib/libG4intercoms.so
#18 0x00007f265a68db83 in G4UIcommand::DoIt(G4String) () from /home/dayron/Apps/Geant4/geant4-install/lib/libG4intercoms.so
#19 0x00007f265a6ac9ef in G4UImanager::ApplyCommand(char const*) () from /home/dayron/Apps/Geant4/geant4-install/lib/libG4intercoms.so
#20 0x000055722077ad15 in main ()
The lines below might hint at the cause of the crash.
You may get help by asking at the ROOT forum http://root.cern.ch/forum
Only if you are really convinced it is a bug in ROOT then please submit a
report at http://root.cern.ch/bugs Please post the ENTIRE stack trace
from above as an attachment in addition to anything else
that might help us fixing this issue.
And the problem is caused by this line:
G4String proName = step->GetTrack()->GetCreatorProcess()->GetProcessName();
In the UserSteppingAction().
Do you know how can I fix it??
Best, Dayron
The UserSteppingAction() is your own code, so you will need to debug it yourself. In the line you quote:
Notice that you are dereferencing a series of three pointers which are returned by function calls. More than likely, one of those functions returned a null pointer, which obviously can’t be dereferenced, since it doesn’t point to an object in memory.
Primary particles, for example, do not have a “creator process” since they’re instantiated by the PrimaryGeneratorAction, not as a secondary from a physics process. So if you happen to be processing a primary track, GetCreatorProcess() will return 0 (null pointer).
Thank you so much!! I already fixed it. The problem was that I was procesing primary tracks.
Thanks again.
Best, D
I’m facing the same but I don’t know how to identify the code line that causes it. When I’m running a simulation via the GUI no warning appears but via run.mac it does:
10 events have been kept for refreshing and/or reviewing.
(Note: No keep requests were made by the vis manager.
The kept events are those you have asked to be kept in your user action(s).)
“/vis/reviewKeptEvents” to review them one by one.
“/vis/enable”, then “/vis/viewer/flush” or “/vis/viewer/rebuild” to see them accumulated.
The command in run.mac is only
/run/beamOn 1000
But on the other side the file is generated so I’m not sure whether I shall investigate in this anyway?
