Dear Michael Kelsey,
Thank you very much for your quick response.
I followed your instructions and here is what the terminal stapled for me:
G4WT1 > Det1_lv neutron neutronInelastic 0.000873144 23.011 0.01552 0.754954 1
G4WT2 > Det60_lv gamma nCapture 0.310597 24.9989 0.0168608 0.820174 1
G4WT3 > Det3_lv neutron neutronInelastic 3.08636 2.89757 0.0019543 0.0950646 1
G4WT2 > Det2_lv neutron protonInelastic 261.669 23.8826 0.0161079 0.783549 1
Thread 3 "exampleED" received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x15554cbbd640 (LWP 3445525)]
std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string (__str=<error reading variable: Cannot access memory at address 0x130>, this=0x15554caa9f90) at /usr/include/c++/11/bits/basic_string.h:459
459 { _M_construct(__str._M_data(), __str._M_data() + __str.length()); }
(gdb) bt
#0 std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string (
#1 G4String::G4String (str=..., this=0x15554caa9f90) at /home/augusto/Scrivania/Geant4/geant4-v11.0.2-install/include/Geant4/G4String.icc:36
#2 ED::SensitiveDetector::ProcessHits (this=<optimized out>, aStep=0x15554004c3e0)
at /home/augusto/Scrivania/Geant4/geant4-v11.0.2/examples/CAVE_HIT_SD/src/SensitiveDetector.cc:81
#3 0x0000155551fd21c3 in G4VSensitiveDetector::Hit (aStep=0x15554004c3e0, this=0x155540234750)
at /home/augusto/Scrivania/Geant4/geant4-v11.0.2/source/digits_hits/detector/include/G4VSensitiveDetector.hh:127
#4 G4SteppingManager::Stepping (this=0x15554004c240) at /home/augusto/Scrivania/Geant4/geant4-v11.0.2/source/tracking/src/G4SteppingManager.cc:258
#5 0x0000155551fe8518 in G4TrackingManager::ProcessOneTrack (this=0x15554004abd0, apValueG4Track=apValueG4Track@entry=0x1555406fc1b0)
at /home/augusto/Scrivania/Geant4/geant4-v11.0.2/source/tracking/src/G4TrackingManager.cc:138
#6 0x0000155554c3238b in G4EventManager::DoProcessing (this=0x1555400188b0, anEvent=<optimized out>)
at /home/augusto/Scrivania/Geant4/geant4-v11.0.2/source/event/src/G4EventManager.cc:204
#7 0x0000155554dc8a5c in G4WorkerTaskRunManager::ProcessOneEvent (this=0x15554004a900, i_event=<optimized out>)
at /home/augusto/Scrivania/Geant4/geant4-v11.0.2/source/tasking/src/G4WorkerTaskRunManager.cc:243
#8 0x0000155554dc8766 in G4WorkerTaskRunManager::DoEventLoop (this=0x15554004a900, n_event=10000, macroFile=<optimized out>, n_select=-1)
at /home/augusto/Scrivania/Geant4/geant4-v11.0.2/source/tasking/src/G4WorkerTaskRunManager.cc:222
#9 0x0000155554dc8916 in G4WorkerTaskRunManager::DoWork (this=0x15554004a900)
at /home/augusto/Scrivania/Geant4/geant4-v11.0.2/source/tasking/src/G4WorkerTaskRunManager.cc:541
#10 0x0000155554dba732 in operator() (__closure=0x55557cfb6800) at /home/augusto/Scrivania/Geant4/geant4-v11.0.2/source/tasking/src/G4TaskRunManager.cc:475
#11 operator() (__closure=0x55557cfb67e8) at /home/augusto/Scrivania/Geant4/geant4-v11.0.2/source/externals/ptl/include/PTL/TaskGroup.icc:294
#12 std::__invoke_impl<void, PTL::TaskGroup<void, void>::exec<G4TaskRunManager::AddEventTask(G4int)::<lambda()> >(G4TaskRunManager::AddEventTask(G4int)::<lambda()>)::<lambda()>&> (__f=...) at /usr/include/c++/11/bits/invoke.h:61
#13 std::__invoke_r<void, PTL::TaskGroup<void, void>::exec<G4TaskRunManager::AddEventTask(G4int)::<lambda()> >(G4TaskRunManager::AddEventTask(G4int)::<lambda()>)::<lambda()>&> (__fn=...) at /usr/include/c++/11/bits/invoke.h:111
#14 operator() (__closure=<optimized out>) at /usr/include/c++/11/future:1468
#15 std::__future_base::_Task_setter<std::unique_ptr<std::__future_base::_Result<void>, std::__future_base::_Result_base::_Deleter>, std::__future_base::_Task_state<PTL::TaskGroup<void, void>::exec<G4TaskRunManager::AddEventTask(G4int)::<lambda()> >(G4TaskRunManager::AddEventTask(G4int)::<lambda()>)::<lambda()>, std::allocator<int>, void()>::_M_run()::<lambda()>, void>::operator() (this=<optimized out>) at /usr/include/c++/11/future:1409
#16 std::__invoke_impl<std::unique_ptr<std::__future_base::_Result<void>, std::__future_base::_Result_base::_Deleter>, std::__future_base::_Task_setter<std::unique_ptr<std::__future_base::_Result<void>, std::__future_base::_Result_base::_Deleter>, std::__future_base::_Task_state<PTL::TaskGroup<void, void>::exec<G4TaskRunManager::AddEventTask(G4int)::<lambda()> >(G4TaskRunManager::AddEventTask(G4int)::<lambda()>)::<lambda()>, std::allocator<int>, void()>::_M_run()::<lambda()>, void>&> (__f=...)
#17 std::__invoke_r<std::unique_ptr<std::__future_base::_Result_base, std::__future_base::_Result_base::_Deleter>, std::__future_base::_Task_setter<std::unique_ptr<std::__future_base::_Result<void>, std::__future_base::_Result_base::_Deleter>, std::__future_base::_Task_state<PTL::TaskGroup<void, void>::exec<G4TaskRunManager::AddEventTask(G4int)::<lambda()> >(G4TaskRunManager::AddEventTask(G4int)::<lambda()>)::<lambda()>, std::allocator<int>, void()>::_M_run()::<lambda()>, void>&> (__fn=...)
at /usr/include/c++/11/bits/invoke.h:116
#18 std::_Function_handler<std::unique_ptr<std::__future_base::_Result_base, std::__future_base::_Result_base::_Deleter>(), std::__future_base::_Task_setter<std::unique_ptr<std::__future_base::_Result<void>, std::__future_base::_Result_base::_Deleter>, std::__future_base::_Task_state<PTL::TaskGroup<void, void>::exec<G4TaskRunManager::AddEventTask(G4int)::<lambda()> >(G4TaskRunManager::AddEventTask(G4int)::<lambda()>)::<lambda()>, std::allocator<int>, void()>::_M_run()::<lambda()>, void> >::_M_invoke(const std::_Any_data &) (__functor=...) at /usr/include/c++/11/bits/std_function.h:291
#19 0x0000155554dbec3d in std::function<std::unique_ptr<std::__future_base::_Result_base, std::__future_base::_Result_base::_Deleter> ()>::operator()() const (
this=<optimized out>) at /usr/include/c++/11/bits/std_function.h:590
#20 std::__future_base::_State_baseV2::_M_do_set(std::function<std::unique_ptr<std::__future_base::_Result_base, std::__future_base::_Result_base::_Deleter> ()>*, bool*) (this=0x55557cfb67c0, __f=<optimized out>, __did_set=0x15554caaa48f) at /usr/include/c++/11/future:571
#21 0x0000155551899ee8 in __pthread_once_slow (once_control=0x55557cfb67d8, init_routine=0x155551cdad50 <__once_proxy>) at ./nptl/pthread_once.c:116
#22 0x0000155554dbed97 in __gthread_once (__func=<optimized out>, __once=0x55557cfb67d8) at /usr/include/x86_64-linux-gnu/c++/11/bits/gthr-default.h:700
#23 std::call_once<void (std::__future_base::_State_baseV2::*)(std::function<std::unique_ptr<std::__future_base::_Result_base, std::__future_base::_Result_base::_Deleter> ()>*, bool*), std::__future_base::_State_baseV2*, std::function<std::unique_ptr<std::__future_base::_Result_base, std::__future_base::_Result_base::_Deleter> ()>*, bool*>(std::once_flag&, void (std::__future_base::_State_baseV2::*&&)(std::function<std::unique_ptr<std::__future_base::_Result_base, std::__future_base::_Result_base::_Deleter> ()>*, bool*), std::__future_base::_State_baseV2*&&, std::function<std::unique_ptr<std::__future_base::_Result_base, std::__future_base::_Result_base::_Deleter> ()>*&&, bool*&&) (
__f=@0x15554caaa4b0: (void (std::__future_base::_State_baseV2::*)(std::__future_base::_State_baseV2 * const, std::function<std::unique_ptr<std::__future_base::_Result_base, std::__future_base::_Result_base::_Deleter>()> *, bool *)) 0x155554dbec10 <std::__future_base::_State_baseV2::_M_do_set(std::function<std::unique_ptr<std::__future_base::_Result_base, std::__future_base::_Result_base::_Deleter> ()>*, bool*)>, __once=...) at /usr/include/c++/11/mutex:783
#24 std::__future_base::_State_baseV2::_M_set_result(std::function<std::unique_ptr<std::__future_base::_Result_base, std::__future_base::_Result_base::_Deleter> ()>, bool) (__ignore_failure=false, __res=..., this=0x55557cfb67c0) at /usr/include/c++/11/future:411
#25 std::__future_base::_Task_state<PTL::TaskGroup<void, void>::exec<G4TaskRunManager::AddEventTask(G4int)::<lambda()> >(G4TaskRunManager::AddEventTask(G4int)::<lambda()>)::<lambda()>, std::allocator<int>, void()>::_M_run (this=0x55557cfb67c0) at /usr/include/c++/11/future:1471
#26 std::packaged_task<void ()>::operator()() (this=<optimized out>) at /usr/include/c++/11/future:1604
#27 PTL::mpl::impl::apply<std::packaged_task<void()>, std::tuple<> > (_args=..., _func=...)
at /home/augusto/Scrivania/Geant4/geant4-v11.0.2/source/externals/ptl/include/PTL/Globals.hh:173
#28 PTL::mpl::apply<std::packaged_task<void()>, std::tuple<> > (_args=..., _func=...)
at /home/augusto/Scrivania/Geant4/geant4-v11.0.2/source/externals/ptl/include/PTL/Globals.hh:200
#29 PTL::Task<void>::operator() (this=<optimized out>) at /home/augusto/Scrivania/Geant4/geant4-v11.0.2/source/externals/ptl/include/PTL/Task.hh:169
#30 0x0000155554b85118 in PTL::ThreadPool::execute_thread (this=0x55555597ab30, _task_queue=0x555555cf2d60)
at /home/augusto/Scrivania/Geant4/geant4-v11.0.2/source/externals/ptl/src/ThreadPool.cc:700
#31 0x0000155554b85595 in PTL::ThreadPool::start_thread (tp=0x55555597ab30, _data=0x55555597acb8, _idx=2)
at /home/augusto/Scrivania/Geant4/geant4-v11.0.2/source/externals/ptl/src/ThreadPool.cc:87
#32 0x0000155551cdc253 in ?? () from /lib/x86_64-linux-gnu/libstdc++.so.6
#33 0x0000155551894ac3 in start_thread (arg=<optimized out>) at ./nptl/pthread_create.c:442
#34 0x0000155551926850 in clone3 () at ../sysdeps/unix/sysv/linux/x86_64/clone3.S:81
(gdb) continue
Continuing.
### CAUGHT SIGNAL: 11 ### address: 0x128, signal = SIGSEGV, value = 11, description = segmentation violation. Address not mapped to object.
Backtrace:
[PID=3445500, TID=1][ 0/16]> /home/augusto/Scrivania/Geant4/G4work/CAVE_HIT_Dec/INCL2/exampleED(+0x1eda8) [0x555555572da8]
[PID=3445500, TID=1][ 1/16]> /home/augusto/Scrivania/Geant4/geant4-v11.0.2-install/lib/libG4tracking.so(_ZN17G4SteppingManager8SteppingEv+0x1f3) [0x155551fd21c3]
[PID=3445500, TID=1][ 2/16]> /home/augusto/Scrivania/Geant4/geant4-v11.0.2-install/lib/libG4tracking.so(_ZN17G4TrackingManager15ProcessOneTrackEP7G4Track+0x118) [0x155551fe8518]
[PID=3445500, TID=1][ 3/16]> /home/augusto/Scrivania/Geant4/geant4-v11.0.2-install/lib/libG4event.so(_ZN14G4EventManager12DoProcessingEP7G4Event+0x89b) [0x155554c3238b]
[PID=3445500, TID=1][ 4/16]> /home/augusto/Scrivania/Geant4/geant4-v11.0.2-install/lib/libG4tasking.so(_ZN22G4WorkerTaskRunManager15ProcessOneEventEi+0x3c) [0x155554dc8a5c]
[PID=3445500, TID=1][ 5/16]> /home/augusto/Scrivania/Geant4/geant4-v11.0.2-install/lib/libG4tasking.so(_ZN22G4WorkerTaskRunManager11DoEventLoopEiPKci+0x176) [0x155554dc8766]
[PID=3445500, TID=1][ 6/16]> /home/augusto/Scrivania/Geant4/geant4-v11.0.2-install/lib/libG4tasking.so(_ZN22G4WorkerTaskRunManager6DoWorkEv+0x126) [0x155554dc8916]
[PID=3445500, TID=1][ 7/16]> /home/augusto/Scrivania/Geant4/geant4-v11.0.2-install/lib/libG4tasking.so(+0x3c732) [0x155554dba732]
[PID=3445500, TID=1][ 8/16]> /home/augusto/Scrivania/Geant4/geant4-v11.0.2-install/lib/libG4tasking.so(_ZNSt13__future_base13_State_baseV29_M_do_setEPSt8functionIFSt10unique_ptrINS_12_Result_baseENS3_8_DeleterEEvEEPb+0x2d) [0x155554dbec3d]
[PID=3445500, TID=1][ 9/16]> /lib/x86_64-linux-gnu/libc.so.6(+0x99ee8) [0x155551899ee8]
[PID=3445500, TID=1][10/16]> /home/augusto/Scrivania/Geant4/geant4-v11.0.2-install/lib/libG4tasking.so(_ZN3PTL4TaskIvJEEclEv+0x107) [0x155554dbed97]
[PID=3445500, TID=1][11/16]> /home/augusto/Scrivania/Geant4/geant4-v11.0.2-install/lib/libG4ptl.so.0(_ZN3PTL10ThreadPool14execute_threadEPNS_14VUserTaskQueueE+0x398) [0x155554b85118]
[PID=3445500, TID=1][12/16]> /home/augusto/Scrivania/Geant4/geant4-v11.0.2-install/lib/libG4ptl.so.0(_ZN3PTL10ThreadPool12start_threadEPS0_PSt6vectorISt10shared_ptrINS_10ThreadDataEESaIS5_EEl+0x215) [0x155554b85595]
[PID=3445500, TID=1][13/16]> /lib/x86_64-linux-gnu/libstdc++.so.6(+0xdc253) [0x155551cdc253]
[PID=3445500, TID=1][14/16]> /lib/x86_64-linux-gnu/libc.so.6(+0x94ac3) [0x155551894ac3]
[PID=3445500, TID=1][15/16]> /lib/x86_64-linux-gnu/libc.so.6(+0x126850) [0x155551926850]
: Segmentation fault (Address not mapped to object [0x128])
Thread 3 "exampleED" received signal SIGABRT, Aborted.
__pthread_kill_implementation (no_tid=0, signo=6, threadid=23456103781952) at ./nptl/pthread_kill.c:44
44 ./nptl/pthread_kill.c: File o directory non esistente.
Can you figure out where the problem is coming from?
If you need further information or action from me, I am at your disposal.
BR
ADC
