Hello everyone,
I am getting this long but harmless error from an edited version of the Geant4GarfieldInterface after running and closing the UI session, it is quite long, so here is a snippet.:
Exception: [code: system:22] caught: mutex lock failed: Invalid argument
Non-critical error: mutex lock failure in ~G4Cache<P15G4HadFinalState>.
If the RunManagerKernel has been deleted, it failed to delete an allocated resource
and this destructor is being called after the statics were destroyed.
I am getting the same error when running the original example as well. The output is perfectly fine, and the root file and results look decent. I want that error to go away since it is hard to track things well.
I am unsure if anyone has experienced something like this, I’d appreciate the help.
Hello, thank you for the assistance.
I think the first one includes issues with the Shielding physics list and multithreading.
The second one suggests not deleting runMangaer in main(), I tried that but I am still getting this error. Please if you have any additional suggestions that I can try that would be great
My workaround has been to not delete the runManager at the very end of main(). This means not using an auto-pointer for the run manager (as is the current practice in most example applications).
I am not using any auto_ptr in the main() and I am more or less using an example code as well. So the main look identical to the other examples with the Garfield integration. I tried commenting out the delete runManager line at the end but I am still getting the error with the additional errors now:
WARNING - Attempt to delete the assembly store while geometry closed !
WARNING - Attempt to delete the physical volume store while geometry closed !
WARNING - Attempt to delete the logical volume store while geometry closed !
WARNING - Attempt to delete the solid store while geometry closed !
WARNING - Attempt to delete the region store while geometry closed !
I am not sure if that was the exact suggestion or if there was something I missed.
Thank you either way.
