Running rdecay02, no run1.mac included
Please fill out the following information to help in answering your question, and also see tips for posting code snippets
_Geant4 Version:_geant4-10-07-patch-01 (5-February-2021)
_Operating System:_Linux Mint
_Compiler/Version:_cmake version 3.22.0-rc1
I am attempting to run the rdecay02 example exactly how it is provided with the code. I have followed the process in the manual for building the executable:
$ cd $HOME
$ mkdir rdecay02-build
$ cd $HOME/rdecay02-build
$ cmake -DCMAKE_PREFIX_PATH=$HOME/geant4/geant4.10.07.p01-install path/to/rdecay02
$ make -j1
but there is no run1.mac provided to then run the code in batch mode:
$ ./rdecay02 run1.mac
in the example folder in the source code there is also no run1.mac file provided.
Thanks,
Emma
you are right, the mentioned file is not there (at least in the github repo). You can alternatively test with
./rdecay02 debug.mac
or start interactively
./rdecay02
and then try the macros in the subfolder macros from the command line:
/control/execute macros/<...>
// or
/control/macroPath macros
/control/execute <...>
where you replace <..> with one of the macros in
