Runtime issues while making examples due to issues with CommandLineTools SDKs
Geant4 Version: 11.2.2
Operating System: MacOS Sequia 15.1
Compiler/Version: Apple clang version 16.0.0 (clang-1600.0.26.3)
CMake Version: cmake version 3.30.5
CMake Error in CMakeLists.txt:
Imported target “Geant4::G4Tree” includes non-existent path
"/Library/Developer/CommandLineTools/SDKs/MacOSX15.0.sdk/usr/include"
in its INTERFACE_INCLUDE_DIRECTORIES. Possible reasons include:
  • The path was deleted, renamed, or moved to another location.
  • An install or uninstall procedure did not complete successfully.
  • The installation package was faulty and references files it does not
    provide.
    provide.
– Generating done (0.0s)
CMake Generate step failed. Build files cannot be regenerated correctly.
Last login: Tue Dec  3 23:05:50 on ttys001
kavyawadhwa@KAVYAs-MacBook-Air build % cmake ..
-- The C compiler identification is AppleClang 16.0.0.16000026
-- The CXX compiler identification is AppleClang 16.0.0.16000026
-- Check for working C compiler: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cc - skipped
-- Check for working CXX compiler: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ - skipped
-- Found EXPAT: /Library/Developer/CommandLineTools/SDKs/MacOSX15.0.sdk/usr/lib/libexpat.tbd (Required is at least version "2.6.1")
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD - Success
-- Found Threads: TRUE
-- Found XercesC: /opt/homebrew/lib/libxerces-c.dylib (found suitable version "3.3.0", minimum required is "3.3.0")
-- Found X11: /usr/X11R6/include
-- Looking for XOpenDisplay in /usr/X11R6/lib/libX11.dylib;/usr/X11R6/lib/libXext.dylib
-- Looking for XOpenDisplay in /usr/X11R6/lib/libX11.dylib;/usr/X11R6/lib/libXext.dylib - found
-- Looking for gethostbyname
-- Looking for gethostbyname - found
-- Looking for connect
-- Looking for connect - found
-- Looking for remove
-- Looking for remove - found
-- Looking for shmat
-- Looking for shmat - found
-- Looking for IceConnectionNumber in ICE
-- Looking for IceConnectionNumber in ICE - found
-- Found OpenGL: /Library/Developer/CommandLineTools/SDKs/MacOSX15.0.sdk/System/Library/Frameworks/OpenGL.framework
-- Found Geant4: /usr/local/Geant4/lib/cmake/Geant4/Geant4Config.cmake (found version "11.2.2")
-- Configuring done (2.3s)
  Imported target "Geant4::G4Tree" includes non-existent path
  * The path was deleted, renamed, or moved to another location.
  * An install or uninstall procedure did not complete successfully.
  * The installation package was faulty and references files it does not
  provide.
  provide.
-- Generating done (0.0s)
I think this almost certainly due to a system update that has invalidated the Geant4PackageCache.cmake file installed with Geant4. This should be present at
/usr/local/Geant4/lib/cmake/Geant4/Geant4PackageCache.cmake
and can be safely removed. The example should then configure fine.
