Hello;
I’m a beginner
I deleted it many times and installed it again but it always gives the same error. Please can you help?Scene tree empty and and I can’t see the image
this is output
Geant4 version Name: geant4-10-06-patch-01 (14-February-2020)
: IEEE-TNS 53 (2006), 270-278
: NIM A 835 (2016), 186-225
WWW : http://geant4.org/
Registering graphics systems…
Current available graphics systems are:
ASCIITree (ATree)
DAWNFILE (DAWNFILE)
G4HepRep (HepRepXML)
G4HepRepFile (HepRepFile)
RayTracer (RayTracer)
VRML1FILE (VRML1FILE)
VRML2FILE (VRML2FILE)
gMocrenFile (gMocrenFile)
OpenGLImmediateX (OGLIX, OGLIQt_FALLBACK)
OpenGLStoredX (OGLSX, OGLSQt_FALLBACK)
Registering model factories…
Registered model factories:
generic
drawByAttribute
drawByCharge
drawByOriginVolume
drawByParticleID
drawByEncounteredVolume
Registered filter factories:
attributeFilter
chargeFilter
originVolumeFilter
particleFilter
encounteredVolumeFilter
“/vis/list” to see available colours.
parameter out of range: switch >= 0 && switch <=2
***** Illegal parameter (99) </control/verbose 2> *****
*** G4Exception : UIMAN0123
Command aborted (399)
Error code : 399
Error code : 399
Error code : 399
