Dear Rooters,
I am quite puzzle about the scintillation process handling. I am re-using an old code that handled scintillator light generation in the old way (with G4OpticalPhysics::Configure in the main file). So I had to make a few adjustments to match the current version of geant4. It runs well and makes sense. However, I am unable to generate scintillation light. I check the amount of scintillated photons via (I know it’s not optimal but it should give the results) :
G4bool scintSD::ProcessHits(G4Step*aStep, G4TouchableHistory* /*ROhist*/)
// Check for secondary photons
auto secondaries = aStep->GetSecondary();
for (auto const & secondary : *secondaries)
G4double secondaryEnergy = secondary->GetKineticEnergy();
G4cout << secondary->GetParticleDefinition()->GetParticleName() << " with energy = " << G4BestUnit(secondaryEnergy, "Energy") << G4endl;
if (secondary->GetParticleDefinition() == G4OpticalPhoton::OpticalPhotonDefinition()){
G4cout << "Optical photon generated with energy: " << G4BestUnit(secondaryEnergy, "Energy") << G4endl;
And I get no optical photons. I get the secondary electrons all right though, so I suppose I should see the photons if they were produced right ?
So, now how I implemented it :
in main.cc :
G4OpticalPhysics* opticalPhysics = new G4OpticalPhysics();
physList -> RegisterPhysics(opticalPhysics);
in detectorConstructor.cc:
G4bool scintSD::ProcessHits(G4Step* aStep, G4TouchableHistory* /*ROhist*/)
G4Material* CeBr3 = new G4Material("CeBr_3", 5.2*g/cm3, 2);
CeBr3 -> AddElement(Ce, nAtoms=1);
CeBr3 -> AddElement(Br, nAtoms=3);
// Properties definition :
G4double optScintSpectrum[optN] = {5./9., 4./9.};
G4double optScintIndex[optN] = {1.9, 1.9};
G4double optScintAbs[optN] = {500.*cm, 500.*cm};
G4double optQuartzIndex[optN] = {1.47, 1.47};
G4double optBorosilIndex[optN] = {1.55, 1.55};
// Add properties
CeBr3MPT->AddProperty("FASTCOMPONENT", optEmission, optScintSpectrum, optN, true);
CeBr3MPT->AddProperty("RINDEX", optEmission, optScintIndex, optN, true);
CeBr3MPT->AddProperty("ABSLENGTH", optEmission, optScintAbs, optN, true);
// Add constant properties
CeBr3MPT->AddConstProperty("SCINTILLATIONYIELD", 60./keV, true); // or 45
CeBr3MPT->AddConstProperty("YIELDRATIO", 1., true);
CeBr3MPT->AddConstProperty("FASTTIMECONSTANT", 18.*ns, true);
CeBr3MPT->AddConstProperty("RESOLUTIONSCALE", 1., true);
// Set the material properties table for CeBr3
CeBr3->SetMaterialPropertiesTable(CeBr3MPT);
So I just put the crucial parts that I think might cause the issue. Tell me if you have a hint of where it might come from !
Sincerely,
Corentin
Geant4 Version: 11.3.0
Operating System: Linux/Debian (WSL2)
Compiler/Version: g++ (Debian 12.2.0-14) 12.2.0
CMake Version: 3.25.1
