_Geant4 Version:_11.3.2
_Operating System:_Windows
_Compiler/Version:_mingw32_gcc 6.3.0
_CMake Version:_3.16
Goodmorning everyone. I’m new in Geant4 simulation and I’m trying to simulate the response of a liquid scintillator in a small cylinder hit by gammas. The geometry should be an aluminum box with inside the cylinder of liquid scintillator and two PMTs for the readout.
Unfortunately I can’t see any scintillation light (any optical photon) originated from the scintillation and I think that neither the scintillation nor any interaction between the gammas and the scintillation happen.
I have defined the physics as follows:
#include "PhysicsList.hh"
#include "G4EmStandardPhysics.hh"
#include "G4DecayPhysics.hh"
#include "G4OpticalPhysics.hh"
#include "G4EmExtraPhysics.hh"
#include "G4EmParameters.hh"
#include "G4EmStandardPhysics_option4.hh"
#include "G4SystemOfUnits.hh"
#include "G4ProcessManager.hh"
#include "G4ProcessVector.hh"
#include "G4OpticalParameters.hh"
#include "G4OpticalPhoton.hh"
#include "G4ComptonScattering.hh"
#include "G4PhotoElectricEffect.hh"
#include "G4Gamma.hh"
#include "G4Electron.hh"
#include "G4Positron.hh"
PhysicsList::PhysicsList()
// 1. Fisica di base
RegisterPhysics(new G4DecayPhysics());
//______________________________________
// 2. Fisica elettromagnetica standard
RegisterPhysics(new G4EmStandardPhysics());
RegisterPhysics(new G4EmStandardPhysics_option4()); // Fisica EM avanzata
// 3. Altra fisica
RegisterPhysics(new G4EmExtraPhysics());
// 4. Fisica ottica
auto opticalPhysics = new G4OpticalPhysics();
auto opticalParams = G4OpticalParameters::Instance();
// Scintillazione
opticalParams->SetScintTrackSecondariesFirst(true);
opticalParams->SetScintStackPhotons(true);
opticalParams->SetScintByParticleType(true);
opticalParams->SetProcessActivation("Scintillation", true);
opticalParams->SetProcessActivation("Cerenkov", false);
opticalParams->SetProcessActivation("OpAbsorption", true);
opticalParams->SetProcessActivation("OpBoundary", true);
opticalParams->SetProcessActivation("OpRayleigh", true);
opticalParams->SetProcessActivation("OpWLS", false);
opticalParams->SetVerboseLevel(2); // Debug
RegisterPhysics(opticalPhysics);}
PhysicsList::~PhysicsList() {}
void PhysicsList::ConstructParticle()
// Costruisci particelle standard (inclusi i gamma)
G4Gamma::GammaDefinition();
G4OpticalPhoton::OpticalPhotonDefinition();
G4VModularPhysicsList::ConstructParticle();
void PhysicsList::ConstructProcess()
// processi base
G4VModularPhysicsList::ConstructProcess();
//processi per i gamma
G4ProcessManager* pManager = G4Gamma::Gamma()->GetProcessManager();
if (!pManager) {
G4Exception("PhysicsList::ConstructProcess()", "Run0110", FatalException,
"Process manager per gamma non trovato!");
return;
// tutti i processi registrati
G4cout << "\n=== DEBUG: Processi registrati per gamma ===" << G4endl;
G4ProcessVector* procs = pManager->GetProcessList();
for(size_t i=0; i<procs->size(); ++i) {
G4cout << "- " << (*procs)[i]->GetProcessName() << G4endl;
// Compton scattering
if(!pManager->GetProcess("compt")) {
pManager->AddDiscreteProcess(new G4ComptonScattering());
G4cout << "Aggiunto processo: compton" << G4endl;
// effetto fotoelettrico
if(!pManager->GetProcess("phot")) {
pManager->AddDiscreteProcess(new G4PhotoElectricEffect());
G4cout << "Aggiunto processo: photoelectric" << G4endl;
void PhysicsList::SetCuts()
// Tagli di default
// SetCutValue(0.1 * mm, "gamma");
SetCutValue(0.1 * mm, "e-");
SetCutValue(0.1 * mm, "e+");
// SetCutValue(0.01 * mm, "opticalphoton");
I have also defined the optical properties of the liquid scintillator as follows:
const G4int num = 7;
G4double energies[num] = {1.55*eV, 2.07*eV, 2.48*eV, 2.76*eV, 3.10*eV, 3.54*eV, 4.13*eV};
// Proprietà scintillatore liquido
G4double rIndexScint[num] = {1.48, 1.50, 1.52, 1.53, 1.54, 1.56, 1.58};
G4double absLengthScint[num] = {5.*m, 6.*m, 7.*m, 8.*m, 7.*m, 6.*m, 5.*m};
G4double scintFast[num] = {0.0, 0.2, 0.8, 1.0, 0.7, 0.3, 0.0};
G4double scintSlow[num] = {0.0, 0.2, 0.8, 1.0, 0.7, 0.3, 0.0};
G4MaterialPropertiesTable* scintMPT = new G4MaterialPropertiesTable();
scintMPT->AddProperty("RINDEX", energies, rIndexScint, num);
scintMPT->AddProperty("ABSLENGTH", energies, absLengthScint, num);
scintMPT->AddProperty("FASTCOMPONENT", energies, scintFast, num, true);
scintMPT->AddProperty("SLOWCOMPONENT", energies, scintSlow, num, true);
scintMPT->AddConstProperty("SCINTILLATIONYIELD", 20000./MeV);
scintMPT->AddConstProperty("RESOLUTIONSCALE", 1.0);
scintMPT->AddConstProperty("FASTTIMECONSTANT", 8.*ns, true);
scintMPT->AddConstProperty("SLOWTIMECONSTANT", 20.*ns, true);
scintMPT->AddConstProperty("YIELDRATIO", 0.8, true);
liquidScint->GetIonisation()->SetBirksConstant(0.05*mm/MeV);
liquidScint->SetMaterialPropertiesTable(scintMPT);
Still I can’t see any scinitillation light
The particle source is set in the origin (0, 0, 0) and the center of the cylinder is set in (0, 0, 293.5 cm)
Does anybody know how to solve this problem? Is there something I’m missing in the physics and/or in the optical properties part? Or maybe the problem is somewhere else? Thank you in advance!
