I am using a G4Wrapper to bias the secondaries (direction and number). In the overridden AtRestDoIt I call the pRegProcess-> AtRestDoIt and receive the below output for some decays. Many decays work perfectly fine.
G4WT1 > G4VParticleChange::CheckSecondary :
G4WT1 > The global time of secondary goes back compared to the parent !!
G4WT1 > ParentTime(ns)=3.5172e+16 SecondaryTime(ns)= 4.01313e+14 Difference(ns)=3.47707e+16
G4WT1 > Ekin(MeV)=9.63804e-06Zr90[2319.000] created by model_RDM_IT
G4WT1 > -----------------------------------------------
G4WT1 > G4VParticleChange Information
G4WT1 > TrackID : 135
G4WT1 > ParentID : 51
G4WT1 > Particle : e-
G4WT1 > Kinetic energy (MeV): 0.0021923056
G4WT1 > Position (mm) : (1.0334841e-311,371.31385,136.82683)
G4WT1 > Direction : (0.347514,-0.48819155,-0.80056419)
G4WT1 > PhysicsVolume : PV-LV_innerbox
In these instances I never make it past my call the the pRegProcess->AtRestDoIt so that code is
likely irrelevant to this issue.
Doing a stack trace I end up the DecayIt with a Mean lifetime of: 188.99310000000000 and a globalTime for the track as 401312856727909.75.Which doesn’t seem to match the error.
This error doesn’t appear if I turn off the G4Wrapper around RadioaciveDecay Physics.
Using break points, it looks like G4Wrapper or my RadioacitveDecayWrapper is not thread safe.
I added some G4out lines to output so I can get the info right before G4RadioactiveDecay takes over:
G4WT4 > globalTime: 0.805504
G4WT4 > Dy particle: Pt181
G4WT4 > Track ID: 31
G4WT4 > Parent Id: 1
G4WT4 >
G4WT4 > globalTime: 1.16208e+10
G4WT4 > Dy particle: Ir181[1680.760]
G4WT4 > Track ID: 32
G4WT4 > Parent Id: 31
G4WT4 >
G4WT4 > Track ID: 361
G4WT4 > Parent Id: 32
G4WT4 >
G4WT4 > globalTime: 3.93938e+11
G4WT4 > Dy particle: Os181
G4WT4 > Track ID: 1787
G4WT4 > Parent Id: 361
G4WT4 >
G4WT2 > globalTime: 1.69613
G4WT2 > Dy particle: Au187
G4WT2 > Track ID: 40
G4WT2 > Parent Id: 1
G4WT2 >
G4WT4 > globalTime: 1.98084e+12
G4WT4 > Dy particle: Re181[432.430]
G4WT4 > Track ID: 2044
G4WT4 > Parent Id: 1787
G4WT4 >
G4WT0 > globalTime: 0.158701
G4WT0 > Dy particle: Pt177
G4WT0 > Track ID: 32
G4WT0 > Parent Id: 1
G4WT0 >
G4WT2 > G4VParticleChange::CheckSecondary :
G4WT2 > The global time of secondary goes back compared to the parent !!
G4WT2 > ParentTime(ns)=0.158701 SecondaryTime(ns)= 4.54839e+11 Difference(ns)=-4.54839e+11
G4WT2 > Ekin(MeV)=0.101763Ir183 created by model_RDM_Alpha
G4WT2 > -----------------------------------------------
G4WT2 > G4VParticleChange Information
G4WT2 > TrackID : 32
G4WT2 > ParentID : 1
G4WT2 > Particle : Pt177
G4WT2 > Kinetic energy (MeV): 0
G4WT2 > Position (mm) : (-10.297004,-3.9912292,-34.6215)
G4WT2 > Direction : (0.33584882,-0.45288854,-0.82589197)
G4WT2 > PhysicsVolume : PV-LV_innerbox
G4WT2 > Material : Average_SV_int
G4WT2 > # of secondaries : 0
G4WT2 > Energy Deposit (MeV): 0
G4WT2 > NIEL Energy Deposit (MeV): 0
G4WT2 > Track Status : StopButAlive
G4WT2 > TruePathLength (mm) : 0
G4WT2 > Stepping Control : 0
G4WT2 > First step in volume
G4WT2 > G4ParticleChangeForDecay proposes:
G4WT2 > Proposed local Time (ns): 0.011576413
G4WT2 > Initial local Time (ns) : 0.011576413
G4WT2 > Initial global Time (ns): 0.15870094
G4WT2 > Current global Time (ns): 0.15870094
G4WT2 >
*** G4Exception : TRACK001
issued by : G4VParticleChange::CheckSecondary()
Secondary with illegal time and/or energy and/or momentum
G4WT2 > globalTime: 0.159008
G4WT2 > Dy particle: Ir183
G4WT2 > Track ID: 41
G4WT2 > Parent Id: 40
G4WT4 >
G4WT4 > Dy particle: Re181[356.720]
G4WT4 > Track ID: 2362
G4WT4 > Parent Id: 2044
G4WT4 >
G4WT0 > G4VParticleChange::CheckSecondary :
G4WT0 > The global time of secondary goes back compared to the parent !!
G4WT0 > ParentTime(ns)=1.98084e+12 SecondaryTime(ns)= 8.83298e+09 Difference(ns)=1.97201e+12
G4WT0 > Ekin(MeV)=4.46861e-05Ir177 created by model_RDM_BetaPlus
G4WT0 > -----------------------------------------------
G4WT0 > G4VParticleChange Information
G4WT0 > TrackID : 2362
G4WT0 > ParentID : 2044
G4WT0 > Particle : Re181[356.720]
G4WT0 > Kinetic energy (MeV): 0
G4WT0 > Position (mm) : (142.37867,116.7671,-28.453447)
G4WT0 > Direction : (0.52273975,-0.80202952,-0.28894948)
G4WT0 > PhysicsVolume : PV-LV_innerbox
G4WT0 > Material : Average_SV_int
G4WT0 > # of secondaries : 0
G4WT0 > Energy Deposit (MeV): 0
G4WT0 > NIEL Energy Deposit (MeV): 0
G4WT0 > Track Status : StopButAlive
G4WT0 > TruePathLength (mm) : 0
G4WT0 > Stepping Control : 0
G4WT0 > First step in volume
G4WT0 > G4ParticleChangeForDecay proposes:
G4WT0 > Proposed local Time (ns): 0.013354366
G4WT0 > Initial local Time (ns) : 0.013354366
G4WT0 > Initial global Time (ns): 1.9808403e+12
G4WT0 > Current global Time (ns): 1.9808403e+12
G4WT0 >
Looking at the output from the wrapper the globalTime is 0.158701 and the dynamic particle is Pt-177. When G4RadioactiveDecay gets ahold of the track it is all messed up. It’s getting the correct track (ID: 32) but it’s on the wrong thread. The timing makes sense but not why it’s throwing an error. With break points we can look at the data in the track 32:
Initial Global time: 0.158701 (parentTime)
final Global time: 8.8329e+09 (secondaryTime)
Parent Track ID: 1
If we continue on, we can see Re181[356.720] is also on the wrong thread, and that it has the secondaryTime from the traced Pt-177 (8.8329e+09). I’ve also included the entire decay chain for the Re181[356.720] starting at the Pt-181 output from the wrapper.
The final global time/secondary time is being attributed to the incorrect track on the wrong thread. In some runs I even receive a segfault, as it tries to add a secondary to a particleChange object on another thread.
It was my understating per this page that each thread handles an entire event.
Final update and solved. The issue arose in the physicsList where I construct the RadioactiveDecayWrapper:
I created the member variable RadioactiveDecayWrapper* decayWrap in my header, then built in my constructor. This made one decayWrap for all the threads and it wasn’t thread safe.
The fix was to create a local variable in the WrapRadioactiveDecay() function (see below).
There were some code refactoring required such as passing in the needed parameters into the constructor of the RadioactiveDecayWrapper but it works now.
