I’m trying to run a piece of code with multithreading which executes fine if I do not enable multithreading. As the code in question is a bit too big and convovluted to paste…I’ll try to paste a “light version” of what I’m doing (i hope it helps).
In my ActionInitialization.cc script I have a Build() and BuildForMaster() as shown below
void ActionInitialization::Build() const {
//primary generator action
SetUserAction(fPrimaryGeneratorAction_);
//run action
RunAction* runAction = new RunAction(output_file_, fixed_filename_);
SetUserAction(runAction);
//event action
EventAction* eventAction = new EventAction();
SetUserAction(eventAction);
// prepare file
G4AnalysisManager* fAnalysisManager = G4AnalysisManager::Instance();
if (G4RunManager::GetRunManager()->GetRunManagerType() == G4RunManager::RMType::sequentialRM) {
fAnalysisManager->CreateNtuple("Keyword", "Keyword");
fAnalysisManager->CreateNtupleIColumn("RunID"); // 0
fAnalysisManager->CreateNtupleIColumn("NumberOfEvents"); // 1
and
void ActionInitialization::BuildForMaster() const {
SetUserAction(new RunAction(output_file_, fixed_filename_));
fAnalysisManager->SetNtupleMerging(true);
In my Run.cc I fill the tuples (no issues there). So I assume that each local thread is doing what it’s supposed to do. I also see their respective files in the local directory. However, when I try to fill the tuples in the master thread (through the “IsMaster()” boolean) I get the following warning
*** G4Exception : Analysis_W011
issued by : G4TNtupleManager::FillNtupleTColumn
ntupleId 1 does not exist.
This is very odd because I’m “pretty sure” It was created on the same thread. Or did I misunderstand something?
Furthermore, after completing the runs, the the merging process crashes and I do not know how to resolve this. The error messages are
********************* End Simulation *********************
G4WT0 > Destroying WorkerRunManager (0x7f6478046f60)
G4WT0 > G4 kernel has come to Quit state.
G4WT2 > Destroying WorkerRunManager (0x7f6474046f60)
G4WT2 > G4 kernel has come to Quit state.
G4WT3 > Destroying WorkerRunManager (0x7f6468046f60)
G4WT3 > G4 kernel has come to Quit state.
G4WT0 > ================== Deleting memory pools ===================
G4WT0 > Number of memory pools allocated: 12; of which, static: 0
G4WT0 > Dynamic pools deleted: 12 / Total memory freed: 0.048 MB
G4WT0 > ============================================================
G4WT0 > Thread-local UImanager is to be deleted.
G4WT0 > There should not be any thread-local G4cout/G4cerr hereafter.
*** Break *** segmentation violation
G4WT1 > Destroying WorkerRunManager (0x7f6470046f60)
G4WT1 > G4 kernel has come to Quit state.
double free or corruption (fasttop)
There was a crash.
This is the entire stack trace of all threads:
Thread 4 (Thread 0x7f647e14a700 (LWP 882721)):
#0 0x00007f64825d8dff in __GI___wait4 (pid=882728, stat_loc=stat_loc
entry=0x7f647dfcbba8, options=options
entry=0, usage=usage
entry=0x0) at ../sysdeps/unix/sysv/linux/wait4.c:27
#1 0x00007f64825d8d7b in __GI___waitpid (pid=<optimized out>, stat_loc=stat_loc
entry=0) at waitpid.c:38
#2 0x00007f64825480e7 in do_system (line=<optimized out>) at ../sysdeps/posix/system.c:172
#3 0x00007f648b0f9b1e in TUnixSystem::StackTrace() () from /home/johannes/software/root_v6.20.04/root_install/lib/libCore.so
#4 0x00007f648b0f683c in TUnixSystem::DispatchSignals(ESignals) () from /home/johannes/software/root_v6.20.04/root_install/lib/libCore.so
#5 <signal handler called>
#6 0x0000000000004161 in ?? ()
#7 0x00007f6487ebf21d in G4RunManager::~G4RunManager() () from /home/johannes/software/geant4_v10.06/geant4_install/lib/libG4run.so
#8 0x00007f6487ec9b9d in G4WorkerRunManager::~G4WorkerRunManager() () from /home/johannes/software/geant4_v10.06/geant4_install/lib/libG4run.so
#9 0x00007f6487ed4ec9 in G4MTRunManagerKernel::StartThread(G4WorkerThread*) () from /home/johannes/software/geant4_v10.06/geant4_install/lib/libG4run.so
#10 0x00007f648294ad84 in ?? () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#11 0x00007f64826ee609 in start_thread (arg=<optimized out>) at pthread_create.c:477
#12 0x00007f6482615293 in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:95
Thread 3 (Thread 0x7f647e94b700 (LWP 882720)):
#0 0x00007f64825d8dff in __GI___wait4 (pid=882786, stat_loc=stat_loc
entry=0x7f647e7ccba8, options=options
Thread 2 (Thread 0x7f647f14c700 (LWP 882719)):
#0 0x00007f64825d8dff in __GI___wait4 (pid=882731, stat_loc=stat_loc
entry=0x7f647efcdba8, options=options
Thread 1 (Thread 0x7f647fbc3d00 (LWP 882680)):
#0 __pthread_clockjoin_ex (threadid=140069605525248, thread_return=0x0, clockid=<optimized out>, abstime=<optimized out>, block=<optimized out>) at pthread_join_common.c:145
#1 0x00007f648294afe7 in std::thread::join() () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#2 0x00007f6487ec4fd9 in G4MTRunManager::TerminateWorkers() () from /home/johannes/software/geant4_v10.06/geant4_install/lib/libG4run.so
#3 0x00007f6487ec508e in G4MTRunManager::~G4MTRunManager() () from /home/johannes/software/geant4_v10.06/geant4_install/lib/libG4run.so
#4 0x00007f6487ec51dd in G4MTRunManager::~G4MTRunManager() () from /home/johannes/software/geant4_v10.06/geant4_install/lib/libG4run.so
#5 0x0000561e78f7bea3 in main (argc=7, argv=0x7fffc9995858) at /home/johannes/Desktop/POLAR-02/Simulations/POLAR2sim/POLAR2sim.cc:151
The lines below might hint at the cause of the crash.
You may get help by asking at the ROOT forum http://root.cern.ch/forum
Only if you are really convinced it is a bug in ROOT then please submit a
report at http://root.cern.ch/bugs Please post the ENTIRE stack trace
from above as an attachment in addition to anything else
that might help us fixing this issue.
Aborted (core dumped)
Any ideas/tips that might have caused this?
Cheers,
Johan
