I have this problem that I don’t understand. In EndOfRunAction I want to print an hdf5 output by using the analsysis Manager. The lines of codes (simplified with respect the original version, in order to debug) are the following:
and I tried to use the GDB debug, getting the following message:
Thread 32 "essn" received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x7fff81ffb700 (LWP 1146001)]
0x000000000041ea2a in ESSNRunAction::EndOfRunAction(G4Run const*) ()
I tried to debug by decommenting different lines of the code and I started to get the error when I fill the column, by adding:
analysisManager->FillNtupleIColumn(0,1);
Any suggestion, please?
Thank you very much in advance for your time.
maybe analysisManager->OpenFile(); is also missing, or is that done automatically?
At least for csv, the ntuple files are being written as the simulation runs…
HDF5-DIAG: Error detected in HDF5 (1.12.0) thread 0:
#000: H5Gdeprec.c line 232 in H5Gcreate1(): unable to create group
major: Symbol table
minor: Unable to initialize object
#001: H5VLcallback.c line 4081 in H5VL_group_create(): group create failed
major: Virtual Object Layer
minor: Unable to create file
#002: H5VLcallback.c line 4047 in H5VL__group_create(): group create failed
#003: H5VLnative_group.c line 74 in H5VL__native_group_create(): unable to create group
major: Symbol table
#004: H5Gint.c line 158 in H5G__create_named(): unable to create and link to group
major: Symbol table
#005: H5L.c line 1804 in H5L_link_object(): unable to create new link to object
major: Links
#006: H5L.c line 2045 in H5L__create_real(): can't insert link
major: Links
minor: Unable to insert object
The output is print but without giving results to read. Using OpenFile(), in other positions gave segmentation fault error as before.
