EDIT: (I have updated the code for the physics list, but am still getting a segfault)
I am trying to enable alpha particles in the physics list in the example RMC01, but I am receiving a segmentation fault during the run. The primary error seems to be in “G4MaterialCutsCouple::GetMaterial()”. Any advice is greatly appreciated.
Here is the current report from gdb:
Thread 1 "ATOM" received signal SIGSEGV, Segmentation fault.
0x00007ffff58d21f8 in G4MaterialCutsCouple::GetMaterial() const ()
from /home/jordan/Documents/Geant4/geant4.10.6-build/BuildProducts/lib/libG4tracking.so
(gdb) where
#0 0x00007ffff58d21f8 in G4MaterialCutsCouple::GetMaterial() const ()
at /home/jordan/Documents/Geant4/geant4.10.6-build/BuildProducts/lib/libG4tracking.so
#1 0x00007ffff0e708cb in G4VEmAdjointModel::DefineCurrentMaterial(G4MaterialCutsCouple const*) ()
at /home/jordan/Documents/Geant4/geant4.10.6-build/BuildProducts/lib/libG4processes.so
#2 0x00007ffff0e6dea7 in G4VEmAdjointModel::AdjointCrossSection(G4MaterialCutsCouple const*, double, bool) ()
#3 0x00007ffff0e4f071 in G4AdjointCSManager::ComputeAdjointCS(G4Material*, G4VEmAdjointModel*, double, double, bool, std::vector<double, std::allocator<double> >&) ()
#4 0x00007ffff0e6df22 in G4VEmAdjointModel::AdjointCrossSection(G4MaterialCutsCouple const*, double, bool) ()
#5 0x00007ffff0e6dfbe in G4VEmAdjointModel::GetAdjointCrossSection(G4MaterialCutsCouple const*, double, bool) ()
Relevant bits of code:
if (fUse_gionisation) {
if (!fGIonisation) fGIonisation = new G4ionIonisation();
fGIonisation->SetLossFluctuations(fUse_egain_fluctuation);
theCSManager->RegisterAdjointParticle(
G4AdjointGenericIon::GenericIon());
G4AdjointAlpha::Alpha());
//Define adjoint ionisation for ions
G4AdjointIonIonisationModel* thegInverseIonisationModel = 0;
G4IonInverseIonisation* thegInverseIonisationProjToProjCase = 0 ;
G4IonInverseIonisation* thegInverseIonisationProdToProjCase = 0;
thegInverseIonisationModel = new G4AdjointIonIonisationModel();
thegInverseIonisationModel->SetHighEnergyLimit(fEmax_adj_models);
thegInverseIonisationModel->SetLowEnergyLimit(fEmin_adj_models);
thegInverseIonisationModel->SetUseMatrix(false);
thegInverseIonisationProjToProjCase = new G4IonInverseIonisation(true,
"Inv_gIon",thegInverseIonisationModel);
thegInverseIonisationProdToProjCase = new G4IonInverseIonisation(false,
"Inv_gIon1",thegInverseIonisationModel);
theAdjointSimManager->ConsiderParticleAsPrimary(G4String("ion"));
theAdjointSimManager->SetPrimaryIon(G4AdjointAlpha::Alpha(),G4Alpha::Alpha());
theCSManager->SetIon(G4AdjointAlpha::Alpha(),G4Alpha::Alpha());
thegInverseIonisationModel->SetIon(G4AdjointAlpha::Alpha(),G4Alpha::Alpha());
std::cout<<theAdjointSimManager->GetPrimaryIonName()<<std::endl;
if (particleName == "alpha" && fUse_gionisation) {
if (fUse_ms && fUse_gionisation) pmanager->AddProcess(thegMS);
if (fUse_gionisation){
pmanager->AddProcess(fGIonisation);
G4AdjointCSManager::GetAdjointCSManager()->
RegisterEnergyLossProcess(fGIonisation,particle);
G4int n_order=0;
if (fUse_ms && fUse_gionisation) {
n_order++;
pmanager->SetProcessOrdering(thegMS, idxAlongStep,n_order);
n_order++;
pmanager->SetProcessOrdering(fGIonisation,idxAlongStep,n_order);
n_order=0;
n_order++;
pmanager->SetProcessOrdering(thegMS, idxPostStep,n_order);
n_order++;
pmanager->SetProcessOrdering(fGIonisation,idxPostStep,n_order);
if (particleName == "adj_alpha" && fUse_gionisation) {
G4ContinuousGainOfEnergy* theContinuousGainOfEnergy =0;
if (fUse_gionisation ) {
theContinuousGainOfEnergy= new G4ContinuousGainOfEnergy();
theContinuousGainOfEnergy->SetLossFluctuations(
theContinuousGainOfEnergy->SetDirectEnergyLossProcess(fGIonisation);
theContinuousGainOfEnergy->SetDirectParticle(G4Alpha::Alpha());
pmanager->AddProcess(theContinuousGainOfEnergy);
G4int n_order=0;
if (fUse_ms) {
n_order++;
n_order++;
pmanager->SetProcessOrdering(theContinuousGainOfEnergy,idxAlongStep,
n_order);
n_order++;
G4AdjointAlongStepWeightCorrection* theAlongStepWeightCorrection =
new G4AdjointAlongStepWeightCorrection();
pmanager->AddProcess(theAlongStepWeightCorrection);
pmanager->SetProcessOrdering(theAlongStepWeightCorrection,
idxAlongStep,
n_order);
n_order=0;
pmanager->AddProcess(thegInverseIonisationProjToProjCase);
n_order++;
thegInverseIonisationProjToProjCase,
n_order++;
pmanager->SetProcessOrdering(thegMS,idxPostStep,n_order);
And here is the full code:
// * License and Disclaimer *
// * The Geant4 software is copyright of the Copyright Holders of *
// * the Geant4 Collaboration. It is provided under the terms and *
// * conditions of the Geant4 Software License, included in the file *
// * LICENSE and available at http://cern.ch/geant4/license . These *
// * include a list of copyright holders. *
// * Neither the authors of this software system, nor their employing *
// * institutes,nor the agencies providing financial support for this *
// * work make any representation or warranty, express or implied, *
// * regarding this software system or assume any liability for its *
// * use. Please see the license in the file LICENSE and URL above *
// * for the full disclaimer and the limitation of liability. *
// * This code implementation is the result of the scientific and *
// * technical work of the GEANT4 collaboration. *
// * By using, copying, modifying or distributing the software (or *
// * any work based on the software) you agree to acknowledge its *
// * use in resulting scientific publications, and indicate your *
// * acceptance of all terms of the Geant4 Software license. *
/// \file biasing/ReverseMC01/src/G4AdjointPhysicsList.cc
/// \brief Implementation of the G4AdjointPhysicsList class
// Class Name: G4AdjointPhysicsList
// Author: L. Desorgher
// Organisation: SpaceIT GmbH
// Contract: ESA contract 21435/08/NL/AT
// Customer: ESA/ESTEC
#include "G4AdjointPhysicsList.hh"
#include "G4ProcessManager.hh"
#include "G4ParticleTypes.hh"
#include "G4AdjointPhysicsMessenger.hh"
#include "G4SystemOfUnits.hh"
G4AdjointPhysicsList::G4AdjointPhysicsList()
:G4VUserPhysicsList(),
fEminusIonisation(0),fPIonisation(0),fGIonisation(0),
fUse_forced_interaction(true),
fUse_eionisation(true),fUse_pionisation(true),fUse_gionisation(true),
fUse_brem(true),fUse_compton(true),fUse_ms(true),
fUse_egain_fluctuation(true),fUse_peeffect(true),
fEmin_adj_models(1.*keV), fEmax_adj_models(1.*MeV),
fCS_biasing_factor_compton(1.),fCS_biasing_factor_brem(1.),
fCS_biasing_factor_ionisation(1.),fCS_biasing_factor_PEeffect(1.)
defaultCutValue = 1.0*mm;
SetVerboseLevel(1);
fPhysicsMessenger = new G4AdjointPhysicsMessenger(this);
G4AdjointPhysicsList::~G4AdjointPhysicsList()
void G4AdjointPhysicsList::ConstructParticle()
// In this method, static member functions should be called
// for all particles which you want to use.
// This ensures that objects of these particle types will be
// created in the program.
ConstructBosons();
ConstructLeptons();
ConstructMesons();
ConstructBaryons();
ConstructIons();
ConstructAdjointParticles();
void G4AdjointPhysicsList::SetLossFluctuationFlag(bool aBool)
if (fEminusIonisation) fEminusIonisation->SetLossFluctuations(aBool);
void G4AdjointPhysicsList::ConstructBosons()
// pseudo-particles
G4Geantino::GeantinoDefinition();
G4ChargedGeantino::ChargedGeantinoDefinition();
// gamma
G4Gamma::GammaDefinition();
// optical photon
G4OpticalPhoton::OpticalPhotonDefinition();
void G4AdjointPhysicsList::ConstructLeptons()
// leptons
G4Electron::ElectronDefinition();
G4Positron::PositronDefinition();
G4MuonPlus::MuonPlusDefinition();
G4MuonMinus::MuonMinusDefinition();
G4NeutrinoE::NeutrinoEDefinition();
G4AntiNeutrinoE::AntiNeutrinoEDefinition();
G4NeutrinoMu::NeutrinoMuDefinition();
G4AntiNeutrinoMu::AntiNeutrinoMuDefinition();
void G4AdjointPhysicsList::ConstructMesons()
// mesons
G4PionPlus::PionPlusDefinition();
G4PionMinus::PionMinusDefinition();
G4PionZero::PionZeroDefinition();
G4Eta::EtaDefinition();
G4EtaPrime::EtaPrimeDefinition();
G4KaonPlus::KaonPlusDefinition();
G4KaonMinus::KaonMinusDefinition();
G4KaonZero::KaonZeroDefinition();
G4AntiKaonZero::AntiKaonZeroDefinition();
G4KaonZeroLong::KaonZeroLongDefinition();
G4KaonZeroShort::KaonZeroShortDefinition();
void G4AdjointPhysicsList::ConstructBaryons()
// barions
G4Proton::ProtonDefinition();
G4AntiProton::AntiProtonDefinition();
G4Neutron::NeutronDefinition();
G4AntiNeutron::AntiNeutronDefinition();
#include "G4Alpha.hh"
#include "G4AntiAlpha.hh"
#include "G4GenericIon.hh"
void G4AdjointPhysicsList::ConstructIons()
// nuclei
G4Alpha::AlphaDefinition();
// anti_nuclei
G4AntiAlpha::AntiAlphaDefinition();
// generic ion
G4GenericIon::GenericIonDefinition();
#include"G4AdjointGamma.hh"
#include"G4AdjointElectron.hh"
#include"G4AdjointProton.hh"
#include"G4AdjointAlpha.hh"
#include"G4AdjointGenericIon.hh"
void G4AdjointPhysicsList::ConstructAdjointParticles()
// adjoint_gammma
G4AdjointGamma::AdjointGammaDefinition();
// adjoint_electron
G4AdjointElectron::AdjointElectronDefinition();
// adjoint_proton
G4AdjointProton::AdjointProtonDefinition();
void G4AdjointPhysicsList::ConstructProcess()
AddTransportation();
ConstructEM();
ConstructGeneral();
//#include "G4PEEffectFluoModel.hh"
#include "G4ComptonScattering.hh"
#include "G4GammaConversion.hh"
#include "G4PhotoElectricEffect.hh"
#include "G4eMultipleScattering.hh"
#include "G4eAdjointMultipleScattering.hh"
#include "G4hMultipleScattering.hh"
#include "G4eIonisation.hh"
#include "G4eBremsstrahlung.hh"
#include "G4eplusAnnihilation.hh"
#include "G4hIonisation.hh"
#include "G4ionIonisation.hh"
//#include "G4IonParametrisedLossModel.hh"
#include "G4ContinuousGainOfEnergy.hh"
#include "G4eInverseIonisation.hh"
#include "G4AdjointeIonisationModel.hh"
#include "G4AdjointCSManager.hh"
#include "G4AdjointBremsstrahlungModel.hh"
#include "G4eInverseBremsstrahlung.hh"
#include "G4AdjointComptonModel.hh"
#include "G4eInverseCompton.hh"
#include "G4InversePEEffect.hh"
#include "G4AdjointPhotoElectricModel.hh"
#include "G4AdjointAlongStepWeightCorrection.hh"
#include "G4hInverseIonisation.hh"
#include "G4AdjointhIonisationModel.hh"
#include "G4AdjointhMultipleScattering.hh"
#include "G4IonInverseIonisation.hh"
#include "G4AdjointIonIonisationModel.hh"
#include "G4AdjointSimManager.hh"
#include "G4AdjointProcessEquivalentToDirectProcess.hh"
#include "G4PhysicalConstants.hh"
#include "G4UrbanMscModel.hh"
#include "G4UrbanAdjointMscModel.hh"
#include "G4AdjointForcedInteractionForGamma.hh"
void G4AdjointPhysicsList::ConstructEM()
G4AdjointCSManager* theCSManager =
G4AdjointCSManager::GetAdjointCSManager();
G4AdjointSimManager* theAdjointSimManager =
G4AdjointSimManager::GetInstance();
G4AdjointElectron::AdjointElectron());
if (fUse_brem || fUse_peeffect ||fUse_compton)
G4AdjointGamma::AdjointGamma());
if (fUse_eionisation) {
if (!fEminusIonisation) fEminusIonisation =
new G4eIonisation();
fEminusIonisation->SetLossFluctuations(fUse_egain_fluctuation);
if (fUse_pionisation) {
if (!fPIonisation) fPIonisation = new G4hIonisation();
fPIonisation->SetLossFluctuations(fUse_egain_fluctuation);
G4AdjointProton::AdjointProton());
G4eBremsstrahlung* theeminusBremsstrahlung = 0;
if (fUse_brem && fUse_eionisation)
theeminusBremsstrahlung = new G4eBremsstrahlung();
G4ComptonScattering* theComptonScattering =0;
if (fUse_compton) theComptonScattering = new G4ComptonScattering();
G4PhotoElectricEffect* thePEEffect =0;
if (fUse_peeffect) thePEEffect = new G4PhotoElectricEffect();
G4eMultipleScattering* theeminusMS = 0;
G4hMultipleScattering* thepMS= 0;
G4hMultipleScattering* thegMS= 0;
G4eAdjointMultipleScattering* theeminusAdjointMS = 0;
if (fUse_ms) {
theeminusMS = new G4eMultipleScattering();
G4UrbanMscModel* msc1 = new G4UrbanMscModel();
theeminusMS->SetEmModel(msc1);
theeminusAdjointMS = new G4eAdjointMultipleScattering();
G4UrbanAdjointMscModel* msc2 = new G4UrbanAdjointMscModel();
theeminusAdjointMS->SetEmModel(msc2);
thepMS = new G4hMultipleScattering();
thegMS = new G4hMultipleScattering();
G4VProcess* theGammaConversion =0;
if (fUse_gamma_conversion) theGammaConversion = new G4GammaConversion();
//Declare the processes active for the different particles
auto particleIterator=GetParticleIterator();
particleIterator->reset();
while( (*particleIterator)() ){
G4ParticleDefinition* particle = particleIterator->value();
G4ProcessManager* pmanager = particle->GetProcessManager();
if (!pmanager) {
pmanager = new G4ProcessManager(particle);
particle->SetProcessManager(pmanager);
G4String particleName = particle->GetParticleName();
std::cout<<particleName<<std::endl;
G4String particleType = particle->GetParticleType();
if (particleName == "e-") {
if (fUse_ms && fUse_eionisation) pmanager->AddProcess(theeminusMS);
if (fUse_eionisation){
pmanager->AddProcess(fEminusIonisation);
RegisterEnergyLossProcess(fEminusIonisation,particle);
if (fUse_brem && fUse_eionisation) {
pmanager->AddProcess(theeminusBremsstrahlung);
RegisterEnergyLossProcess(theeminusBremsstrahlung,particle);
G4int n_order=0;
if (fUse_ms && fUse_eionisation) {
n_order++;
pmanager->SetProcessOrdering(theeminusMS, idxAlongStep,n_order);
n_order++;
pmanager->SetProcessOrdering(fEminusIonisation,idxAlongStep,n_order);
n_order++;
pmanager->SetProcessOrdering(theeminusBremsstrahlung,
n_order=0;
n_order++;
pmanager->SetProcessOrdering(theeminusMS,idxPostStep,n_order);
n_order++;
pmanager->SetProcessOrdering(fEminusIonisation,idxPostStep,n_order);
n_order++;
pmanager->SetProcessOrdering(theeminusBremsstrahlung,idxPostStep,
n_order);
if (particleName == "gamma") {
if (fUse_compton) {
pmanager->AddDiscreteProcess(theComptonScattering);
RegisterEmProcess(theComptonScattering,particle);
if (fUse_peeffect) {
pmanager->AddDiscreteProcess(thePEEffect);
RegisterEmProcess(thePEEffect,particle);
if (fUse_gamma_conversion) {
pmanager->AddDiscreteProcess(theGammaConversion);
if (particleName == "e+" && fUse_gamma_conversion) {//positron
G4VProcess* theeplusMultipleScattering = new G4eMultipleScattering();
G4VProcess* theeplusIonisation = new G4eIonisation();
G4VProcess* theeplusBremsstrahlung = new G4eBremsstrahlung();
G4VProcess* theeplusAnnihilation = new G4eplusAnnihilation();
// add processes
pmanager->AddProcess(theeplusMultipleScattering);
pmanager->AddProcess(theeplusIonisation);
pmanager->AddProcess(theeplusBremsstrahlung);
pmanager->AddProcess(theeplusAnnihilation);
// set ordering for AtRestDoIt
pmanager->SetProcessOrderingToFirst(theeplusAnnihilation, idxAtRest);
// set ordering for AlongStepDoIt
pmanager->SetProcessOrdering(theeplusMultipleScattering,
idxAlongStep,1);
pmanager->SetProcessOrdering(theeplusIonisation, idxAlongStep,2);
pmanager->SetProcessOrdering(theeplusBremsstrahlung,idxAlongStep,3);
// set ordering for PostStepDoIt
idxPostStep,1);
pmanager->SetProcessOrdering(theeplusIonisation,idxPostStep,2);
pmanager->SetProcessOrdering(theeplusBremsstrahlung,idxPostStep,3);
pmanager->SetProcessOrdering(theeplusAnnihilation,idxPostStep,4);
G4int n_order=0;
n_order++;
n_order++;
n_order=0;
n_order++;
n_order++;
G4int n_order=0;
if (fUse_ms) {
n_order++;
n_order++;
n_order);
n_order++;
idxAlongStep,
n_order);
n_order=0;
n_order++;
n_order++;
#include "G4Decay.hh"
void G4AdjointPhysicsList::ConstructGeneral()
// Add Decay Process
G4Decay* theDecayProcess = new G4Decay();
if (theDecayProcess->IsApplicable(*particle)) {
pmanager ->AddProcess(theDecayProcess);
// set ordering for PostStepDoIt and AtRestDoIt
pmanager ->SetProcessOrdering(theDecayProcess, idxPostStep);
pmanager ->SetProcessOrdering(theDecayProcess, idxAtRest);
void G4AdjointPhysicsList::SetCuts()
if (verboseLevel >0){
G4cout << "G4AdjointPhysicsList::SetCuts:";
G4cout << "CutLength : " << G4BestUnit(defaultCutValue,"Length") << G4endl;
// set cut values for gamma at first and for e- second and next for e+,
// because some processes for e+/e- need cut values for gamma
SetCutValue(defaultCutValue, "gamma");
SetCutValue(defaultCutValue, "e-");
SetCutValue(defaultCutValue, "e+");
if (verboseLevel>0) DumpCutValuesTable();
