I have a simple simulation involving protons impinging onto a target composed of water.
When I include Hadron inelastic physics into my PhysicsList the simulation ends abruptly with a Segmentation Fault and the following Warning message:
*** G4Exception : Tracking0013
issued by : G4SteppingManager::InvokeAtRestDoItProcs()
No AtRestDoIt process is active!
When I turn verbose mode on, this is preceded with the production of a triton.
Here is the longer output which is obtained when the code is executed with valgrind in case it helps anyone:
==1806877== Invalid read of size 8
==1806877== at 0x5C139A2: G4SteppingManager::InvokeAtRestDoItProcs() (in /usr/local/bin/geant4-10/geant4-v10.6.3-install/lib/libG4tracking.so)
==1806877== by 0x5C1073F: G4SteppingManager::Stepping() (in /usr/local/bin/geant4-10/geant4-v10.6.3-install/lib/libG4tracking.so)
==1806877== by 0x5C1B8EB: G4TrackingManager::ProcessOneTrack(G4Track*) (in /usr/local/bin/geant4-10/geant4-v10.6.3-install/lib/libG4tracking.so)
==1806877== by 0x5B85B29: G4EventManager::DoProcessing(G4Event*) (in /usr/local/bin/geant4-10/geant4-v10.6.3-install/lib/libG4event.so)
==1806877== by 0x4F0EB56: G4RunManager::DoEventLoop(int, char const*, int) (in /usr/local/bin/geant4-10/geant4-v10.6.3-install/lib/libG4run.so)
==1806877== by 0x4F0C7A1: G4RunManager::BeamOn(int, char const*, int) (in /usr/local/bin/geant4-10/geant4-v10.6.3-install/lib/libG4run.so)
==1806877== by 0x4F29286: G4RunMessenger::SetNewValue(G4UIcommand*, G4String) (in /usr/local/bin/geant4-10/geant4-v10.6.3-install/lib/libG4run.so)
==1806877== by 0x4F8BC42: G4UIcommand::DoIt(G4String) (in /usr/local/bin/geant4-10/geant4-v10.6.3-install/lib/libG4intercoms.so)
==1806877== by 0x4FAAAAE: G4UImanager::ApplyCommand(char const*) (in /usr/local/bin/geant4-10/geant4-v10.6.3-install/lib/libG4intercoms.so)
==1806877== by 0x4F7A570: G4UIbatch::ExecCommand(G4String const&) (in /usr/local/bin/geant4-10/geant4-v10.6.3-install/lib/libG4intercoms.so)
==1806877== by 0x4F7C525: G4UIbatch::SessionStart() (in /usr/local/bin/geant4-10/geant4-v10.6.3-install/lib/libG4intercoms.so)
==1806877== by 0x4FAC31F: G4UImanager::ExecuteMacroFile(char const*) (in /usr/local/bin/geant4-10/geant4-v10.6.3-install/lib/libG4intercoms.so)
==1806877== Address 0x0 is not stack'd, malloc'd or (recently) free'd
==1806877==
==1806877==
==1806877== Process terminating with default action of signal 11 (SIGSEGV)
==1806877== Access not within mapped region at address 0x0
==1806877== If you believe this happened as a result of a stack
==1806877== overflow in your program's main thread (unlikely but
==1806877== possible), you can try to increase the size of the
==1806877== main thread stack using the --main-stacksize= flag.
==1806877== The main thread stack size used in this run was 8388608.
==1806877==
==1806877== HEAP SUMMARY:
==1806877== in use at exit: 17,604,693 bytes in 150,993 blocks
==1806877== total heap usage: 1,240,228 allocs, 1,089,235 frees, 79,934,573 bytes allocated
==1806877==
==1806877== LEAK SUMMARY:
==1806877== definitely lost: 568 bytes in 4 blocks
==1806877== indirectly lost: 64 bytes in 2 blocks
==1806877== possibly lost: 160 bytes in 2 blocks
==1806877== still reachable: 17,603,901 bytes in 150,985 blocks
==1806877== of which reachable via heuristic:
==1806877== newarray : 8,200 bytes in 5 blocks
==1806877== multipleinheritance: 112 bytes in 1 blocks
==1806877== suppressed: 0 bytes in 0 blocks
==1806877== Rerun with --leak-check=full to see details of leaked memory
==1806877==
==1806877== For lists of detected and suppressed errors, rerun with: -s
==1806877== ERROR SUMMARY: 1 errors from 1 contexts (suppressed: 0 from 0)
My question is simple, does anyone know how I can prevent this from happening and allow my simulation to produce results? Any help/advice you can provide would be very appreciated.
