I have been trying to modify exampleB1 to include a localised magnetic field, but I have run into a segmentation fault error which I don’t understand. The code compiles with no errors, but when I run it I get this segmentation fault.
I have copied sections of the code from example f03 and pasted them into the ConstructSDandField function in the B1DetectorConstrunction class.
The logical volume containing the field is a cylinder. Here is a snippet from the ConstructSDandField function:
void B1DetectorConstruction::ConstructSDandField()
G4UniformMagField* fLocalMagneticField = new G4UniformMagField(G4ThreeVector(3.3*tesla,
0.0, // 0.5*tesla,
0.0));
G4Mag_UsualEqRhs* fLocalEquation = new G4Mag_UsualEqRhs(fLocalMagneticField);
G4double fMinStep = 0.25*um ; // minimal step of 1 mm is default
G4FieldManager* fLocalFieldManager = new G4FieldManager();
G4cout<<"F03FieldSetup::UpdateField> The minimal step is equal to "
<< fMinStep/mm <<" mm"<<G4endl;
G4cout<<" Stepper Type chosen = " //<< fStepperType
<< G4endl;
// 2. Create the steppers ( Note: this also deletes the previous ones. )
G4MagIntegratorStepper* fLocalStepper= nullptr;
fLocalStepper = new G4ClassicalRK4( fLocalEquation );
G4cout<<"G4ClassicalRK4 (default) is called"<<G4endl;
// 3. Create the chord finder(s)
G4ChordFinder* fLocalChordFinder = new G4ChordFinder(fLocalMagneticField,
fMinStep,fLocalStepper);
fLocalFieldManager->SetChordFinder(fLocalChordFinder);
// 4. Ensure that the field is updated (in Field manager & equation)
fLocalFieldManager->SetDetectorField(fLocalMagneticField);
G4bool allLocal = true;
//Logical volume containing the field
fFieldContainer->SetFieldManager(fLocalFieldManager,
allLocal );
G4cout<< "End of COnstructSDandField"<<G4endl;
This is my output
Any feedback on what might be causing this segmentation fault error would be greatly appreciated.
Thank you very much!
Cheers,
Luana
