Segmentation fault when using low energy and electric field
I am using Geant4 10.07 on Linux.
I am trying to run very low energy electrons (down to 1 eV eventually) with a non-uniform electric field. I am using Geant4-DNA as my PhysicsList.
I find that I can see the electron trajectory plotted on screen using an energy of 71 eV. However, with an energy of 70 eV, I get a Segmentation fault. I note that it cant find the region “Target”. I am not sure why this is at the moment, but its only a warning… and it doesn´t seem to cause a problem at the higher energy.
Any help much appreciated.
Chris
The output at 70 eV is as follows:
Available UI session types: [ Qt, GAG, tcsh, csh ]
qt.qpa.xcb: X server does not support XInput 2
Geant4 version Name: geant4-10-07 [MT] (4-December-2020)
: IEEE-TNS 53 (2006), 270-278
: NIM A 835 (2016), 186-225
WWW : http://geant4.org/
After SetUserInitialization(new B1DetectorConstruction())
Registering graphics systems…
ASCIITree (ATree)
DAWNFILE (DAWNFILE)
G4HepRep (HepRepXML)
G4HepRepFile (HepRepFile)
RayTracer (RayTracer)
VRML1FILE (VRML1FILE)
VRML2FILE (VRML2FILE)
gMocrenFile (gMocrenFile)
OpenGLImmediateX (OGLIX, OGLIQt_FALLBACK)
OpenGLStoredX (OGLSX, OGLSQt_FALLBACK)
RayTracerX (RayTracerX)
Registering model factories…
Registered model factories:
generic
drawByAttribute
drawByCharge
drawByOriginVolume
drawByParticleID
drawByEncounteredVolume
Registered models:
None
Registered filter factories:
attributeFilter
chargeFilter
originVolumeFilter
particleFilter
encounteredVolumeFilter
Registered filters:
None
“/vis/list” to see available colours.
/control/saveHistory
/run/verbose 2
Change the default number of threads (in multi-threaded mode)
#/run/numberOfThreads 4
Initialize kernel
/run/initialize
Checking overlaps for volume Sample (G4Tubs) … OK!
Checking overlaps for volume eFieldVol1 (G4Tubs) … OK!
Checking overlaps for volume eFieldVol2 (G4Tubs) … OK!
Checking overlaps for volume eFieldVol3 (G4Tubs) … OK!
Checking overlaps for volume eFieldVol4 (G4Tubs) … OK!
Checking overlaps for volume eFieldVol5 (G4Tubs) … OK!
Checking overlaps for volume eFieldVol6 (G4Tubs) … OK!
Checking overlaps for volume eFieldVol7 (G4Tubs) … OK!
World is registered to the default region.
Construct E Field Step 1
Construct E Field Step 2
  Electric field
—> Reading the field grid from EField_z_1E-9_r_1E-9_Tip_-70V.txt …
[ Number of values r,z: 11 11 ]
rstart: 0 zstart: 0 rend: 1e-08 zend: 1e-08
rstep: 1e-09 zstep: 1e-09
—> … done reading
  Electric field
—> Reading the field grid from EField_z_1E-8_r_1E-8_Tip_-70V.txt …
rstart: 0 zstart: 0 rend: 1e-07 zend: 1e-07
rstep: 1e-08 zstep: 1e-08
—> … done reading
  Electric field
—> Reading the field grid from EField_z_1E-7_r_1E-7_Tip_-70V.txt …
rstart: 0 zstart: 0 rend: 1e-06 zend: 1e-06
rstep: 1e-07 zstep: 1e-07
—> … done reading
  Electric field
—> Reading the field grid from EField_z_1E-6_r_1E-6_Tip_-70V.txt …
rstart: 0 zstart: 0 rend: 1e-05 zend: 1e-05
rstep: 1e-06 zstep: 1e-06
—> … done reading
  Electric field
—> Reading the field grid from EField_z_1E-5_r_1E-5_Tip_-70V.txt …
rstart: 0 zstart: 0 rend: 0.0001 zend: 0.0001
rstep: 1e-05 zstep: 1e-05
—> … done reading
  Electric field
—> Reading the field grid from EField_z_1E-4_r_1E-4_Tip_-70V.txt …
rstart: 0 zstart: 0 rend: 0.001 zend: 0.001
rstep: 0.0001 zstep: 0.0001
—> … done reading
  Electric field
—> Reading the field grid from EField_z_1E-3_r_1E-3_Tip_-70V.txt …
[ Number of values r,z: 26 21 ]
rstart: 0 zstart: 0 rend: 0.025 zend: 0.02
rstep: 0.001 zstep: 0.001
—> … done reading
physicsList->Construct() start.
=== G4UAtomicDeexcitation::InitialiseForNewRun()
physicsList->CheckParticleList() start.
physicsList->setCut() start.
PhysicsList::SetCuts:CutLength : 1 um
Visualization setting
/control/execute vis.mac
Use these open statements to open selected visualization
Use this open statement to create an OpenGL view:
/vis/open OGL 600x600-0+0
/vis/sceneHandler/create OGL
/vis/viewer/refresh
#/vis/open Win32
Use this open statement to create an OpenInventor view:
#/vis/open OI
Use this open statement to create a .prim file suitable for
viewing in DAWN:
#/vis/open DAWNFILE
Use this open statement to create a .heprep file suitable for
viewing in HepRApp:
#/vis/open HepRepFile
Use this open statement to create a .wrl file suitable for
viewing in a VRML viewer:
#/vis/open VRML2FILE
Disable auto refresh and quieten vis messages whilst scene and
trajectories are established:
/vis/verbose errors
Draw geometry:
/vis/drawVolume
/vis/scene/create
/vis/sceneHandler/attach
Specify view angle:
Specify style (surface, wireframe, auxiliary edges,…)
Draw smooth trajectories at end of event, showing trajectory points
as markers 2 pixels wide:
/tracking/storeTrajectory 2
G4TrajectoriesModel:
Event ID (EventID): G4int
Run ID (RunID): G4int
G4SmoothTrajectory:
Track ID (ID): G4int
No. of points (NTP): G4int
PDG Encoding (PDG): G4int
Parent ID (PID): G4int
Particle Name (PN): G4String
G4SmoothTrajectoryPoint:
/vis/scene/notifyHandlers
(if too many tracks cause core dump => /tracking/storeTrajectory 0)
Draw hits at end of event:
#/vis/scene/add/hits
To draw only gammas:
To invert the above, drawing all particles except gammas,
keep the above two lines but also add:
Many other options are available with /vis/modeling and /vis/filtering.
For example, to select colour by particle ID:
To select or override default colours (note: e+ is blue by default):
To superimpose all of the events from a given run:
Decorations
Name
/vis/set/textColour green
/vis/set/textLayout right
or, if your system does not support right-adjustment
/vis/set/textLayout
/vis/set/textColour
Axes, scale, etc.
/vis/scene/add/scale
/vis/scene/add/axes
/vis/scene/add/eventID
/vis/scene/add/date
/vis/scene/add/logo2D
/vis/scene/add/logo
Frame
/vis/set/colour red
/vis/set/lineWidth 2
/vis/scene/add/frame
/vis/set/colour
/vis/set/lineWidth
Attach text to one edge of Shape1, with a small, fixed offset
Attach text to one corner of Shape2, with a small, fixed offset
To get nice view
Make the “World” box invisible
/vis/geometry/set/visibility World 0 false
“Sample” is transparent blue to represent water
/vis/geometry/set/colour Sample 0 0 0 1 .3
/vis/viewer/set/style surface
Re-establish auto refreshing and verbosity:
/vis/viewer/refresh
/vis/verbose warnings
For file-based drivers, use this to create an empty detector view:
#/vis/viewer/flush
/control/execute run1.mac
Macro file for example B1
Can be run in batch, without graphic
or interactively: Idle> /control/execute run1.mac
Change the default number of workers (in multi-threading mode)
Initialize kernel
/run/initialize
/control/verbose 2
/run/verbose 2
/event/verbose 0
/tracking/verbose 1
gamma 6 MeV to the direction (0.,0.,1.)
#/gun/particle gamma
#/gun/energy 60 eV
#/run/beamOn 5
electron 210 eV to the direction (0.,-1.,0.)
/process/em/lowestElectronEnergy 1 eV
/run/physicsModified
/run/setCut 0.001 mm
/gun/particle e-
/gun/direction 0. 1. 1.
/gun/position 0. 100. 0. um
/gun/energy 70 eV
/tracking/verbose 2
/run/beamOn 1
=== Deexcitation model UAtomDeexcitation is activated for 1 region:
      DefaultRegionForTheWorld  1  1  1
=== Auger cascade flag: 0
=== Ignore cuts flag: 0
=== PIXE model for hadrons: Empirical
=== PIXE model for e±: Livermore
*** G4Exception : GeomMgt1001
issued by : G4RegionStore::GetRegion()
Region NOT found in store !
Region Target NOT found in store !
Returning NULL pointer.
G4EmConfigurator WARNING: fails to find a region <Target
msc: for e- SubType= 10
===== EM models for the G4Region DefaultRegionForTheWorld ======
UrbanMsc : Emin= 0 eV Emax= 100 TeV Nbins=84 100 eV - 100 TeV
StepLim=UseSafety Rfact=0.04 Gfact=2.5 Sfact=0.6 DispFlag:1 Skin=1 Llimit=1
eIoni: for e- SubType=2
dE/dx and range tables from 100 eV to 100 TeV in 84 bins
Lambda tables from threshold to 100 TeV, 7 bins/decade, spline: 1
StepFunction=(0.2, 1 mm), integ: 1, fluct: 1, linLossLim= 0.01
MollerBhabha : Emin= 0 eV Emax= 100 TeV
e-_G4MicroElecElastic: for e- SubType=51 BuildTable=0
DummyModel : Emin= 0 eV Emax= 100 TeV
e-_G4MicroElecInelastic: for e- SubType=53 BuildTable=0
msc: for proton SubType= 10
StepLim=Minimal Rfact=0.2 Gfact=2.5 Sfact=0.6 DispFlag:0 Skin=1 Llimit=1
hIoni: for proton SubType=2
StepFunction=(0.2, 0.1 mm), integ: 1, fluct: 1, linLossLim= 0.01
Bragg : Emin= 0 eV Emax= 2 MeV
BetheBloch : Emin= 2 MeV Emax= 100 TeV
p_G4MicroElecInelastic: for proton SubType=53 BuildTable=0
msc: for GenericIon SubType= 10
ionIoni: for GenericIon SubType=2
StepFunction=(0.2, 0.1 mm), integ: 1, fluct: 1, linLossLim= 0.02
Stopping Power data for 17 ion/material pairs
BraggIon : Emin= 0 eV Emax= 2 MeV
ion_G4MicroElecInelastic: for GenericIon SubType=53 BuildTable=0
Region – – appears in world volume
This region is in the mass world.
Root logical volume(s) : World
Pointers : G4VUserRegionInformation[0], G4UserLimits[0], G4FastSimulationManager[0], G4UserSteppingAction[0]
Materials : G4_Galactic G4_W Galactic
Production cuts : gamma 1 um e- 1 um e+ 1 um proton 1 um
Region – – is not associated to any world.
Materials :
========= Table of registered couples ============================
Index : 0 used in the geometry : Yes
Material : G4_Galactic
Range cuts : gamma 1 um e- 1 um e+ 1 um proton 1 um
Energy thresholds : gamma 990 eV e- 990 eV e+ 990 eV proton 100 eV
Region(s) which use this couple :
Index : 1 used in the geometry : Yes
Material : G4_W
Energy thresholds : gamma 1.62781 keV e- 14.7038 keV e+ 14.3856 keV proton 100 eV
Index : 2 used in the geometry : Yes
Material : Galactic
Start closing geometry.
G4GeometryManager::ReportVoxelStats – Voxel Statistics
Total memory consumed for geometry optimisation:   1 kByte
Total CPU time elapsed for geometry optimisation: 0 seconds
Voxelisation: top CPU users:
Percent   Total CPU    System CPU       Memory  Volume
   0.00         0.00         0.00            1k World
Voxelisation: top memory users:
Percent     Memory      Heads    Nodes   Pointers    Total CPU    Volume
 100.00          1k         3        9         50         0.00    World
Run 0 starts.
  • G4Track Information: Particle = e-, Track ID = 1, Parent ID = 0
Step# X(mm) Y(mm) Z(mm) KinE(MeV) dE(MeV) StepLeng TrackLeng NextVolume ProcName
0 0 0.1 0 7e-05 0 0 0 eFieldVol6 initStep
1 1.3e-17 1 0.00524 7.01e-05 9.89e-24 0.925 0.925 eFieldVol7 Transportation
2 1.4e-17 1.06 7.23e-16 6.99e-05 5.96e-25 0.0557 0.981 Sample Transportation
3 1.4e-17 1.06 -3.57e-08 5.1e-05 1.89e-05 1.85e-06 0.981 Sample msc
4 2.9e-08 1.06 -2.31e-18 4.78e-05 3.26e-06 6.39e-08 0.981 eFieldVol7 Transportation
5 0.23 0.973 0.306 6.01e-05 3.46e-24 0.392 1.37 eFieldVol6 Transportation
Segmentation fault
Hi. Sorry to see this very late.
From the verbose output it’s clear that there is a crash. There have at times been problems with particles stopping in an electric field. If I recall correctly there can a large inaccuracy in a step in which the electric field slows the track down and ‘turns’ it around - i.e. the projection of the momentum on the direction of the velocity goes from negative to positive.
If you have been able to overcome this issue, please let us know.
Else we will investigate.
Best regards, John
Hi John,
Thanks for the reply (if a little late!). I was using a low energy Geant4 library that was used to simulate electrons in scanning electron microscopes. I thought I had updated the library to the latest version, but it seems that I missed part of it. The issue seems to have been with a modified version of G4Transportation and I was unable to figure out how to update the code to the latest release of Geant4. The code worked when there were no electric or magnetic fields, but as soon as such a field was introduced, the code provided incorrect results. I got around the problem by flying the electrons when they were in the vacuum (and in the electric field) using a different program (COMSOL) and then transferring to the Geant4 code when the electrons struck a material object (and vice versa when the electron exited the material). A bit clunky, but it worked and we got a paper or two out of it ! Best Wishes, Chris
