Hello!
I try to install Giant 4 on Mac, but every time I try to run B1 example, I get a segmentation fault error. Geant and example were installed without problems (except a problem with geant4_set_and_check_package_variable).
Available UI session types: [ Qt, tcsh, csh ]
QObject::connect: No such signal QTabWidget::tabCloseRequested(G4int)
QObject::connect: No such signal QTabWidget::currentChanged(G4int)
QObject::connect: No such signal QComboBox::activated(G4int)
Geant4 version Name: geant4-11-01-patch-01 [MT] (10-February-2023)
<< in Multi-threaded mode >>
: IEEE-TNS 53 (2006), 270-278
: NIM A 835 (2016), 186-225
WWW : http://geant4.org/
ASCIITree (ATree)
DAWNFILE (DAWNFILE)
G4HepRepFile (HepRepFile)
RayTracer (RayTracer)
VRML2FILE (VRML2FILE)
gMocrenFile (gMocrenFile)
Qt3D (Qt3D)
TOOLSSG_QT_GLES (TSG_QT_GLES, TSGQt, TSG)
Registered model factories:
generic
drawByAttribute
drawByCharge
drawByOriginVolume
drawByParticleID
drawByEncounteredVolume
Registered models:
None
Registered filter factories:
attributeFilter
chargeFilter
originVolumeFilter
particleFilter
encounteredVolumeFilter
Registered filters:
None
/control/saveHistory
/run/verbose 2
# Change the default number of threads (in multi-threaded mode)
#/run/numberOfThreads 4
# Initialize kernel
/run/initialize
zsh: segmentation fault ./exampleB1
What should I do to fix it?
Thanks!
Geant4 Version: 4.11.01
Operating System: MacOS 13.5.2
Compiler/Version: clang 15.0.0
CMake Version: 3.27.6
