Many apologies if this is in the wrong category,
Hi, when using my group’s geant4 monte carlo I am experiencing a segmentation fault of which we are unable to debug. If any one can identify the root of this fault it would be greatly appreciated.
Here is the stack trace, my OS, compiler and geant4 version,
Ubutunu 18.04
Geant4-10.6.2
gcc 7.5.0
There was a crash.
This is the entire stack trace of all threads:
#0 0x00007fa4b81496e7 in __GI___waitpid (pid=4087, stat_loc=stat_loc
entry=0x7ffdd5c85d68, options=options
entry=0) at ../sysdeps/unix/sysv/linux/waitpid.c:30
#1 0x00007fa4b80b4107 in do_system (line=<optimised out>) at ../sysdeps/posix/system.c:149
#2 0x00007fa4c43af753 in TUnixSystem::StackTrace() () from /home/chuggles/root/build/lib/libCore.so
#3 0x00007fa4c43b2245 in TUnixSystem::DispatchSignals(ESignals) () from /home/chuggles/root/build/lib/libCore.so
#4 <signal handler called>
#5 0x00007fa4ba15ec53 in G4DynamicParticle::~G4DynamicParticle (this=0x5564aeed2d30, __in_chrg=<optimised out>) at /home/chuggles/geant4-sources/source/particles/management/src/G4DynamicParticle.cc:275
#6 0x00007fa4b4caf90a in G4Track::~G4Track() () from /usr/local/geant4/lib/libG4track.so
#7 0x00007fa4bf13d845 in G4EventManager::DoProcessing (this=0x5564a73cbcf0, anEvent=<optimised out>) at /home/chuggles/geant4-sources/source/event/src/G4EventManager.cc:248
#8 0x00007fa4bf13e2fc in G4EventManager::ProcessOneEvent (this=<optimised out>, anEvent=<optimised out>) at /home/chuggles/geant4-sources/source/event/src/G4EventManager.cc:337
#9 0x00007fa4bf3dc3b7 in G4RunManager::ProcessOneEvent (this=0x5564a73c87e0, i_event=0) at /home/chuggles/geant4-sources/source/run/src/G4RunManager.cc:414
#10 0x00007fa4bf3da8c3 in G4RunManager::DoEventLoop (this=0x5564a73c87e0, n_event=13817, macroFile=<optimised out>, n_select=<optimised out>) at /home/chuggles/geant4-sources/source/run/src/G4RunManager.cc:381
#11 0x00007fa4bf3da65e in G4RunManager::BeamOn (this=0x5564a73c87e0, n_event=13817, macroFile=0x0, n_select=-1) at /home/chuggles/geant4-sources/source/run/src/G4RunManager.cc:276
#12 0x00005564a5915562 in main (argc=1, argv=0x7ffdd5cd18d8) at /home/chuggles/gitwagasci/wagasci-babymind-monte-carlo/src/B2MC.cc:148
