Is it possible to set a limit on the maximum number of trajectories that will be saved to a visualization?
I would like to save the first 100 to 1000 events so I can confirm that the x-rays are firing in the correct direction and over the right area. But I don’t want all the events when I do a longer run.
It seems like there should be a UI command for this, but I can’t find it.
where 100 is the maximum number of events to keep. But it does not seem to work the way I expected. For others reading this later: Note that the command on the second line is drawOnlyToBeKeptEvents
“Keeping” refers to what’s kept at end of run. At end of run you may /vis/reviewKeptEvents
They are also used when re-drawing, for example, with another graphics system.
