ShieldingLEND physics list crashing
_Geant4 Version: 11.4
_Operating System: Windows 11
_Compiler/Version: Visual Studio 17.9
_CMake Version: 3.29.2
Hello. I am trying to run a simulation comparing several different physics lists, with ShieldingLEND being one of them. I downloaded and unzipped the data file according to the documentation below (I downloaded LEND_GNDS2.0_ENDF.BVIII.1)
  • This release introduces new data set versions. Please see the corresponding details in Section 9 of this document.
    • New data set versions: G4PhotonEvaporation-6.1.2, G4INCL-1.3, G4CHANNELING-2.0, G4EMLOW-8.8, G4PARTICLEXS-4.2.
    • In order to use ParticleHP for charged particles (protons, deuterons, tritons, He3 and alphas), an optional data set G4TENDL-1.4 is required, and can be optionally downloaded in addition.
Optional nuclear data sets for use with the LEND (Low Energy Nuclear Data) Cross Section and Model can be optionally downloaded here:
LEND_GNDS2.0_ENDF.BVII.1 (2.87 Gb), LEND_GNDS2.0_ENDF.BVIII.0 (4.24 Gb), LEND_GNDS2.0_ENDF.BVIII.1 (5.78 Gb).
The G4LENDDATA environment variable should be used to switch the path to the appropriate nuclear data library unpacked and installed.
I also made sure that I updated my environment variable for G4LENDDATA to point to the correct directory: “C:\Users\User\Geant4-v-11-4\share\Geant4\data\LEND_GNDS2.0_ENDF.BVIII.1”. I make I include the ShieldingLEND header and initialize the physics lists as well,
#include "ShieldingLEND.hh"
G4VModularPhysicsList* physicsList = new ShieldingLEND;
physicsList->SetVerboseLevel(2);
When I try to run the executeable, it recognizes the physics list,
Geant4 version Name: geant4-11-04 [MT] (5-December-2025)
: IEEE-TNS 53 (2006), 270-278
: NIM A 835 (2016), 186-225
WWW : http://geant4.org/
<<< Geant4 Physics List simulation engine: Shielding
<<< LEND will be used for low energy neutron and gamma projectiles
Registering graphics systems…
ASCIITree (ATree)
DAWNFILE (DAWNFILE)
RayTracer (RT)
VRML2FILE (VRML2FILE)
gMocrenFile (gMocrenFile)
TOOLSSG_WINDOWS_GLES (TSG_WINDOWS_GLES, TSG, OGL)
TOOLSSG_WINDOWS_ZB (TSG_WINDOWS_ZB, TSGZB)
You may choose a graphics system (driver) with a parameter of
the command “/vis/open” or “/vis/sceneHandler/create”,
or you may omit the driver parameter and choose at run time:
  • by argument in the construction of G4VisExecutive;
  • by environment variable “G4VIS_DEFAULT_DRIVER”;
  • by entry in “~/.g4session”;
  • by build flags.
  • Note: This feature is not allowed in batch mode.
    For further information see “examples/basic/B1/exampleB1.cc”
    and “vis.mac”.
Registering model factories…
Registered model factories:
generic
drawByAttribute
drawByCharge
drawByOriginVolume
drawByParticleID
drawByEncounteredVolume
Registered models:
None
Registered filter factories:
attributeFilter
chargeFilter
originVolumeFilter
particleFilter
encounteredVolumeFilter
Registered filters:
None
PrimaryGeneratorAction initialized.
No data files loaded. Set via macro commands:
/primary/setAngularFile (required)
/primary/setMeanEnergyFile (required if useMeanSampling true)
/primary/setCDFEnergyFile (required if useMeanSampling false)
/primary/setLabDepth (auto-loads bundle tables)
Bundle energy scaling in CDF mode uses the first moment of each
CDF block - no mean energy file needed.
Checking overlaps for volume labPV:0 (G4Box) … OK!
Checking overlaps for volume rockPV:0 (G4SubtractionSolid) … OK!
G4EmStandard Construct Processes
but every time it gets to the G4EmStandard Construct Processes, it crashes right after that. If I just use Shielding instead of ShieldingLEND I have no issues and everything runs perfectly fine. Is this is known issue or does anyone possibly know how to making the LEND physics work properly?
I tested this on macOS with Geant4 11.4.1 and ShieldingLEND using LEND_GNDS2.0_ENDF.BVIII.1, and a small test program initialized successfully in both single-thread and multi-thread mode, so I could not reproduce the crash…. If possible, could you share a small reproducer?
