I am developing Geant4-based simulation to check detector response, and I have a question.
Could someone tell me how to show pions/kaons in the decay process?
Currently I am using very simple simulation that protons with 30 GeV are injected into Carbons or Leads of 10 cm thickness, and check particles in the sensitive detector as
for (int i = 0; i < i_numberOfHits; i++) {
TTNNHit* aHit = static_cast<TTNNHit*>(i_TTNNHitsCollection->GetHit(i));
G4cout << "check ParticleName: " << theEventID << " " << aHit->TrackID << " " << aHit->ParticleName << " " << aHit->pdgID << G4endl;
But only protons and electrons (and small fraction of gammas) appear.
In the PhysicsList, I included all the 6 types of particles as
G4MesonConstructor mConstructor;
mConstructor.ConstructParticle();
and in the PhysicsProcess, I include G4EmStandardPhysics, G4HadronElasticPhysics (and else), but situation does not change.
I added decay processes as following,
G4Decay* fDecayProcess = new G4Decay;
G4PhysicsListHelper* ph = G4PhysicsListHelper::GetPhysicsListHelper();
ph->RegisterProcess( fDecayProcess, G4PionPlus::Definition() );
ph->RegisterProcess( fDecayProcess, G4PionMinus::Definition() );
ph->RegisterProcess( fDecayProcess, G4KaonPlus::Definition() );
ph->RegisterProcess( fDecayProcess, G4KaonMinus::Definition() );
ph->RegisterProcess( fDecayProcess, G4KaonZeroLong::Definition() );
ph->RegisterProcess( fDecayProcess, G4KaonZeroShort::Definition() );
but simulation stops with following exception.
using sequential mode
G4PhysicsListHelper::RegisterProcess : No Process Manager for pi+
*** G4Exception : Riun0110
issued by : G4PhysicsListHelper::RegisterProcess
No process manager
It is very much appreciated if you tell me how to include pions/kaons in the decay process of the simulation.
Thanks!
