Simple Gamma Detection Simulation
Geant4 Version: 10.7.4
Operating System: RHEL9
Compiler/Version: 11.4.1
CMake Version: 3.20.2
I’ve simulated a Cs137 point source sitting next to a NaI crystal and recorded the energy deposited in the crystal to form an energy spectra. I’ve uploaded the results of the simulated energy spectra along with one collected from a NaI detector I have in my lab. The big noticable difference is in the Compton back scatter peak around 200keV which is absent from the simulation. Can someone help pin point how to figure out if I’m using the right physics libraries to properly simulate an energy spectra of a gamma less than 2MeV?
The simulation was done using the topasmc.org geant4 framework.
Here is a cut and paste of the simulation output at the initialization stage listing all the physics processes.
Registered Physics Processes:
     Transportation,        StepLimiter,     UserSpecialCut,               phot
              compt,               conv,               Rayl,                msc
              eIoni,              eBrem,        CoulombScat,                msc
              eIoni,              eBrem,            annihil,        CoulombScat
                msc,            ionIoni,                msc,             muIoni
        CoulombScat,             muIoni,                msc,              hIoni
        CoulombScat,              hIoni,                msc,              hIoni
        CoulombScat,                msc,              hIoni,        CoulombScat
              hIoni,              hIoni,                msc,            ionIoni
                msc,            ionIoni,RadioactiveDecayBase
Visualization verbosity changed to quiet (0)
My Begin Run has been called edited
### ===  Deexcitation model UAtomDeexcitation is activated for 1 region:
          DefaultRegionForTheWorld  1  1  0
### ===  Auger cascade flag: 1
### ===  Ignore cuts flag:   1
phot:  for gamma SubType=12 BuildTable=0
      LambdaPrime table from 200 keV to 500 MeV in 25 bins
      ===== EM models for the G4Region  DefaultRegionForTheWorld ======
 LivermorePhElectric : Emin=    0 eV  Emax=  500 MeV  SauterGavrila Fluo
compt:  for gamma SubType=13 BuildTable=1
      Lambda table from 100 eV  to 1 MeV, 7 bins/decade, spline: 1
      LambdaPrime table from 1 MeV to 500 MeV in 20 bins
       Klein-Nishina : Emin=    0 eV  Emax=  500 MeV
conv:  for gamma SubType=14 BuildTable=1
      Lambda table from 1.022 MeV to 500 MeV, 33 bins/decade, spline: 1
     BetheHeitlerLPM : Emin=    0 eV  Emax=  500 MeV  ModifiedTsai
Rayl:  for gamma SubType=11 BuildTable=1
      Lambda table from 100 eV  to 100 keV, 7 bins/decade, spline: 0
      LambdaPrime table from 100 keV to 500 MeV in 27 bins
   LivermoreRayleigh : Emin=    0 eV  Emax=  500 MeV  CullenGenerator
msc:  for e-  SubType= 10
            UrbanMsc : Emin=    0 eV  Emax=  100 MeV Nbins=42 100 eV  - 100 MeV
              StepLim=UseSafety Rfact=0.04 Gfact=2.5 Sfact=0.6 DispFlag:1 Skin=1 Llimit=1
        WentzelVIUni : Emin=  100 MeV Emax=  500 MeV Nbins=7 100 MeV - 500 MeV
eIoni:  for e-  SubType=2
      dE/dx and range tables from 100 eV  to 500 MeV in 49 bins
      Lambda tables from threshold to 500 MeV, 7 bins/decade, spline: 1
      StepFunction=(0.2, 1 mm), integ: 1, fluct: 1, linLossLim= 0.01
        MollerBhabha : Emin=    0 eV  Emax=  500 MeV
eBrem:  for e-  SubType=3
      LPM flag: 1 for E > 0.5 GeV,  VertexHighEnergyTh(GeV)= 100000
             eBremSB : Emin=    0 eV  Emax=  500 MeV  ModifiedTsai
CoulombScat:  for e-, integral:1  SubType=1 BuildTable=1
      Lambda table from 100 MeV to 500 MeV, 7 bins/decade, spline: 1
      ThetaMin(p) < Theta(degree) < 180; pLimit(GeV^1)= 0.139531
  eCoulombScattering : Emin=  100 MeV Emax=  500 MeV
msc:  for e+  SubType= 10
eIoni:  for e+  SubType=2
eBrem:  for e+  SubType=3
annihil:  for e+, integral:1  SubType=5 BuildTable=0
            eplus2gg : Emin=    0 eV  Emax=  500 MeV
CoulombScat:  for e+, integral:1  SubType=1 BuildTable=1
msc:  for proton  SubType= 10
        WentzelVIUni : Emin=    0 eV  Emax=  500 MeV Nbins=49 100 eV  - 500 MeV
              StepLim=Minimal Rfact=0.2 Gfact=2.5 Sfact=0.6 DispFlag:0 Skin=1 Llimit=1
hIoni:  for proton  SubType=2
      StepFunction=(0.2, 0.1 mm), integ: 1, fluct: 1, linLossLim= 0.01
               Bragg : Emin=    0 eV  Emax=    2 MeV
          BetheBloch : Emin=    2 MeV Emax=  500 MeV
CoulombScat:  for proton, integral:1  SubType=1 BuildTable=1
      Lambda table from threshold  to 500 MeV, 7 bins/decade, spline: 1
  eCoulombScattering : Emin=    0 eV  Emax=  500 MeV
msc:  for GenericIon  SubType= 10
            UrbanMsc : Emin=    0 eV  Emax=  500 MeV
ionIoni:  for GenericIon  SubType=2
      StepFunction=(0.2, 0.1 mm), integ: 1, fluct: 1, linLossLim= 0.02
      Stopping Power data for 17 ion/material pairs
            BraggIon : Emin=    0 eV  Emax=    2 MeV
======          Radioactive Decay Physics Parameters           =======
Max life time                                     1.4427e+06 ps
Internal e- conversion flag                       1
Stored internal conversion coefficients           1
Enable correlated gamma emission                  0
Max 2J for sampling of angular correlations       10
Atomic de-excitation enabled                      1
Auger electron emission enabled                   1
Auger cascade enabled                             1
Check EM cuts disabled for atomic de-excitation   1
Use Bearden atomic level energies                 0
msc:  for alpha  SubType= 10
            UrbanMsc : Emin=    0 eV  Emax=  500 MeV Nbins=49 100 eV  - 500 MeV
ionIoni:  for alpha  SubType=2
            BraggIon : Emin=    0 eV  Emax=7.9452 MeV
          BetheBloch : Emin=7.9452 MeV Emax=  500 MeV
msc:  for anti_proton  SubType= 10
hIoni:  for anti_proton  SubType=2
            ICRU73QO : Emin=    0 eV  Emax=    2 MeV
CoulombScat:  for anti_proton, integral:1  SubType=1 BuildTable=1
msc:  for kaon+  SubType= 10
hIoni:  for kaon+  SubType=2
               Bragg : Emin=    0 eV  Emax=1.05231 MeV
          BetheBloch : Emin=1.05231 MeV Emax=  500 MeV
CoulombScat:  for kaon+, integral:1  SubType=1 BuildTable=1
msc:  for kaon-  SubType= 10
hIoni:  for kaon-  SubType=2
            ICRU73QO : Emin=    0 eV  Emax=1.05231 MeV
CoulombScat:  for kaon-, integral:1  SubType=1 BuildTable=1
      Used Lambda table of kaon+
msc:  for mu+  SubType= 10
muIoni:  for mu+  SubType=2
               Bragg : Emin=    0 eV  Emax=  200 keV
          BetheBloch : Emin=  200 keV Emax=  500 MeV
CoulombScat:  for mu+, integral:1  SubType=1 BuildTable=1
msc:  for mu-  SubType= 10
muIoni:  for mu-  SubType=2
            ICRU73QO : Emin=    0 eV  Emax=  200 keV
CoulombScat:  for mu-, integral:1  SubType=1 BuildTable=1
      Used Lambda table of mu+
msc:  for pi+  SubType= 10
hIoni:  for pi+  SubType=2
               Bragg : Emin=    0 eV  Emax=297.505 keV
          BetheBloch : Emin=297.505 keV Emax=  500 MeV
CoulombScat:  for pi+, integral:1  SubType=1 BuildTable=1
msc:  for pi-  SubType= 10
hIoni:  for pi-  SubType=2
            ICRU73QO : Emin=    0 eV  Emax=297.505 keV
CoulombScat:  for pi-, integral:1  SubType=1 BuildTable=1
      Used Lambda table of pi+
--> G4MTRunManager::CreateAndStartWorkers() --> Initializing workers...
G4WT0 >      Transportation,        StepLimiter,     UserSpecialCut,               phot
G4WT0 >               compt,               conv,               Rayl,                msc
G4WT0 >               eIoni,              eBrem,        CoulombScat,                msc
G4WT0 >               eIoni,              eBrem,            annihil,        CoulombScat
G4WT0 >                 msc,            ionIoni,                msc,             muIoni
G4WT0 >         CoulombScat,             muIoni,                msc,              hIoni
G4WT0 >         CoulombScat,              hIoni,                msc,              hIoni
G4WT0 >         CoulombScat,                msc,              hIoni,        CoulombScat
G4WT0 >               hIoni,              hIoni,                msc,            ionIoni
G4WT0 >                 msc,            ionIoni,RadioactiveDecayBase
G4WT0 > Begin processing for Run: 0, History: 0
The backscatter peak (normally a broad bump) is a real-world experimental effect caused by gamma rays scattering at large angles (very roughly 180 degrees) from materials surrounding the detector into the detector. Your simulation only has the detector and a source so I would not expect a backscatter peak.
This is very useful. I’ll add the aluminum casing used to insulate the NaI crystal and surrounding lead shielding. Let’s see if the Compton back-scatter appears.
