_Geant4 Version: 4-11.2
_Operating System: Windows 11
_Compiler/Version: Visual Studio 17.9
_CMake Version: 3.29.2
I am brand new to using GEANT4 and am quite overwhelmed at the amount of information one needs to learn to properly utilize it. I am currently running a muon detection experiment in a new shallow underground research facility and need to simulate the detector in GEANT4 in order to properly understand the effective solid angle cone of muon acceptance. The physical geometry is a smaller 12.5cm W x 14.5cm L x 4.0cm H plastic scintillator on top of a 16.0cm W x 20.0cm L x 2.0cm H sheet of lead, which then sits on top of a much larger 30.0cm W x 48.0cm L x 4.0cm H plastic scintillator. A muon passing through the top AND bottom scintillator would produce a coincidence detection and be recorded as a count.
The detector does not need to be simulated underground, I just need to understand the solid angle acceptance of this setup. I can’t seem to find an example similar to this, if anyone could assist me an example or where to start, I would greatly appreciate it, thank you.
