11.1.1 GEANT4 version
Linus OS
So I modified the WLS example that consists of WLS plugged in the plastic scintillator wrapped in tyvek with copied sensitive detector with copy number (from the WLS example). I am shooting a muon beam of 4 GeV right in front of the plastic scintillator and it seems to be working perfectly apart from some events that are “disappearing”. For example, I have attached the scintillation output file which shows after certain events (exactly 75) it gives 0 scintillation output and the program rushes through those events. I believe it may be due to stacking action issues or memory loss since I tested both the physics with muon decay off. I also tested with and without wrapping material and it yields the same results. I have included my Stacking Action.cc code below.
// * License and Disclaimer *
// * The Geant4 software is copyright of the Copyright Holders of *
// * the Geant4 Collaboration. It is provided under the terms and *
// * conditions of the Geant4 Software License, included in the file *
// * LICENSE and available at http://cern.ch/geant4/license . These *
// * include a list of copyright holders. *
// * Neither the authors of this software system, nor their employing *
// * institutes,nor the agencies providing financial support for this *
// * work make any representation or warranty, express or implied, *
// * regarding this software system or assume any liability for its *
// * use. Please see the license in the file LICENSE and URL above *
// * for the full disclaimer and the limitation of liability. *
// * This code implementation is the result of the scientific and *
// * technical work of the GEANT4 collaboration. *
// * By using, copying, modifying or distributing the software (or *
// * any work based on the software) you agree to acknowledge its *
// * use in resulting scientific publications, and indicate your *
// * acceptance of all terms of the Geant4 Software license. *
/// \file optical/wls/src/WLSStackingAction.cc
/// \brief Implementation of the WLSStackingAction class
#include "WLSStackingAction.hh"
#include "G4OpticalPhoton.hh"
#include "G4RunManager.hh"
#include "G4Track.hh"
#include <iostream>
#include <fstream> // Required for file handling
#include "G4AnalysisManager.hh" // Ntuples update
WLSStackingAction::WLSStackingAction()
: fPhotonCounter(0)
, fScintillationCounter(0)
, fCerenkovCounter(0)
WLSStackingAction::~WLSStackingAction() {}
G4ClassificationOfNewTrack WLSStackingAction::ClassifyNewTrack(
const G4Track* aTrack)
G4ParticleDefinition* particleType = aTrack->GetDefinition();
// keep primary particle
if (aTrack->GetParentID() == 0) { return fUrgent; }
if(particleType == G4OpticalPhoton::OpticalPhotonDefinition())
// keep optical photon
++fPhotonCounter;
return fUrgent;
//stack and count optical photons
if(aTrack->GetDefinition() == G4OpticalPhoton::OpticalPhotonDefinition())
{ // particle is optical photon
// ++fPhotonCounter; // total optical photons produced
if(aTrack->GetParentID() > 0)
{ // particle is secondary
if(aTrack->GetCreatorProcess()->GetProcessName() == "Scintillation")
++fScintillationCounter;
else if(aTrack->GetCreatorProcess()->GetProcessName() == "Cerenkov")
++fCerenkovCounter;
return fUrgent;
void WLSStackingAction::NewStage()
// G4cout << "Number of optical photons produces in this event : "
// << fPhotonCounter << G4endl;
// Open a file stream for writing
std::ofstream outputFile("scintillation_output.txt", std::ios::app);
// Check if the file is successfully opened
if (outputFile.is_open()) {
// Redirect the output to the file stream
outputFile << fPhotonCounter << std::endl;
// Close the file stream
outputFile.close();
} else {
// Print an error message if the file cannot be opened
G4cout << "Error: Unable to open the output file." << G4endl;
analysisManager->FillNtupleDColumn(4,fPhotonCounter);
analysisManager->AddNtupleRow();
void WLSStackingAction::PrepareNewEvent() {
fPhotonCounter = 0;
fScintillationCounter = 0;
fCerenkovCounter =0;
I ran 100 events for 3 runs and it seems to get stuck randomly at certain events and then run again. I am shooting the muon beam pretty close to the plastic scintillator tile wrapped in tyvek.
I have attached the DetectorConstruction.cc file
WLSDetectorConstruction.cc (36.4 KB)
for reference as well.
scintillation_output.txt (1.5 KB)
