I am attempting to enable user step limits in a specific volume (“boundaryPV”; spans 150x150x5000mm) via the G4UserLimits class. The volume boundaryPV holds a daughter volume (“daughterPV”) which does not share edges with boundaryPV. The simulation obeys my limits while inside boundaryPV, but seems to occasionally fail when entering boundaryPV.
For example of a successful entrance, see:
*** G4Navigator::ComputeStep: ***
Volume = World - Proposed step length = 91.1478
----- Upon exiting :
The current state of G4Navigator is:
ValidExitNormal= 0 ExitNormal = (0,0,0) Exiting = 0 Entering = 1 BlockedPhysicalVolume= boundaryPV
BlockedReplicaNo = -1 LastStepWasZero = 0
Current Localpoint = (-16.773248,3.6383308,-2565.7303)
PreviousSftOrigin = (-16.773248,3.6383308,-2565.7303)
PreviousSafety = 65.726752
Returned step= 65.7303 Safety = 65.7268
*** G4Navigator::LocateGlobalPointAndSetup: ***
Called with arguments:
Globalpoint = (-16.779452,3.6378361,-2500)
RelativeSearch = 1
----- Upon entering:
Return value = new volume = boundaryPV
----- Upon exiting:
ValidExitNormal= 0 ExitNormal = (0,0,0) Exiting = 0 Entering = 0 BlockedPhysicalVolume= None
Current Localpoint = (-16.779452,3.6378361,-2500)
Volume = boundaryPV - Proposed step length = 1
PreviousSftOrigin = (-16.779452,3.6378361,-2500)
PreviousSafety = 0
Returned step= 9e+99 Requested step= 1 Safety = 0
However, the step limits are occasionally disobeyed when entering boundaryPV:
Volume = boundaryPV - Proposed step length = 166318
ValidExitNormal= 0 ExitNormal = (0,0,-1) Exiting = 0 Entering = 1 BlockedPhysicalVolume= daughterPV
Current Localpoint = (7.2337165,0.21567678,2500)
PreviousSftOrigin = (7.2337165,0.21567678,2500)
PreviousSafety = 0
Returned step= 1.1 Safety = 0
Globalpoint = (7.3085994,0.04244853,2498.9163)
RelativeSearch = 1
PreviousSafety = 0
Return value = new volume = daughterPV
----- Upon exiting:
ValidExitNormal= 0 ExitNormal = (0,0,-1) Exiting = 0 Entering = 0 BlockedPhysicalVolume= None
Current Localpoint = (7.3085994,0.04244853,2498.9163)
PreviousSafety = 0
While looking for the cause, I have noted that in the successful case, the “Entering” flag is set to 0 when the particle is on the surface of boundaryPV while, in the failed case, this flag is 1. Additionally, the successful case has “BlockedPhysicalVolume” set to boundaryPV while the failed case has it set to daughterPV.
Any suggestions as to why this failure occurs and how I can fix it?
Thank you!
