I need to store the initial particle’s trajectory vertices into a root file. How do I do it in the simplest way?
If it’s only the original origin point of the primary, you can get this in your event action class. You should create a class that inherits G4UserEventAction and implement the EndOfEvent action method
virtual void EndOfEventAction(const G4Event* anEvent);
In this, you can do anEvent->GetPrimaryVertex().
If you wish to store all of the 3D points along the trajectory for the primary, you should create a class that inherits G4UserTrackingAction and implement the method
virtual void PreUserTrackingAction(const G4Track* aTrack)
Something like:
void MyUserTrackingAction::PreUserTrackingAction(const G4Track* aTrack)
if (aTrack->GetParentID() == 0) // a primary
{fpTrackingManager->SetStoreTrajectory(1);}
else
{fpTrackingManager->SetStoreTrajectory(0);}
You should only do this only for the tracks you want and not all tracks as this will use a lot of memory!
You can collect the information in your EndOfEventAction with G4TrajectoryContainer* trajCont = event->GetTrajectoryContainer();.
See: Tracking — Book For Application Developers 11.0 documentation
You may also consider using SetStoreTrajectory(3) which will use G4RichTrajectory with G4RichTrajectoryPoints that has a lot of extra information.
Cheers,
Laurie
