Simulation description
Purpose: Get the cross-section of different EM process
Reference code: Lampe_XScompare
Physics Constructor: G4EmDNAPhysics_option6(CPA100 model)
Geant4 version: Geant4.10.06
Problem
Get different cross-section data compared with literature,Why?
Partial results:
#Energy(MeV) | #sigma(mm^-1) | #sigmadiff(10^-20m2) |
1.1e-05 | 9.19003e+06 | 147.24 |
0.000111 | 1.15671e+06 | 18.5325 |
0.000211 | 713479 | 11.4312 |
0.000311 | 533342 | 8.54508 |
0.000411 | 435255 | 6.97355 |
0.000511 | 370686 | 5.93904 |
0.000611 | 324001 | 5.19106 |
0.000711 | 288235 | 4.61803 |
0.000811 | 260041 | 4.16632 |
0.000911 | 237221 | 3.8007 |
0.001011 | 218058 | 3.49367 |
0.001111 | 201939 | 3.23542 |
0.001211 | 187985 | 3.01185 |
0.001311 | 175925 | 2.81862 |
0.001411 | 165367 | 2.64947 |
0.001511 | 156064 | 2.50043 |
0.001611 | 147692 | 2.36629 |
0.001711 | 140207 | 2.24637 |
0.001811 | 133477 | 2.13854 |
0.001911 | 127358 | 2.0405 |
0.002011 | 121779 | 1.95111 |
0.002111 | 116697 | 1.86969 |
0.002211 | 112015 | 1.79467 |
0.002311 | 107695 | 1.72547 |
0.002411 | 103704 | 1.66152 |
0.002511 | 99990 | 1.60202 |
0.002611 | 96540.6 | 1.54675 |
0.002711 | 93332.3 | 1.49535 |
0.002811 | 90331.4 | 1.44727 |
0.002911 | 87520.5 | 1.40223 |
0.003011 | 84877.1 | 1.35988 |
0.003111 | 82389.1 | 1.32002 |
0.003211 | 80045.3 | 1.28247 |
0.003311 | 77839 | 1.24712 |
0.003411 | 75755.9 | 1.21374 |
0.003511 | 73779.9 | 1.18208 |
0.003611 | 71899.6 | 1.15196 |
0.003711 | 70109.1 | 1.12327 |
0.003811 | 68415.1 | 1.09613 |
0.003911 | 66805.2 | 1.07034 |
0.004011 | 65264.8 | 1.04566 |
0.004111 | 63796.5 | 1.02213 |
0.004211 | 62395 | 0.999679 |
0.004311 | 61056.1 | 0.978226 |
0.004411 | 59774.8 | 0.957698 |
0.004511 | 58547.2 | 0.938029 |
0.004611 | 57363.7 | 0.919067 |
0.004711 | 56228.7 | 0.900884 |
0.004811 | 55140.5 | 0.883448 |
0.004911 | 54095.1 | 0.866699 |
0.005011 | 53089.3 | 0.850584 |
0.005111 | 52121.1 | 0.835073 |
0.005211 | 51188.2 | 0.820126 |
0.005311 | 50287.9 | 0.805701 |
0.005411 | 49419.8 | 0.791792 |
0.005511 | 48582.8 | 0.778382 |
0.005611 | 47774.8 | 0.765436 |
0.005711 | 46993.5 | 0.752919 |
0.005811 | 46236.2 | 0.740785 |
0.005911 | 45503.7 | 0.729049 |
0.006011 | 44794.7 | 0.71769 |
0.006111 | 44108.1 | 0.70669 |
0.006211 | 43443 | 0.696033 |
0.006311 | 42799 | 0.685715 |
0.006411 | 42174.8 | 0.675716 |
0.006511 | 41569.3 | 0.666013 |
0.006611 | 40980.2 | 0.656575 |
0.006711 | 40407.3 | 0.647396 |
0.006811 | 39850.7 | 0.638479 |
0.006911 | 39309.3 | 0.629804 |
0.007011 | 38782.3 | 0.62136 |
0.007111 | 38269.6 | 0.613147 |
0.007211 | 37770.9 | 0.605156 |
0.007311 | 37286.2 | 0.597391 |
0.007411 | 36814.2 | 0.589828 |
0.007511 | 36354.4 | 0.582461 |
0.007611 | 35906.2 | 0.575281 |
0.007711 | 35469.4 | 0.568282 |
0.007811 | 35043.3 | 0.561456 |
0.007911 | 34627.7 | 0.554797 |
0.008011 | 34222 | 0.548296 |
0.008111 | 33825.9 | 0.541951 |
0.008211 | 33439.2 | 0.535756 |
0.008311 | 33061.5 | 0.529703 |
0.008411 | 32692.1 | 0.523784 |
0.008511 | 32331.1 | 0.518001 |
0.008611 | 31978.2 | 0.512348 |
0.008711 | 31633.3 | 0.506821 |
0.008811 | 31296.1 | 0.501418 |
0.008911 | 30966.2 | 0.496133 |
0.009011 | 30643.4 | 0.490962 |
0.009111 | 30327.5 | 0.485901 |
0.009211 | 30018.5 | 0.480949 |
0.009311 | 29715.8 | 0.4761 |
0.009411 | 29419.4 | 0.471351 |
0.009511 | 29129.1 | 0.466699 |
0.009611 | 28844.7 | 0.462143 |
0.009711 | 28566 | 0.457678 |
0.009811 | 28292.8 | 0.453301 |
0.009911 | 28025 | 0.44901 |
0.010011 | 27762.4 | 0.444803 |
0.010111 | 27505 | 0.440678 |
0.010211 | 27252.4 | 0.436632 |
0.010311 | 27004.6 | 0.432662 |
0.010411 | 26761.4 | 0.428765 |
0.010511 | 26522.8 | 0.424942 |
0.010611 | 26288.6 | 0.421191 |
0.010711 | 26058.7 | 0.417507 |
0.010811 | 25833 | 0.41389 |
0.010911 | 25611.2 | 0.410336 |
0.011011 | 25393.3 | 0.406845 |
0.011111 | 25179 | 0.403413 |
0.011211 | 24968.5 | 0.40004 |
0.011311 | 24761.6 | 0.396725 |
0.011411 | 24558.2 | 0.393466 |
0.011511 | 24358.2 | 0.390262 |
0.011611 | 24161.9 | 0.387116 |
0.011711 | 23968.8 | 0.384023 |
**literature:**Julien Bordes,Université Paul Sabatier,phd thesis,2017
or incerti 2010,DOI:10.1118/1.3476457
Appendix
code:
G4String filename = G4String(particle + "_" + material + "_" + process + "_" +
G4UIcommand::ConvertToString(e_min) + "_" +
G4UIcommand::ConvertToString(e_max) + ".dat");
G4cout << "Saving cross section in :" << filename << G4endl;
// Get the cross section in G4Em PhysicsConstructor //
// Write to the file //
G4ParticleDefinition* particleDefinition = G4ParticleTable::GetParticleTable()->FindParticle(particle);
G4double density = mat->GetDensity();
G4cout << "Saving crossSection for " << particleDefinition->GetParticleName()
<< "in material" << mat->GetName() << "its density:" << density
<< ".Process" << process << "Cut:" << cut / keV << "keV." << G4endl;
std::ofstream file(filename, std::ofstream::out);
file << "#Energy(MeV)" << "\t" << "#sigma(mm^-1)" << "\t" << "#sigmadiff(10-20m2)" << std::endl;
G4EmCalculator* calculator = new G4EmCalculator();
calculator->SetVerbose(0);
G4double energy = e_min;
G4double macroCrossSection;
G4double microCrossSection;
//write to the file
while(energy < e_max)
macroCrossSection = calculator->ComputeCrossSectionPerVolume(energy, particleDefinition, process, mat, cut) * mm;
microCrossSection = macroCrossSection / density /(1e-20*m2);
file << energy << "\t" << macroCrossSection << "\t" << microCrossSection << std::endl;
//G4cout << "process:" << process << G4BestUnit(microCrossSection, "Surface/Mass") << G4endl;
energy += 100 * eV;
file.close();
mac
/run/verbose 0
# Load Physics
/phys/addPhysics G4EmDNAPhysics_option6
/run/setCut 1 nm
/cuts/setLowEdge 10 eV
#activate deexcitation
/process/em/auger true
/process/em/augerCascade true
/process/em/pixe true
/process/em/fluo true
#/process/list
/run/initialize
# Check that the simulation functions as expected
/gun/energy 10 keV
/gun/particle e-
/run/beamOn 1
# Save a cross-section (particle material process min_en max_en, cut)
# Energies are in MeV, cut in keV
/phys/printcs e- water msc 0.000011 0.3 0.011
/phys/printcs e- water eIoni 0.000011 0.3 0.011
/phys/printcs e- water e-_G4DNAElectronSolvation 0.000011 0.3 0.011
/phys/printcs e- water e-_G4DNAElastic 0.000011 0.3 0.011
/phys/printcs e- water e-_G4DNAExcitation 0.000011 0.3 0.011
/phys/printcs e- water e-_G4DNAIonisation 0.000011 0.3 0.011
/phys/printcs e- water e-_G4DNAAttachment 0.000011 0.3 0.011
/phys/printcs e- water CoulombScat 0.000011 0.3 0.011
/phys/printcs e- water e-_G4DNAVibExcitation 0.000011 0.3 0.011
