I build a 500nm cube with a 100nm sphere inside. The warning message always pops up at runtime as follows,and the program will suddenly stop running, should I modify the physical process or geometry ?
*** G4Exception : GeomNav1002
Stuck Track: potential geometry or navigation problem.
Track stuck, not moving for 10 steps.
Current phys volume: ‘WaterCubePhysVol’
- at position : (0,0,2.272489531138023e-05)
in direction: (-0.7861613457480034,-0.5962365404035369,0.1626417115604408)
(local position: (0,0,2.272489531138023e-05))
(local direction: (-0.7861613457480034,-0.5962365404035369,0.1626417115604408)).
Previous phys volume: ‘SpherePhysVol’
Likely geometry overlap - else navigation problem !
*** Trying to get unstuck using a push - expanding step to 1e-07 (mm) … Potential overlap in geometry !
