Symbol lookup error
_Geant4 Version:_Geant4.11.2.2
_Operating System:_Ubuntu22.04
_Compiler/Version:Visual Studio Code 1.93.1
OS: Linux x64 6.8.0-40-generic snap
_CMake Version:_3.22.1
Crash information as follows:
but it work normally if run the terminal of the Ubuntu. the above happen in the Visual Studio. The help is very appreciated,
From a quick Google of the error message, this looks like it may be an issue with the VScode Snap package. See an example and possible solution here:
Thank you for your link. this is a simple solution to fix the problem.
But I saw a phonomenon thant the Visual Display is flashing and display black screen. Then we find one solution to address the phonomenon, operation as follows:
need to find /etc/gdm3/custom.conf, modify the “#WaylandEnable=false” into “WaylandEnable=false”, then input"sudo systemctl restart gdm3" in the terminal.
By the above operation, we will fix the Visual proble. I hope to help people who have encountered such problems.
Glad it’s sorted, and thanks for the pointer on Wayland in this case.
