Geant4 Version: geant4-11-02-patch-02
Operating System: Ubuntu 22.04.4
Compiler/Version: gcc 11.4.0
CMake Version: 3.22.1
Dear G4 experts,
I have been trying to study e+ e- pair creation with the G4BetheHeitler5DModel
in the extended/electromagnetic/TestEm15
example. It seems however that the provided macro file gamma.mac
(and also the similar gamma2mumu.mac
) is outdated/broken.
I run the macro file provided together with the example in the G4 source code as
./TestEm15 gamma.mac
There are several issues:
The line
/testem/phys/addPhysics emstandard5D
in
gamma.mac
causes the error messagePhysicsList::AddPhysicsList: <emstandard5D> is not defined
(but the program continues and finishes with exit code zero). I replaced this with/testem/phys/addPhysics emstandard_opt4
and then the error disappears.
However, now the lines
/process/inactivate phot /process/inactivate compt /process/inactivate Rayl /process/inactivate GammaToMuPair
cause an exception:
-------- WWWW ------- G4Exception-START -------- WWWW ------- *** G4Exception : UIMAN0123 issued by : G4UImanager::ApplyCommand illegal process (or type) name [phot] Error code : 1 *** This is just a warning message. *** -------- WWWW -------- G4Exception-END --------- WWWW ------- ***** Illegal parameter (1) </process/inactivate phot> *****
I can remove them, but this will counteract the purpose stated in
README.gamma
: “All discrete processes are inactivated (see macro), so Gamma Conversion is ‘forced’.” -
Finally the histogram relevant to studying the conversion of polarized gammas, histogram 16, “Gamma Conversion. Phi of Gamma Polarization”, which is actived by
/analysis/h1/set 16 100 -{pi} {pi} none # Phi of Gamma Polarization
only has entries at phi=0, which is clearly unphysical. I suspect that the
is not used at all in the current state of the example.
Any help by the experts would be greatly appreciated.
Best regards
Henning
