Those are ROOT classes. Do you have your ROOT installation included in your environment? At a minimum, you should see an environment variable $ROOTSYS set, pointing to the ROOT installation.
Typically you get it set up with source <root-install-path>/bin/thisroot.sh on a Unix system.
Read the ROOT documentation to find out what to do on a Windows machine.
C:\B1\src\StackingAction.cc(40,10): fatal error C1083: Non è possibile aprire il file inclusione: 'TH1D.h': No such fil
e or directory [C:\B1\B1-build\exampleB1.vcxproj]
Given that I use my Geant only to test the simulation, but I lunch it on laboratory machine (where it is installed cvmfs), I also tried to lunch it on laboratory machine but it doesn’t work on cvmfs too…
[100%] Linking CXX executable exampleB1
CMakeFiles/exampleB1.dir/src/StackingAction.cc.o: In function `__static_initialization_and_destruction_0':
/cvmfs/sft.cern.ch/lcg/views/LCG_geant4ext20201111/x86_64-centos7-gcc8-opt/include/TVersionCheck.h:31: undefined reference to `TVersionCheck::TVersionCheck(int)'
make[2]: *** [exampleB1] Error 1
make[1]: *** [CMakeFiles/exampleB1.dir/all] Error 2
make: *** [all] Error 2
# Locate sources and headers for this project
# NB: headers are included so they will show up in IDEs
include_directories(${PROJECT_SOURCE_DIR}/include
${PROJECT_SOURCE_DIR}/shared/include
${Geant4_INCLUDE_DIR}
${ROOT_INCLUDE_DIRS})
file(GLOB sources ${PROJECT_SOURCE_DIR}/src/*.cc
${PROJECT_SOURCE_DIR}/shared/src/*.cc)
file(GLOB headers ${PROJECT_SOURCE_DIR}/include/*.hh
${PROJECT_SOURCE_DIR}/shared/include/*.hh)
# Add the executable, and link it to the Geant4 libraries
add_executable(exampleB1 exampleB1.cc ${sources} ${headers})
target_link_libraries(exampleB1 ${Geant4_LIBRARIES} ${ROOT_LIBRARIES})
C:\B1\B1-build>cmake --build . --config Release
Microsoft (R) Build Engine versione 16.11.2+f32259642 per .NET Framework
Copyright (C) Microsoft Corporation. Tutti i diritti sono riservati.
Checking Build System
Building Custom Rule C:/B1/CMakeLists.txt
exampleB1.cc
B1ActionInitialization.cc
B1DetectorConstruction.cc
B1EventAction.cc
B1PrimaryGeneratorAction.cc
B1Run.cc
B1RunAction.cc
B1SteppingAction.cc
DetectorMessenger.cc
MGGerdaLocalMaterialTable.cc
StackingAction.cc
gem90PhysListEmLowEnergy.cc
gem90PhysListHadron.cc
gem90PhysListParticles.cc
gem90PhysicsList.cc
gem90PhysicsListMessenger.cc
C:\root_v6.26.02\include\TString.h(509,58): warning C4273: '_stricmp': collegamento dll non coerente (compilazione del
file di origine C:\B1\src\StackingAction.cc) [C:\B1\B1-build\exampleB1.vcxproj]
C:\Program Files (x86)\Windows Kits\10\Include\10.0.19041.0\ucrt\string.h(189,22): message : vedere la precedente defin
izione di '_stricmp' (compilazione del file di origine C:\B1\src\StackingAction.cc) [C:\B1\B1-build\exampleB1.vcxproj]
StackingAction.obj : error LNK2019: riferimento al simbolo esterno "public: __cdecl TVersionCheck::TVersionCheck(int)"
(??0TVersionCheck@@QEAA@H@Z) non risolto nella funzione "void __cdecl ROOT::Internal::`dynamic initializer for 'gVersio
nCheck''(void)" (??__EgVersionCheck@Internal@ROOT@@YAXXZ) [C:\B1\B1-build\exampleB1.vcxproj]
C:\root_v6.26.02\lib\libCore.lib : warning LNK4272: il tipo 'x86' del computer della libreria è in conflitto con il tip
o 'x64' del computer di destinazione [C:\B1\B1-build\exampleB1.vcxproj]
C:\root_v6.26.02\lib\libImt.lib : warning LNK4272: il tipo 'x86' del computer della libreria è in conflitto con il tipo
C:\root_v6.26.02\lib\libRIO.lib : warning LNK4272: il tipo 'x86' del computer della libreria è in conflitto con il tipo
C:\root_v6.26.02\lib\libNet.lib : warning LNK4272: il tipo 'x86' del computer della libreria è in conflitto con il tipo
C:\root_v6.26.02\lib\libHist.lib : warning LNK4272: il tipo 'x86' del computer della libreria è in conflitto con il tip
C:\root_v6.26.02\lib\libGraf.lib : warning LNK4272: il tipo 'x86' del computer della libreria è in conflitto con il tip
C:\root_v6.26.02\lib\libGraf3d.lib : warning LNK4272: il tipo 'x86' del computer della libreria è in conflitto con il t
ipo 'x64' del computer di destinazione [C:\B1\B1-build\exampleB1.vcxproj]
C:\root_v6.26.02\lib\libGpad.lib : warning LNK4272: il tipo 'x86' del computer della libreria è in conflitto con il tip
C:\root_v6.26.02\lib\libROOTDataFrame.lib : warning LNK4272: il tipo 'x86' del computer della libreria è in conflitto c
on il tipo 'x64' del computer di destinazione [C:\B1\B1-build\exampleB1.vcxproj]
C:\root_v6.26.02\lib\libTree.lib : warning LNK4272: il tipo 'x86' del computer della libreria è in conflitto con il tip
C:\root_v6.26.02\lib\libTreePlayer.lib : warning LNK4272: il tipo 'x86' del computer della libreria è in conflitto con
C:\root_v6.26.02\lib\libRint.lib : warning LNK4272: il tipo 'x86' del computer della libreria è in conflitto con il tip
C:\root_v6.26.02\lib\libPostscript.lib : warning LNK4272: il tipo 'x86' del computer della libreria è in conflitto con
C:\root_v6.26.02\lib\libMatrix.lib : warning LNK4272: il tipo 'x86' del computer della libreria è in conflitto con il t
C:\root_v6.26.02\lib\libPhysics.lib : warning LNK4272: il tipo 'x86' del computer della libreria è in conflitto con il
C:\root_v6.26.02\lib\libMathCore.lib : warning LNK4272: il tipo 'x86' del computer della libreria è in conflitto con il
C:\root_v6.26.02\lib\libThread.lib : warning LNK4272: il tipo 'x86' del computer della libreria è in conflitto con il t
C:\root_v6.26.02\lib\libROOTVecOps.lib : warning LNK4272: il tipo 'x86' del computer della libreria è in conflitto con
C:\B1\B1-build\Release\exampleB1.exe : fatal error LNK1120: 1 esterni non risolti [C:\B1\B1-build\exampleB1.vcxproj]
