The mac command from messenger is weird
the result below is from hard code:
the gamma current for 1.25 MeV gamma through 3cm lead
the gamma current for 1.25 MeV gamma through 6cm lead
the gamma current for 1.25 MeV gamma through 3cm germanium
the gamma current for 1.25 MeV gamma through 6cm germanium
the three results below are all from mac messenger
the parameters in hard code are: 3cm, germanium
when only changing material from germanium to lead, the result is:
when only changing thickness from 3cm to 6cm, the result is:
when changing material from germanium to lead, and changing thickness from 3cm to 6cm, the result is:
so when only changing one parameter, the result is ok,
but when changing all the two parameters, it seems the material did not changed successfully.
why?
_Geant4 Version:_Geant4 11.1.1
_Operating System:_Ubuntu 20.04
_Compiler/Version:_GCC 9.4.0
_CMake Version:_3.16.3
sorry, the second figure and the third figure are exchanged.
Is this the same problem/result of that already posted in The class DetectorConstrution was only implemented once in many runs ?
No, not the same case.
