The problem of Stuck Track: potential geometry or navigation problem. Track stuck, not moving for 10 steps
_Geant4 Version:_geant4-10-06-patch-03 (6-November-2020)
_Operating System:_Linux
Compiler/Version:(Ubuntu 9.4.0-1ubuntu1~20.04.2) 9.4.0
_CMake Version:_3.16.0
Hello everyone,
When I try to load a phantom in .h33 and .i33 format into GATE for simulation, I encounter the following issue. This problem occurs when I set the pixel size to 1x1x1 mm. However, if I set it to 2x2x2 mm, the issue does not occur. But my research requires the 1x1x1 mm resolution. Could anyone tell me how to solve this problem? I would be very, very grateful.
*** G4Exception : GeomNav1002
Track stuck, not moving for 10 steps.
Current phys volume: ‘phantom_ncat_physVol’
  • at position : (-14.34092508578862,4.707447542417131,23)
    in direction: (-0.5982347889668695,-0.7131925791212912,-0.3653374910354614)
    (local position: (0.1590749142113772,0.2074475424171309,-0.5))
    (local direction: (-0.5982347889668695,-0.7131925791212912,-0.3653374910354614)).
    Previous phys volume: ‘phantom_ncat_physVol’
Likely geometry overlap - else navigation problem !
*** Trying to get unstuck using a push - expanding step to 1e-07 (mm) … Potential overlap in geometry !
When the voxel size is reduced enough that the track experiences zero steps, a warning about a stuck track appears.
Since the problem encountered from Navigator therefore, in your GATE simulation, you can check
G4Navigator.CC and make following changes,
Step += 100*kCarTolerance;*
by
*Step += kCarTolerance*std::pow(10.,fNumberZeroSteps);
Ref.: Geant4.10: G4Navigator.cc Source File
[Look line 954.]
VRS
Thank you very much! I will try the method you suggested.
