Geant4 Version: geant-v11.4.0
Operating System: Ubuntu 24.04
Compiler/Version: gcc (Ubuntu 13.3.0-6ubuntu2~24.04.1) 13.3.0
CMake Version: cmake version 3.28.3
Dear experts,
I am a beginner with the Geant4 toolkit. I have developed a multithreaded computing program for counting the neutrons emitted after heavy ion bombardment of a lead target. Here are the codes for MySensitiveDetector.cc and RunAction.cc that I wrote.
G4bool MySensitiveDetector::ProcessHits(G4Step* step, G4TouchableHistory* history){ G4AnalysisManager* analysisManager = G4AnalysisManager::Instance(); if(step->GetTrack()->GetDefinition() != G4Neutron::Neutron()) return false; if(!step->IsFirstStepInVolume()) return false; G4double energy = step->GetPreStepPoint()->GetKineticEnergy() / MeV; G4ThreeVector direction = step->GetPreStepPoint()->GetMomentumDirection(); G4double theta = direction.theta() / deg; if(theta >= 0.0 && theta < 2.4) analysisManager->FillH1(0, energy); else if(theta >= 2.5 && theta < 7.5) analysisManager->FillH1(1, energy); else if(theta >= 12.5 && theta < 17.5) analysisManager->FillH1(2, energy); else if(theta >= 28.5 && theta < 32.5) analysisManager->FillH1(3, energy); else if(theta >= 42.5 && theta < 47.5) analysisManager->FillH1(4, energy); else if(theta >= 58.5 && theta < 62.5) analysisManager->FillH1(5, energy); else if(theta >= 72.5 && theta < 77.5) analysisManager->FillH1(6, energy); return true; }
RunAction::RunAction() { G4AnalysisManager* analysisManager = G4AnalysisManager::Instance(); #ifdef G4MULTITHREADED analysisManager->SetNtupleMerging(true); #endif analysisManager->SetVerboseLevel(1); analysisManager->OpenFile("yield.root"); for (size_t i = 0; i < 7; ++i) { std::ostringstream nameStream; nameStream << "h" << i+1; G4String hname = nameStream.str(); G4String htitle = "Neutron double differential yield;Neutron Energy [MeV];d^{2}N/(dE d#Omega) [MeV^{-1} sr^{-1}]"; analysisManager->CreateH1(hname, htitle, 2000, 0.0, 2000.0); } } RunAction::~RunAction() {} void RunAction::BeginOfRunAction(const G4Run* run) { std::vector<G4HadronicInteraction *> interactions = G4HadronicInteractionRegistry::Instance() ->FindAllModels(G4INCLXXInterfaceStore::GetInstance()->getINCLXXVersionName()); for(std::vector<G4HadronicInteraction *>::const_iterator iInter=interactions.begin(), e=interactions.end(); iInter!=e; ++iInter) { G4INCLXXInterface *theINCLInterface = static_cast<G4INCLXXInterface*>(*iInter); if(theINCLInterface) { // Instantiate the ABLA model G4HadronicInteraction *interaction = G4HadronicInteractionRegistry::Instance()->FindModel("ABLA"); G4AblaInterface *theAblaInterface = static_cast<G4AblaInterface*>(interaction); if(!theAblaInterface) theAblaInterface = new G4AblaInterface; // Couple INCL++ to ABLA G4cout << "---------------------------------------------" << G4endl << "-----------------Coupling INCLXX to ABLA-----------" << G4endl << "---------------------------------------------" << G4endl; theINCLInterface->SetDeExcitation(theAblaInterface); } } } void RunAction::EndOfRunAction(const G4Run* run) { G4AnalysisManager* analysisManager = G4AnalysisManager::Instance(); G4long nEvents = run->GetNumberOfEventToBeProcessed(); if (nEvents == 0) return; if(IsMaster()) { incidentParticles = run->GetNumberOfEventToBeProcessed(); G4cout << "incident particles: " << incidentParticles << G4endl; G4double dE = 1.0; // MeV for (int i = 0; i < 7; ++i) { double theta1 = angleMin[i] * M_PI / 180.0; double theta2 = angleMax[i] * M_PI / 180.0; double dOmega = 2.0 * M_PI * std::abs(std::cos(theta1) - std::cos(theta2)); double scale = 1.0 / (incidentParticles * dE * dOmega); analysisManager->ScaleH1(i, scale); } } analysisManager->Write(); analysisManager->CloseFile(); }
When I was running the program, I encountered the following problems:
(1) If I use 100 threads and the number of incident particles is 1e7, the program can run normally and produce the correct results. However, if I increase the number of incident particles to 1e8, the program will be terminated. I checked the memory usage during runtime, and the memory would exceed the computer’s memory (521G) when the number of incident particles reached 5e7. I wonder if there is an error in my code that caused this situation.
(2) If I use 300 threads, the program will not run and will display the following error:
G4WT294 > **** Track information is not available at this moment
G4WT148 >
*** G4Exception : ABLA
issued by : G4AblaDataFile::readData()
Data missing: could not find ABLA data file in /mnt/1c05098b-4371-462d-bda4-30f438a4ea53/liqin/software/geant4/geant4-v11.4.0-install/share/Geant4/data/G4ABLA3.3defined by environment variable G4ABLADATA*** Fatal Exception *** core dump ***
G4WT294 > **** Step information is not available at this moment
G4WT294 >
-------- EEEE -------- G4Exception-END --------- EEEE -------G4WT294 >
G4WT294 > *** G4Exception: Aborting execution ***
srun: error: compute1: task 0: Aborted (core dumped)
Could you please tell me what caused this?
If you could help me solve the aforementioned problems, I would be extremely grateful.
Best wishes.
