Hi all,
I use the G4GeneralParticleSource class and UI comands to define a particle source with energy spectrum. Let’s denote the spectrum p_i, and i is the index of bins related to energy. In a run (sampling) N particles are simulated. If we focus on a perticular bin i, then this bin should have N*p_i particles . But the number N*p_i is its expectation value, not the real number of particles in the bin i, and the real number in bin i is not same in each run. Since it’s a binomial distribution with probability p_i and N times expriments, its real number generated in bin i should have variance var=N*p_i(1-p_i)
My question is that can geant4 handle this randomness automaticly or it only generate N*p_i particles in the bin i? I don’t know that if I defined a energy spectrum using UI command /gps/hist/point energy probability do I need some commands to deal with the randomness of its distribution.
