Dear Geant4 experts,
I have found a bug in the visualization of G4Hype. Please see following figure with line segment set to 3:
The inner vertex is not correct at -halfZ.
I have a look at the source code of HepPolyhedronHype (source/graphics_reps/src/HepPolyhedron.cc) and found the problem is due to the wrong size of the inner polyline.
Following is the outer polyline, the size is n and the index is from 0 to n-1. It’s correct.
zz[0] = halfZ;
rr[0] = std::sqrt(sqrtan2halfZhalfZ+k2);
for(G4int i = 1; i < n-1; i++)
zz[i] = zz[i-1] - dz;
rr[i] =std::sqrt(sqrtan2*zz[i]*zz[i]+k2);
zz[n-1] = -halfZ;
rr[n-1] = rr[0]; -
However, for the inner polylines, the size is n+1, which is wrong:
zz[n] = halfZ;
rr[n] = std::sqrt(sqrtan1halfZhalfZ+k1);
for(G4int i = n+1; i < n+n; i++) // fix1: n+n -> n+n-1
rr[i] =std::sqrt(sqrtan1*zz[i]*zz[i]+k1);
zz[n+n] = -halfZ; // fix2: this should be n+n-1
rr[n+n] = rr[n]; // fix3: also n+n-1
Thank you!
Tao Lin
IHEP, Beijing
