Thermal Neutron Crosssections in Geant v11.3
Geant4 Version: 11.3.2
Operating System: AlmaLinux 9.8
Compiler/Version: GCC version 11.5.0
CMake Version: 3.31.8
Hi everybody. I am wondering what the correct way to treat thermal neutrons within Geant4. The physics list I am using is QSP_BIC_HPT. To my Knowledge the treatment of thermal neutrons has changed in recent years. Is it sufficient to register materials via NIST, or do I need to register each element with the adequate naming schemes. If that is the case, I would appreciate some information on what the current naming scheme looks like, since previous attempts of mine to include thermal crosssections that way failed.
Thanks in advance for your help!
Hi, you can download CS from GEANT 4 Libraries , follow the instruction in readme, then export them via export G4NEUTRONHPDATA=$GEANT4_DATA_DIR/JEFF-4.0. For example JEFF-4.0 (probably the most actual). Or download G4TENDL1.4 from Download Geant4-11.4.2 - Geant4 and do export G4PARTICLEHPDATA=$GEANT4_DATA_DIR/G4TENDL1.4. The you can use QGSP_BIC_AllHP.
