I realised that the radioisotope Tm162 (which is produced by the radioactive decay process in one of my simulations) does not have an entry in the RadioactiveDecay 5.6 database (the file z69.a162 is missing), although it decays with an half-life of 21 min (e.g., as reported in NUDAT 3.0, although in that database there is detailed decay information only for an isomeric state with ~24 s half-life)
Am I missing something there?
Cheers
R
Hi R.,
Thank you very much for reporting this. I noticed that the file was dropped some time ago. I have opened a bugzilla ticket for this issue.
As a workaround, could you please add the following file [1] manually?
In my case, the file is placed here: /usr/local/geant4/data/RadioactiveDecay5.6/z69.a162
# 162TM (21.70 m)
#  Excitation   Halflife Mode       Daughter Ex  Intensity           Q
# 162TM (24.3 s)
# File sanitized by Vanderbilt Decay-o-matic
# $Id: repair_decay_files.py,v 1.20 2006/04/24 14:53:36 marcus Exp $
# Fri Oct  6 15:26:23 2006
P       0.0000   1.3020e+03
                          MshellEC       0.0000   2.3190e-02
                          BetaPlus       0.0000   3.9010e-01
                          KshellEC       0.0000   5.0850e-01
                          LshellEC       0.0000   7.8170e-02
                          MshellEC       0.0000   1.8860e-02    4839.0000
                          MshellEC     102.0400   5.6470e-02    4736.9600
                          MshellEC     900.7400   7.5790e-03    3938.2600
                          MshellEC    1002.1200   2.7230e-02    3836.8800
                          MshellEC    1352.1700   6.8480e-03    3486.8300
                          MshellEC    1420.4600   6.0800e-02    3418.5400
                          MshellEC    1506.3600   1.5190e-02    3332.6400
                          MshellEC    1572.8900   2.3560e-01    3266.1100
                          MshellEC    3435.8000   7.1220e-03    1403.2000
                          BetaPlus       0.0000   9.0000e-01    4839.0000
                          BetaPlus     102.0400   2.6000e+00    4736.9600
                          BetaPlus     900.7400   2.0000e-01    3938.2600
                          BetaPlus    1002.1200   2.0000e-01    3836.8800
                          BetaPlus    1352.1700   9.0000e-02    3486.8300
                          BetaPlus    1420.4600   7.4000e-01    3418.5400
                          BetaPlus    1506.3600   2.0000e-01    3332.6400
                          BetaPlus    1572.8900   2.4000e+00    3266.1100
                          KshellEC       0.0000   4.1750e-01    4839.0000
                          KshellEC     102.0400   1.2530e+00    4736.9600
                          KshellEC     900.7400   1.6690e-01    3938.2600
                          KshellEC    1002.1200   5.8140e-01    3836.8800
                          KshellEC    1352.1700   1.5010e-01    3486.8300
                          KshellEC    1420.4600   1.3340e+00    3418.5400
                          KshellEC    1506.3600   3.3360e-01    3332.6400
                          KshellEC    1572.8900   5.1700e+00    3266.1100
                          KshellEC    3435.8000   1.4900e-01    1403.2000
                          LshellEC       0.0000   6.3650e-02    4839.0000
                          LshellEC     102.0400   1.9050e-01    4736.9600
                          LshellEC     900.7400   2.5540e-02    3938.2600
                          LshellEC    1002.1200   9.1370e-02    3836.8800
                          LshellEC    1352.1700   2.3040e-02    3486.8300
                          LshellEC    1420.4600   2.0490e-01    3418.5400
                          LshellEC    1506.3600   5.1240e-02    3332.6400
                          LshellEC    1572.8900   7.9480e-01    3266.1100
                          LshellEC    3435.8000   2.3840e-02    1403.2000
P      66.9000   2.4300e+01
                          MshellEC       0.0000   3.7370e-03
                          BetaPlus       0.0000   6.9610e-02
                          KshellEC       0.0000   9.4080e-02
                          LshellEC       0.0000   1.2570e-02
                                IT       0.0000   8.2000e-01
W [VU repair system] Huge Q discrepancy, Qfile-Qtheor=-67.01 keV
                          MshellEC     667.0100   2.0600e-02    4171.9900
                          MshellEC    1128.5000   1.1460e-02    3710.5000
                          MshellEC    1712.0900   2.7640e-01    3126.9100
                          BetaPlus     329.5300   2.0160e+00    4509.4700
                          BetaPlus     667.0100   7.0560e-01    4171.9900
                          BetaPlus    1128.5000   2.0160e-01    3710.5000
                          BetaPlus    1712.0900   2.8220e+00    3126.9100
                          KshellEC     329.5300   1.0080e+00    4509.4700
                          KshellEC     667.0100   4.5440e-01    4171.9900
                          KshellEC    1128.5000   2.5240e-01    3710.5000
                          KshellEC    1712.0900   6.0510e+00    3126.9100
                          LshellEC     667.0100   6.9310e-02    4171.9900
                          LshellEC    1128.5000   3.8580e-02    3710.5000
                          LshellEC    1712.0900   9.2980e-01    3126.9100
After adding the file I am able to see the gammas from Er as expected.
Best,
Alvaro
[1] The file corresponds to an older release, RadioactiveDecay3.7
