Howdy,
Working through my first GEANT4 project and I’ve run into a snag I can’t figure out. I’m using a sensitive detector on a logical volume that is created first via a division into adjacent anode strips along the ‘Y’ axis (400 of them in the current version) inside of a mother volume anode. This along with the other pieces of an element is placed with assembly volume because they need to step and rotate along ‘Z’. I didn’t see how to make a rotation on a replica or division and I will eventually be doing a parameter sweep for 2-1024 elements and would rather not place them all as physical volumes via loops.
With the output set to /tracking/verbose 2, I can see the particles moving and forming secondaries using the “av_WWW_impr_XXX_YYY_ZZZ” format for the volumes except for the steps in the anode strips where it’s just a name. I can’t find a way to access that XXX number in the step or any of it’s decedents. For particles that exit the volume I can pull it out of the GetNextVolume() method but if they reach 0 energy that field is just anode strips.
Any suggestions on where I can pull that assembly imprint number out of the step or any of it’s decendents?
Thanks
Geant4 version Name: geant4-10-07-patch-03 [MT] (19-November-2021)
Operating System:_CentOS Linux 7 (Core)
Compiler/Version:_Unsure, CMakeCache.txt looks like it’s pointed at spark-base inside of CentOS
CMake Version:_3.22.2
