Trying to upgrade to v11.1.1 from v10.7.4
Please fill out the following information to help in answering your question, and also see tips for posting code snippets
Geant4 Version: moving from v10.7.4 to v11.1.1
Operating System: Ubuntu 20
Compiler/Version: gcc 9.4.0
I am have compiled the code and linked external libraries (ROOT) successfully, with everything installed under the cxx17 standard–note I had to install root from source for this reason b/c the binary used cxx14.
In any case all compiled, user code seems to run OK at first but I get the following error, any ideas?
 Geant4 version Name: geant4-11-01-patch-01 [MT]   (10-February-2023)
                                 : IEEE-TNS 53 (2006), 270-278
                                 : NIM A 835 (2016), 186-225
                             WWW : http://geant4.org/
He isotope 1 is A = 3, relative abundance: 1.37e-06
He isotope 2 is A = 4, relative abundance: 0.999999
Is the He natural abundance distribution? 1
G4Material WARNING: duplicate name of material Aluminum
*** G4Exception : mat205
      issued by : G4MaterialPropertiesTable::AddProperty()
Attempting to create a new material property key SCINTILLATION without setting
createNewKey parameter of AddProperty to true.
This looks like one of the new features of Geant4 11, which is going to create problems for CDMS and for G4CMP. The materials property stuff now has a hardcoded list of name strings that it knows. It’ll throw an error if you try to set a key with a misspelled name (very useful!), and will also throw and error if you try to add a key that isn’t on the list.
If I read the error message correctly, there’s now an optional extra argument to AddProperty(), which you have to pass “true” if you’re sure you want to set a different key.
In your case, you may want to check the Release Notes, because SCINTILLATION may no longer be a valid key, replaced by a more complex set of keys.
