I am attempting to install g4py in order to interface with Geant4 via python (preferable python3). However after following all instructions I could find I am still unable to install it.
I am using a machine with Ubuntu 18.04 in WSL.
After downloading the source I install with the following compilation flags:
cmake .. -DGEANT4_BUILD_MULTITHREADED=ON \
-DGEANT4_USE_QT=ON -DGEANT4_USE_XM=ON -DGEANT4_USE_OPENGL_X11=ON \
-DGEANT4_USE_RAYTRACER_X11=ON -DGEANT4_INSTALL_DATA=ON -DGEANT4_USE_GDML=ON -DCMAKE_INSTALL_PREFIX=$HOME/opt/geant4-install-g4py
After the install is successful I begin to install g4py. I go to environments/g4py and follow the instructions in https://github.com/Geant4/geant4/tree/geant4-10.5-release/environments/g4py.
After defining GEANT4_INSTALL=$HOME/opt/geant4-install-g4py and running cmake .. -DCMAKE_INSTALL_PREFIX=$GEANT4_INSTALL everything seems to be working correctly until the very end where I get an error
This is the output of the cmake command:
-- The CXX compiler identification is GNU 7.4.0
-- Found Geant4: /home/lobis/opt/geant4-install-10.5-release-MT/bin/.. (10.5.1)
-- Found PythonInterp: /home/lobis/anaconda3/bin/python (found version "3.7.3")
-- Found PythonLibs: /home/lobis/anaconda3/lib/libpython3.7m.so (found version "3.7.3")
-- Boost version: 1.65.1
-- Found XercesC: /usr/lib/x86_64-linux-gnu/libxerces-c.so
-- Found ROOT 6.16/00 in /home/lobis/opt/root/root-6.16.00/install-gdml
-- Parameters for building
-- CMAKE_BUILD_TYPE: RelWithDebInfo
-- CMAKE_CXX_COMPILER: /usr/bin/c++
-- CMAKE_INSTALL_PREFIX: /home/lobis/opt/geant4-install-10.5-release-MT
-- Configuring done
-- Generating done
-- Build files have been written to: /home/lobis/opt/geant4/source/geant4/environments/g4py/build
attached you can find the output of the make command.
make_output.txt (28.7 KB)
These are the last lines of make command:
[ 94%] Building CXX object source/geometry/CMakeFiles/pyG4geometry.dir/pyG4Tubs.cc.o
[ 95%] Building CXX object source/geometry/CMakeFiles/pyG4geometry.dir/pyG4TwistedBox.cc.o
[ 95%] Building CXX object source/geometry/CMakeFiles/pyG4geometry.dir/pyG4TwistedTrap.cc.o
[ 96%] Building CXX object source/geometry/CMakeFiles/pyG4geometry.dir/pyG4TwistedTrd.cc.o
[ 96%] Building CXX object source/geometry/CMakeFiles/pyG4geometry.dir/pyG4TwistedTubs.cc.o
[ 96%] Linking CXX shared library G4global.so
[ 96%] Building CXX object source/geometry/CMakeFiles/pyG4geometry.dir/pyG4UniformMagField.cc.o
[ 96%] Built target pyG4global
[ 97%] Building CXX object source/geometry/CMakeFiles/pyG4geometry.dir/pyG4UnionSolid.cc.o
[ 97%] Building CXX object source/geometry/CMakeFiles/pyG4geometry.dir/pyG4VPhysicalVolume.cc.o
[ 97%] Building CXX object source/geometry/CMakeFiles/pyG4geometry.dir/pyG4VSolid.cc.o
[ 98%] Building CXX object source/geometry/CMakeFiles/pyG4geometry.dir/pyG4VTouchable.cc.o
[ 98%] Building CXX object source/geometry/CMakeFiles/pyG4geometry.dir/pymodG4geometry.cc.o
[100%] Linking CXX shared library G4geometry.so
[100%] Built target pyG4geometry
Makefile:140: recipe for target 'all' failed
make: *** [all] Error 2
(for some reason the % at it fails is different)
I could not find a way to configure the installation via cmake variables but in older versions I found this could be done via the configure script, I assume in the newer versions this is not necessary?
I look forward to hearing any advice, thanks!
