Understand error message
I am seeing this error message.
There are only two PV’s involved one being a WorldBox of Air.
Does the error indicate that there is a problem with the Tessellated Shape?
*** G4Exception : GeomNav1002
Stuck Track: potential geometry or navigation problem.
Track stuck, not moving for 10 steps.
Current phys volume: ‘worldVOL_PV’
  • at position :
    (0.007918293603451615,0.007364216430811409,0.97143501900167)
    in direction:
    (0.006492143872717035,0.01340386652329357,0.9998890880643521)
    (local position:
    (0.007918293603451615,0.007364216430811409,0.97143501900167))
    (local direction:
    (0.006492143872717035,0.01340386652329357,0.9998890880643521)).
    Previous phys volume: ‘AuPlateVol’
Likely geometry overlap - else navigation problem !
*** Trying to get unstuck using a push - expanding step to 1e-07
(mm) … Potential overlap in geometry !
AuPlate-Decimated-worldVOL.gdml.txt (57.0 KB)
