While running with Valgrind on GEANT 4.16.p01 I have a lot of messages like the one at the end. They all point to an uninitialized variable in the array created here
==215== by 0x1131C4E1: G4Material::AddMaterial(G4Material*, double) (G4Material.cc:487)
I have inspected the code and I do not believe it is a user error. I also do not think that there is something really intrinsically wrong with the code of GEANT4, although someone more familiar with this code should have a serious look. In any case, and to stay on the safe side, one could use a little known feature of C++03 to initialise a whole new array to 0. The git diff is the following
diff --git a/source/materials/src/G4Material.cc b/source/materials/src/G4Material.cc
index 5e2db45…2cc6d8d 100644
— a/source/materials/src/G4Material.cc
+++ b/source/materials/src/G4Material.cc
@@ -484,7 +484,7 @@ void G4Material::AddMaterial(G4Material* material, G4double fraction)
// initialization
if (fNumberOfComponents == 0) {
fMassFractionVector = new G4double[fArrayLength];
- fAtomsVector = new G4int [fArrayLength];
+ fAtomsVector = new G4int [fArrayLength]();
}G4int nelm = material->GetNumberOfElements();
Best regards.
==215== Use of uninitialised value of size 8
==215== at 0x4C2F023: __GI_memcpy (vg_replace_strmem.c:1037)
==215== by 0x12A93C88: __printf_fp_l (in /usr/lib64/libc-2.17.so)
==215== by 0x12A92486: vfprintf (in /usr/lib64/libc-2.17.so)
==215== by 0x12ABD098: vsnprintf (in /usr/lib64/libc-2.17.so)
==215== by 0x1201F48E: std::__convert_from_v(__locale_struct* const&, char*, int, char const*, …) (c++locale.h:92)
==215== by 0x1204D581: std::ostreambuf_iterator<char, std::char_traits > std::num_put<char, std::ostreambuf_iterator<char, std::char_traits > >::_M_insert_float(std::ostreambuf_iterator<char, std::char_traits >, std::ios_base&, char, char, double) const (locale_facets.tcc:1005)
==215== by 0x1205BDBD: put (locale_facets.h:2438)
==215== by 0x1205BDBD: std::ostream& std::ostream::_M_insert(double) (ostream.tcc:73)
==215== by 0x11A86EDE: operator<< (ostream:221)
==215== by 0x11A86EDE: operator<<(std::ostream&, G4BestUnit) (G4UnitsTable.cc:580)
==215== by 0x1131A6F9: operator<<(std::ostream&, G4Material const*) (G4Material.cc:744)
==215== by 0x1131AB28: operator<<(std::ostream&, std::vector<G4Material*, std::allocator<G4Material*> >) (G4Material.cc:787)
==215== by 0x422BE8: DetectorConstruction::ConstructGeom3() (DetectorConstruction.cc:816)
==215== by 0xAC29BF5: G4RunManager::InitializeGeometry() (G4RunManager.cc:611)
==215== Uninitialised value was created by a heap allocation
==215== at 0x4C2AB68: operator new(unsigned long) (vg_replace_malloc.c:433)
==215== by 0x418422: DetectorConstruction::DefineMaterials() (DetectorConstruction.cc:1671)
==215== by 0x41DAF2: DetectorConstruction::ConstructGeom3() (DetectorConstruction.cc:187)
==215== by 0xAC29A79: G4RunManager::Initialize() (G4RunManager.cc:587)
==215== by 0xAC32E78: G4MTRunManager::Initialize() (G4MTRunManager.cc:198)
==215== by 0x412235: main (mtinrtest.cc:259)
this time). If you add a material to a material and then add an element by number of atoms, the code fails catastrophically with no warning. It is clearly an user error, you cannot add half by weight and half by number of atoms, but what happens is the following (suppose you declare only two components):
