User defined distribution does not seem to work
Geant4 Version: Geant4v11
Operating System: macOS 15.7.3
Hi all,
I modified example hadr04 to try to modify neutron moderation. My use case requires generating neutrons with an arbitrary pointwise distribution. The application seems to work for monoenergetic neutrons; however, when I try with the arbitrary distribution, the neutrons are produced with the default value of 1 MeV and not as per the histogram.
Any thoughts on what the issue could be here?
Here are the relevant macro files that I’m using.
  1. moderation.mac
# Macro file for "Hadr04.cc"
# neutron 2 MeV; all processes
/control/verbose 2
/run/verbose 2
/testhadr/det/setMat HeavyWater
#/testhadr/det/setSize 20 cm
/testhadr/phys/thermalScattering true
/run/initialize
# Set the GPS source
/control/execute set_gps.mac
/analysis/setFileName Moderation_D20
/analysis/h1/set 1  100  0. 200. none	#nb colli >1eV
/analysis/h1/set 2  100  0. 5. m	#track len >1eV
/analysis/h1/set 3  100  0. 50. us	#time of flight >1eV
/analysis/h1/set 4  100  0. 10000. none	#nb colli <1eV
/analysis/h1/set 5  100  0. 100. m	#track len <1eV
/analysis/h1/set 6  100  0. 100. ms	#time of flight <1eV
/analysis/h1/set 7  100  0. 3 MeV 	#energy dist
/run/printProgress 200
/run/beamOn 500
  1. set_gps.mac
/control/execute vis.mac
# Use General Particle Source
/gps/particle neutron
#/gps/energy 2 MeV
/gps/position 0 0 0 cm
/gps/pos/type Point
# User defined
/gps/ene/type Arb
/gps/hist/type arb
/gps/hist/point 0.5 0.2
/gps/hist/point 1.0 0.2
/gps/hist/point 1.5 0.2
/gps/hist/point 2  0.8
/gps/hist/inter Lin
# Direction
/gps/ang/type iso
/gps/ang/mintheta 150 deg
/gps/ang/maxtheta 180 deg
I might be wrong, but don’t you need to configure GPS before /run/initialize?
Thank you, I was a bit careless and was just going off what was being printed in the verbose (I forgot to change that while modifying the histogram). The actual distribution was indeed user-defined, as I checked by filling a histogram.
