I try to use the User’s hook for state change from chapter 3.4.3 in the Book For Application Developers, Release 11.0.
The problem is that it doesn’t work as described in multi-threading mode.
I use Geant4 v11.0.0
and example B1
with little changes
diff_to_vanilla_B1_example.txt (3.3 KB)
I added UserHookForAbortState* uhfas = new UserHookForAbortState();
in main()
created UserHookForAbortState.hh and UserHookForAbortState.cc and force an exception in EventAction::BeginOfEventAction(const G4Event*)
Executing with env G4RUN_MANAGER_TYPE=Serial ./exampleB1 run.mac
in sequential mode behaves as expected:
output_Serial.txt (43.1 KB)
@@@ GetNumberOfEvent=3
@@@ in if
*** G4Exception : had006
issued by : G4HadronicProcess::PostStepDoIt
force this exception!
G4Track (0x2cc0818) - track ID = 4, parent ID = 3
Particle type : e- - creator process : phot, creator model : model_PhotoElectron
Kinetic energy : 0 eV - Momentum direction : (2.31839e-316,0.567689,-0.696325)
Step length : 200.482 nm - total energy deposit : 2.23031 keV
Pre-step point : (50.4612,-12.4468,-77.6538) - Physical volume : Envelope (G4_WATER)
- defined by : not available
Post-step point : (50.4611,-12.4468,-77.6539) - Physical volume : Envelope (G4_WATER)
- defined by : eIoni - step status : 3
*** Note: Step information might not be properly updated.
$$$$$$$$$$$$$$$$$$ 6
!!!!!!!!!! inside abort state handling!!!!!!!!!!
### CAUGHT SIGNAL: 6 ### address: 0x3e800001c34, signal = SIGABRT, value = 6, description = abort program (formerly SIGIOT).
But executing with env G4RUN_MANAGER_TYPE=MT ./exampleB1 run.mac
or ./exampleB1 run.mac
in MT mode the outcome is different:
output_MT.txt (42.3 KB)
G4WT0 > @@@ GetNumberOfEvent=3
G4WT0 > @@@ in if
G4WT0 >
G4WT0 > G4Track (0x7f6fec401f48) - track ID = 2, parent ID = 1
G4WT0 > Particle type : e- - creator process : conv, creator model : model_EplusEminisPair
G4WT0 > Kinetic energy : 0 eV - Momentum direction : (6.92278e-310,-0.874157,0.478461)
G4WT0 > Step length : 250.798 um - total energy deposit : 139.212 keV
G4WT0 > Pre-step point : (-3.20631,11.6247,4.5065) - Physical volume : Envelope (G4_WATER)
G4WT0 > - defined by : eIoni - step status : 3
G4WT0 > Post-step point : (-3.19546,11.5107,4.56888) - Physical volume : Envelope (G4_WATER)
G4WT0 > *** Note: Step information might not be properly updated.
G4WT0 >
G4WT0 >
G4WT0 > *** G4Exception: Aborting execution ***
### CAUGHT SIGNAL: 6 ### address: 0x3e800001bff, signal = SIGABRT, value = 6, description = abort program (formerly SIGIOT).
These two lines are missing, which is the part where the abort state handling should be done!
Can someone help me please?
Best regards
Henning
