_Geant4 Version:_11.2.2
_Operating System:_MacOS
_Compiler/Version:_Clang 17
_CMake Version:_3.31.0
—Dear experts,
I’m currently creating a simulation with a liquid Ar39 sphere around my detector. The Ar39 will decay and I’m trying to plot the location of vertex Ar39 that deposits energy which is contributed by Bremsstrahlung radiation in some way. However, when I try to get the position of my vertex using the following method, I kept getting location that is inside the detector, which does not make sense. In my construction file, I set my detector and the Ar39 sphere as
//building the detector
solidDetector = new G4Tubs(“solidDetector”, 0cm, 5cm, 20cm, 0deg, 360*deg);
logicDetector = new G4LogicalVolume(solidDetector, Ge76Mat, “logicalDetector”);
physDetector = new G4PVPlacement(0, G4ThreeVector(0, 0, 0), logicDetector, “physDetector”, logicWorld, false, 0, true);
fScoringVolume = logicDetector;
// Create full sphere first
G4Sphere* fullSphere = new G4Sphere(“fullSphere”, 0.cm, 40cm, 0deg, 360deg, 0deg, 180deg);
// Create the argon sphere with detector hole
solidArSphere = new G4SubtractionSolid(“solidArSphere”, fullSphere, solidDetector);
logicArSphere = new G4LogicalVolume(solidArSphere, Ar39Mat, “logicalArSphere”);
physArSphere = new G4PVPlacement(0, G4ThreeVector(0, 0, 0), logicArSphere, “physArSphere”, logicWorld, false, 0, true);
and in my macro file run.mac, I set
Set the number of threads for multi-threaded mode
/run/numberOfThreads 6
Initialize the run
/run/initialize
Set up the GPS for Ar39 decay
/gps/particle ion
/gps/ion 18 39 0
/gps/energy 0 keV
Use confined source to exclude detector volume
/gps/pos/type Volume
/gps/pos/shape Sphere
/gps/pos/centre 0. 0. 0. cm
/gps/pos/radius 40 cm
/gps/pos/confine physArSphere
Isotropic angular distribution
/gps/ang/type iso
Set the activity of the source
/gps/source/intensity 1.0
Run events
/run/beamOn 100000000.
And in my event action, I try to get the vertex position of Ar39 by using:
if (event->GetNumberOfPrimaryVertex() > 0) {
G4PrimaryVertex* primaryVertex = event->GetPrimaryVertex(0);
G4PrimaryParticle* primaryParticle = primaryVertex->GetPrimary(0);
G4ThreeVector position = primaryVertex->GetPosition();
fZpos = position.z() / CLHEP::cm;
fSpos = std::sqrt(position.x()*position.x() + position.y()*position.y()) / CLHEP::cm;
I feel like I either create my geometry wrong or the way that I try to get the vertex positio is worng.
